I'm 95% confident I went from 11mm to 10mm. I'll have to check my old thread.
EDIT: Yes went from 11mm to 10mm.
"I want to think it was the 10cm oil pump. I think the 11cm oil pump was bypassing so much oil because of its higher flow volume. The oil was bypassing all the time with the 11cm, just spinning in the block heating up. I also read the 11cm is for journal bearing turbos- I have a ball bearing- that maybe part of it with the oil restrictor for the ball bearing turbo you put on????)
I also do not think you should not have a closed vacuum block with the Element Dry Sump. The vacuum is working against the scavenge, I know Gator has his working though, but both ARE and Element told me to vent it like I have.
I ran without the flat bottom aluminum piece under the engine. That could of helped cool everything also. I did not notice any handling issues running without it. I may suggest the new owner throw it on and try it."
