Picked up my roadster while I was visiting states for Red Sox vs. Angels game at fenway.Car is in storage and its back to Italy for 11 more months. Can't wait to get back and get started building.
Congratulations! Tell us more about it!
Also, I've upgraded your account for full access.
Those are my boys in picture that will help me build every bit of car. I purchased a brand new BBM block and heads (427 type) but will end up being a 482 with about 550 horsepower when done. I have a 2-4 barrel set up, (blue thunder) and a top loader all parts in storage in colorado except kit which I stored on east coast. Bought smiths gauges and other little items to make it look original. This is my third cobra and I usually run them hard and a lot, last one I sold before moving to Italy and it had 54,000 miles on it. The next eleven months we have left in Italy will give me time to get the few items I need to build. Ordered car with powder coated frame, ff5 lower control arms, rectangular tail lights,center support under dash, 15 inch wheels, and 4 link rear. 4 link because I realized after my last cobra I like launches more than corners so independent rear wasn't necessary.
image.jpegimage.jpeg better pic of 2-4 setup and bbm heads done ready to put on engine
feadam,
Here's some info. on images you might like:
http://thefactoryfiveforum.com/showt...tures-in-posts
EDIT: That 2x4 intake looks WICKED!
Thanks David, I'll get this picture function right about the time the car is built. Adam
My Smiths gauges
IMG]http://thefactoryfiveforum.com/attachment.php?attachmentid=57180&d=1470404593[/IMG]
Gorgeous gauges. You're off to a great start collecting parts!
more engine parts for my build
Crank is 4.25 stroke, cam is hyd roller, pan is original aviad type. Valve covers are pent roof with out oil holes as original
nice looking gear
Mk4 # 8834 delivered 03/20/16 2015 IRS wildwood brake upgrade, 18"x9" front 18"X11" rear halibrand wheels, 390 FE, tko600
toploader
Finally moving back to states in 3 months can't wait to start building
Finally back in states in Owings Maryland. Car is in my garage but waiting on storage from Colorado for engine and trans. Has anyone used a 4 speed toploader with a 427 in one of these and if so what problems did you encounter? Also put front a arms on and was going to put brackets on spindles, do bolts come in kit to attach or are the bolts from donor struts?
IMG_7876 2.JPGIMG_7940 1.JPG finally getting some stuff done after move back from Italy
IMG_7958 1.JPGSuspension and some sheet metal done. Now if I could get my stuff from storage, Tools and engine transmission, I could accelerate this project.
IMG_7974 1.JPGsheet metal mostly complete body back on. Am I lucky because body is centered and it doesn't look like ill have to trim any aluminum panels?
All of my 427 FE stuff will be here on 6 Sept along with 4 speed toploader so I can get on the engine build.
Great engine plans. Looking forward to it all.
Good luck as you get things going! I am sure it has been frustrating waiting for your pieces and parts to arrive.
I have to say that you look a lot younger than I thought you were. The picture of you working on the driver's front makes you look very young! ;o-)
I look forward to following along with your build.
If only I was as smart as my 10 year old. I show him stuff once and I think he could build car by himself. The most fun part of the build will be the engine after it arrives from storage next week. I had a 427 FE in my first car, but this one is going to be built exactly the way I wanted when I built my other cobras and couldnt find the parts.
You know, it only gets worse. As my kids got older, they always knew the right way to do something (they always remind you that they do!), they just refused to do it. HA!
Will you be posting your engine build progress? It would be great to watch a big block rebuild!
Your boy looks happy in that picture. I hope he enjoys the engine build as well.
I will be showing build as it comes together.
image.jpeg block prepped and ready to build
IMG_8016 2.jpg First ride for boys, engine is almost ready to install
IMG_8022 4.jpg Heads, oil pan and intake on this week and hopefully ready to go. 482 FE should move this car ok. If anyone ever does a side oiler block you have to grind and modify the left insulator.
IMG_8023 3.jpgIMG_8025.jpg Heads ready to install on engine
IMG_8180.JPG Trans painted and shifter modified and installed
It's coming along pretty good!
Serial #9158
Think i have had to modify everything I've done with engine and transmision to this point, but I'm having fun with this build.
IMG_8041 2.jpgIMG_8043.jpgIMG_8044.jpg Engine is getting closer to being finished
Manifold on [ATTACH]77253
Engine Trans finally
Adam-
Wow, very nice; she looks good in there! Congratulations on your progress, and I look forward to seeing more updates.
Thanks, i want to have car look and feel like it would have in 1965. Engine is 482 instead of 427 but it looks exactly the same except with a little more horsepower.
