Thread: Lug nuts for #14867 - 15" Vintage Halibrand Replica Wheels
    Jun 2015
    Cool Lug nuts for #14867 - 15" Vintage Halibrand Replica Wheels
    Good evening to everyone!
    Quick question as FFR is already closed for the night. I need some lug nuts for my #14867 - 15" Vintage Halibrand Replica Wheels from FFR.
    Will these work? Dorman Lug Nuts 611-153.
    https://www.summitracing.com/parts/r...-153/overview/
    Thanks for any advice you can give.
    These are what I would recommend. The lug nuts that came with my FFR wheels are this type.
    https://www.amazon.com/dp/B00B2FCCDK...527037582&sr=2
    https://www.amazon.com/dp/B01MROPPJD...0-234bfe2b938c
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Jun 2015
    Cool Thank you!
    Dave,
    Thank you for the lug nut advice. Just got on Amazon and ordered them.
    Phoenixmsb
    Alliston, Ontario, Canada
    Did you check all your boxes? Mine came with them, found after I bought some. Same with valve stems.
    Check in the boxes that have the spinners. I didn't realize they would be in those boxes for quite a while. It didn't help that I opened one of the spinner boxes, found no lug nuts, and then didn't open the other three boxes because I believed I already knew what was in them! They were, of course, in the last box I opened! Good luck!
    Jun 2015
    Lug nuts and spinners
    Checked all my boxes - no nuts - BUT I did have a big problem. Test fitting on the spinners and the LH ones are smooth as silk. RH ones, jammed up just putting together in my hands and yes, the allen key was removed. Had to have FFR send me 2 new RH ones to replace these. I know they are imported wheels but I've never had something this terrible.
    Put some anti seize on the threads, they are really sticky without any lube.
    Jun 2015
    Forum comes through again
    As usual, this forum comes through again. One of my FFR-supplied lug nuts had a problem with the threads. I am sure they would have shipped me a replacement but I felt silly having them send me one lug nut. I thought it was a long shot that others would have already figured out exactly what I needed to order and Papa did. Quick and easy on Amazon. Glenn
