Thanks Thanks:  2
Results 1 to 14 of 14
Thread: Updated Coyote Fitment Instructions
    Senior Member lewma's Avatar
    Jan 2018
    San Marcos, CA
    All
    Just incase you hadn't noticed, FFR has updated their coyote fitment instructions here:
    https://www.factoryfive.com/wp-conte...ster-rev-X.pdf
    Hopefully this will help the builders that are using the newer / Gen2 coyote engines in their builds.
    mark
  2. Thanks Gbeck thanked for this post
    I noticed that the other day. The first version of Gen 2 Coyote instructions were just an update to the Gen 1 instructions, so both were together. It was a bit confusing and incomplete. I briefly looked through the revised Gen 2 instructions. They cover all the usual trouble spots -- tach connection, mounting the PDB, starter and fan wiring, the now standard single clutch switch, etc. The one thing I noticed though is they didn't get the famous CMCV plumbing right. They have the vacuum line hooked to the intake instead of the vacuum port. I, along with others, know this doesn't work and throws DTC's because the CMCV's when commanded don't move without a vacuum source. Other than that, nice improvement.
    BTW, that web location is always a great location to check for published instructions from Factory Five. http://www.factoryfiveparts.com/instructions/
  4. Thanks Clover thanked for this post
  5. #3
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    Mark,
    Thanks for posting. Will take a look as I am in the middle of my install.
    Paul - noted on the CMVC. I have received some good guidance on this but will likely need to post a confirmation of my setup.
    Mark
    Mark
  6. #4
    Jan 2018
    San Marcos, CA
    Mark and Paul
    Any easy steps either of you can post in addition to the updated fitment instructions regarding the CMCV plumbing ? I'm getting close but still don't quite understand it.
    thanks
    mark
  7. #5
    Mark and Paul
    thanks
    mark
    I'm going to assume you have the latest 2017 Gen 2 Coyote crate. If so, the vacuum line on the RH side of the engine needs to be connected to the vacuum port on the front of the engine by the intake. It's really that simple. This post has the 2017 vacuum diagram with a markup of where the vacuum needs to be connected.
    https://thefactoryfiveforum.com/show...l=1#post330329
    Note that in the Factory Five instructions they show hooking the fuel regulator vacuum reference to the vacuum port by the intake mentioned above. You have two choices: (1) Use a Y connector to attach both, or (2) Not use the vacuum reference on the fuel regulator. Just plug it. Lots of discussion but many, including me, have found the vacuum reference isn't needed. My tuner specifically said not to use it. Also, some are successfully using a GM regulator back by the tank that doesn't even have the option for a vacuum reference.
    If you have an earlier version Gen 2 Coyote, there's another connection required, but the above doesn't change.
  8. #6
    Jan 2018
    San Marcos, CA
    Thanks Paul
    There's just one more connection that's not 100% clear to me. On the driver's side valve cover, do I connect a 1/2" hose from there to a barb that I need to fit to the 90deg spectre intake tube that I have ?
    thanks!
    mark
  9. #7
    Thanks Paul
    thanks!
    mark
    That's the PCV circuit, just to be clear. Not the CMCV. Yes, it should be connected to the intake as shown.
  10. #8
    Kirkland, WA
    New line in the parts section: "Ford Performance does not recommend the Corvette fuelfilter/pressure regulator"
    Has anyone followed up with Factory Five or Ford yet to determine the source of this comment? I'm reasonably comfortable with my use of this regulator based on a number of successful previous installations by other builders, but would like to hear why.
  11. #9
    Senior Member chrisarella's Avatar
    Clearwater, FL
    Quote Originally Posted by initiator View Post
    New line in the parts section: "Ford Performance does not recommend the Corvette fuel filter/pressure regulator"
    I would like to know the answer to this as well. The cynic in me thinks it is a ploy to sell more Ford products and not promote GM products.
    Mark IV Roadster #7679
    Coyote 5.0, T56, Hydraulic Clutch, IRS, Torsen Diff, Wilwoods, Hydraboost, ABS Power Brakes, Power Steering, & tons more extras.
  12. #10
    Quote Originally Posted by chrisarella View Post
    You might be right about the anti-GM sentiment... But most of us are using Aeromotive regulators when not using the GM one. My guess is the official party line from Ford is in their own instructions: "Fuel pressure regulator must have reference to manifold vacuum." (Page 15) Since the GM regulator doesn't have that capability, that might be why. The rest of the story, which I referenced in an earlier post, is my tuner didn't want the vacuum attached to the regulator. So I've been running without it. So it all may be a moot point.
  13. #11
    Jan 2018
    The emphasis should be on recommend - Ford cannot recommend (endorse) a configuration they have not tested extensively, so they do not reccommend ny configuration that differes from that in their production vehicles. They need to state that so they are not reaponsible if you use an alternate solution, bugger something up, and blow up your motor.
  14. #12
    Quote Originally Posted by JoeAIII View Post
    Your point is a valid one for sure. Follow the directions or you could affect how the motor runs or worse yet void the warranty. But the rest doesn't completely apply in this case. Production vehicles with the Coyote use a return-less on-demand fuel system. Voltage to the fuel pump is varied to keep the appropriate pressure at the injectors. For the crate motor, Ford Performance chose to go with a more traditional (and decidedly less complicated) return style system with a constantly running pump and regulator. So while Ford Performance I'm sure has tested this setup extensively, still not the same as a production car. The vacuum reference line in question here is specific to the regulator used for the crate motor return style setup, and isn't in play for production vehicles.
  15. #13
    Jan 2018
    San Marcos, CA
    All I hope you can see the image in this link
    https://photos.app.goo.gl/AnNudnHxoJxQbGy4A
    Does A connect to B ?
    Mark
  16. #14
    Mark
    No. B should be capped as shown in the instructions and in the picture. Not 100% positive what A is. Is that the vacuum line from the reservoir on the back of the intake? If so, that needs to be connected to the main vacuum connection also by the intake. Shown and discussed on earlier posts in this thread.
