![Forte's](https://www.factoryfive.com/wp-content/uploads/2015/04/fortes.gif)
20
59
The stub tubes for the front hoop are welded in place, which basically takes the place of one set of through-bolts. The roll bars are removable because the rear stub tube can be pushed up inside the rear leg, then you are basically just pulling the hoop off the stub tubes. For final installation, the outer hoop and rear leg are through-bolted to the stub tubes.
![Martin's Dent and Collision Shop](https://www.factoryfive.com/wp-content/uploads/2019/02/martins-dent-shop.jpg)
