Likes Likes:  2
Results 1 to 23 of 23
Thread: Tire Stickers on 17" rims
    Oct 2017
    Does anyone have tire stickers on their 17" rims. I have only found two photos online showing 18" installs.
    I'm thinking about doing 1.25" letters for my Firehawk Indy 500 tires
    Kearney Nebraska
    I purchased some tire stickers from tiresticker.com for my 17" rims. I'm hoping to get time to put them on this week or weekend, so I can't offer you any advice on installation just yet. The tires are Toyo Proxes 888's
    Serial #9158
  3. Likes jgpost liked this post
    Oct 2017
    cv2065's Avatar
    I’ll be getting some as well. They look SWEET!
    Quote Originally Posted by jgpost View Post
    Those are my 18s
    I made an etching of the actual lettering on my tires and then scanned and sent to tire stickers.com They then produced the lettering I wanted exactly to match the lettering on my tires. You can do that if you are happy with the existing letters on your tires. Not a huge difference in sidewall height from the 17 to 18s so I think you will be just fine.
    I have pictures of the etchings in my build thread linked in my signature post #620
    Jax Beach, FL
    Those do look good! I am really starting to get a thing for that look. I didn't know you could get custom ones that really match what is on the tire. I like that idea.
    cv2065's Avatar
    I think these are on 17's. Even though this is a Nitto tire, the Goodyear stickers still look pretty good!
    Kearney Nebraska
    I got mine on this week...
    These are on 17" rims/tires, with a 1.25" decal height. I assume that height includes the stripe underneath the letters, so the letters may be a little shorter than the standard 1.25" letters. I can measure later, if you want to know. I struggled getting the amount of glue correct. I had a little ooze out from under the letters on some of them. I'm going to try to clean it up with acetone later. How have some of you experienced guys dealt with excess glue? Besides the glue, I really like the way they look and the vibe they give the car...
    More details in my build thread.
    Serial #9158
  10. #9
    Kearney Nebraska
    Hey, jgpost, Just in case you aren't aware of this; tirestickers.com has some suggested letter sizes based on your side wall heights. They also ask for your tire size and type so they can design the decals accordingly. It's not a one size fits all type of thing.
    Serial #9158
  11. #10
    Oct 2017
    Just installed them!! 1.25" letters
    What do you think
  12. #11
    Kearney Nebraska
    Looks great!
    Serial #9158
  13. #12
    cv2065's Avatar
    Outstanding!!
  14. #13
    mburger's Avatar
    Punta Gorda FL
    Looks great especially with the meatball!
    Mark
  15. #14
    Senior Member dpariso's Avatar
    Beach Park, IL
    jgpost,
    Would you mind sharing some tips on the install? Did you sand the tire where the letters are glued? How much glue would you recommend?
  16. #15
    Chino Valley, Arizona
    Very trick!
  17. #16
    Millis, MA
    “Privateer”
    289 USRRC Chassis #9188 p/u 9/11/2017 Go kart 3/18/2018, road legal 6/16/2018
    Ford full roller 306 built by my son and me Holley Sniper EFI
    TKO600 2015 IRS 3:55. 17” FFR Hallibrand replicas, Power steering
    FFR Vintage instruments, Wipers and Heat/defrost
    Lots of parts and advice from Mike Forte & Mark Reynolds (Breeze Automotive)
  18. #17
    cv2065's Avatar
    Here's some on 17" wheels. You don't need to sand the tire...Just be sure that its completely cleaned with Acetone. Regarding the glue, you just put enough on the sticker to cover it. Don't glob it on and make sure that you get the corners. Glue is pretty toxic stuff and will adhere almost immediately to the rubber when you put the sticker down, but you do have some working time before that point.
  19. Likes Higgybulin liked this post
  20. #18
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    I love the black powdercoat on the wheels. Did you do a clear PC over the black, or is that just a gloss black PC? I'm planning to do the same thing on my 18's, and leave the spinner shiny (maybe clear PC to keep it from tarnishing).
    Edit: Sorry for the threadjack. Hopefully it's just a quick detour.
    To get back on track... the tire stiickers idea is very intriguing. Anyone have more examples on 18" wheels?
  21. #19
    Beach Park, IL
    CV2065,
    Thanks for the install tips.
    What size are your letters?
  22. #20
    cv2065's Avatar
    That’s high gloss powder coat no clear. Powder coater said the clear on high gloss was a waste, so I didn’t get it.
  23. Thanks JohnK thanked for this post
  24. #21
    cv2065's Avatar
    Quote Originally Posted by dpariso View Post
    CV2065,
    Those are 1.5”
  25. #22
    Nov 2019
    Those are 1.5”
    What's your tire size on those nitto's? Do you happen to have an exact model as well?
  26. #23
    Southern Ontario
    I'll say it again....those wheels are SICK!!
    MK4 #11012 picked up 04/16/24
    351W, 3 link, single roll bar
    MK4 #10616 picked up 4/10/23
    MK4 #9759 picked up on 4/3/19
