Measure pedal bracket holes and frame holes.... All Measurments that you think will detail what you have to work with. I will then measure mine and post it too. Then we can see if your frame or pedal cluster is the issue. Is your pedal cluster from a JDM? does it seem straight? What year and model donor? Take a pic of the pedal mount bracket bolted to frame without the cluster in the way.
