12
Originally Posted by
LearningCurve
If it were the valve stem seals leaking oil into the chamber, wouldn't the leak test show a greater drop in pressure?[/url]
No, The intake "valve stem seals" seals between the gases/oil in the valve cover and the intake manifold air (vacuum or boost).
The exhaust "valve stem seals" seals between the gases/oil in the valve cover and the exhaust manifold gases.
Neither of these seals affect the pressure in the combustion chamber.
