Today I had a few hours to play with and started modding tithe passenger footbox. I moved the crease forward a few inches, the inner aluminum panel now hugs the square tube from the trans tunnel to the 4" tube. The footbox is now 2 1/2" wider than stock, and there seems to be a lot lot more left calf room now. You can see from the pictures how much farther in it is. I didn't see a need to move the front farther out. I was a little conservative on width, but I was able to maintain 1/2" clearance to the headers. I still need to patch the bottom panel and fabricate a new top panel still.
