Putting my questions at the top:
1. Am I forgetting anything? Or am I including stuff I won't actually use (I have the Coyote Fitment Kit + IRS).
2. With the calipers, I was thinking of ordering decals to put Wilwood back on after. Does Wilwood sell them, or just buy aftermarket like these on Amazon?
3. Pedal boxes, for things like the clutch quadrant assembly, should that be painted? POR or PC?
4. What about the Door Latch spacers? I think EdwardB simply attached them before body painting and they got painted.
5. The manual suggests PC for certain parts, yet some seem silly to PC, and are on my POR list, any concern? Like the quadrant stop and switch mount.
I didn't realize how long the engagement with local powder coating places was going to take... After a couple weeks of back and forth, I think I have found the right crew and reasonable price. 20+ years experience, probably take them a week, and between $800-1000 depending on the details of final parts list and such. They also are happy to do my calipers in my accent color for another $200 or so. Seems reasonable.
As I have been going thru this, I have read many other build threads that say "I should have included that on my PC list", so I have tried to do my best to be 1 trip and done, we'll see. Here's the list I compiled of stuff going to the powder coater.
53 panels to Powder Coat:
Part # Description 10551 Footbox Outside Vertical Wall, PS 10554 Footbox Outside Vertical Wall, DS 10853 Footbox Top, PS 10858 Footbox Top Outside Section, DS 10905 Footbox Tunnel Side Vertical Wall, DS 12273 Engine Harness Block Off Plate 12407 Dash Harness Block Off Plate 12806 Transmission Tunnel Front Vertical Wall 13138 Footbox Front Vertical Wall, PS 13139 Footbox Tunnel Side Vertical Wall, PS 14733 Footbox Front Wall Patch Cover, DS 15015 Footbox Top Outside, PS 15523 Footbox Top Inside Section, DS 15802 Wilwood Clutch Blockoff 16061 Footbox Top Inside Cover, DS 16277 Footbox Front Wall Panel, DS 10559 Firewall 10863 F Panel, PS 10864 F Panel, DS 10963 Firewall Extension, PS 13647 Fuse Panel Mount 16274 Coyote 2015 Computer Mount 16484 Coyote 2015 Fuse Panel Mount B70561 Front Battery Box (Breeze) B32204 Fan Shroud (Breeze) RP101 Main Intake Cowl - Nose Opening (Replica Parts) 10560 Trunk Floor, Upper (Front) 12959 Trunk Floor Block Off Plates (x2) 15011 Trunk Outside Wall, DS 15012 Trunk Outside Wall, PS 15222 Trunk Floor, Lower (Rear) 15223 Trunk Side Cover (x2) RT101 Trunk Drop Box (Russ Thompson) 10557 Cockpit Floor w/Tunnel Wall, DS 10558 Cockpit Floor w/Tunnel Wall, PS 10563 Transmission Tunnel Top 10823 Rear Cockpit Vertical Wall 10906 Transmission Tunnel Rear (U-Joint Access Panel) 12274 Transmission Harness Block Off Plate 12985 Footbox Dropped Floor, DS 13247 Transmission Tunnel Rear Corner, PS 13634 Footbox Dropped Floor, PS 13642 Under Door Lower, PS 13803 Under Door Top, DS 14057 Transmission Tunnel Cover Block Off Plate w/Hole 14582 Under Door Lower, DS 14583 Transmission Tunnel Rear Corner, DS 14584 Under Door Top, PS 15020 Rear Cockpit Corner, DS 15021 Rear Cockpit Corner, PS RP102 Underdash Filler Panel (Replica Parts)
Notice I am not using certain parts because I am replacing with parts from ReplicaParts, etc. This is mainly just the Nose panels and a couple dash switch mounts.
31 Additional Parts for Powder Coating:
Part # Description 33113 Bracket: Trunk Hinge Mount 15639 Trunk Hinge Arm 14788 Wilwood Brake Light Switch Mount, Steel 16209 Wilwood Pedalbox Mount 16210 Wilwood Pedalbox Rear Mount 13972 Bracket: Gas Strut, 90 deg bent, Short 13451 Frame Adjustment Plate, DS 13452 Arm Support Plate, DS 13520 Arm Support Plate, PS 13946 Hood Mount Plate 14006 Frame Adjustment Plate, PS 15143 Long Arm, DS 15144 Long Arm, PS 25410 Arm: Short 13531 Spacer: 3/16, Steel (Door Latch) 15176 Lower Handle Assembly 15661 Front Body Mount, DS 15662 Front Body Mount, PS 12470 QJ Bent Hook, DS 12471 QJ Bent Hook, PS 16000 IRS Swaybar Mount, DS 16001 IRS Swaybar Mount, PS
23 parts I am planning to simply paint with POR.
Part # Description 13653 Bracket: Brake Line Mount 14495 Fuel Filter Bracket 14689 Braided Brake Line Mount 15170 Bracket: E-Brake Mounting 15431 Accelerator Mount Bracket 60175 Drive Shaft, 31 Spline x10.50 15167 Fixed Gear 15168 Handle to Ratchet Mount 15169 Ratchet Tooth 14689 Braided Brake Line Mount 15016 Fuel Strap Block Off Plate 16258 Clutch Top Travel Switch Mount 16259 Clutch Bottom Travel Switch Mount 16260 Clutch Pedal Switch Mount 16262 Bottom Switch Clutch Quadrant Plate 16122 IRS Center Section
And lastly the 4 splash panels in Dupli-Color Bed Armor.
Thanks again
-Brian
