Thanks Thanks:  13
Likes Likes:  32
Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 131
Thread: Please Graduate FFR #8352
    Dan-
    The car looks incredible, and like many of the other posts here, I really admire your craftsmanship and attention to detail! The engine compartment is awesome! I love the clean look, the color matching, the way everything is tucked away, etc. I also like the interior. So many subtle, yet classic changes; it works perfectly!
    You mentioned that you mounted the e-stopp on the trans tunnel. Do you have any pics of how you did that? I didn't think there would be enough room at the top of the tunnel to fit all that hardware. I would appreciate any pics, if you don't mind. I was also hoping you might show some more detail on your hood latching/popper set-up. If you don't mind, I would like to see some more detail on that as well.
    Again, terrific job; I really like what you have done! Congratulations on a great build! Thanks in advance for your help with the pics as well.
    Sep 2011
    Steve these are the only two pictures I could find on the E-Stop brake, I made a pulley system. I wish I had more pictures but the system works great..
  3. Thanks Itchief, WIS89 thanked for this post
  4. #43
    Sep 2011
    Couple more pictures, this was taken with engine and trans out. You can see the E-Brake system mounted to the top of the trans tunnel. You can also see the PVC pipe I painted black to run the wires in.
  5. Thanks WIS89 thanked for this post
  6. #44
  7. #45
    Sep 2011
    Sep 2011
    Coyote gas pedal made to match clutch and brake, or at least I tried to get close.
  9. #47
    Sep 2011
    8FA276CA-7FCB-4227-8DCA-9CADACF26ADF.jpg905042FA-EB1C-4DC8-998A-BAE7FFBBE19F.jpg7DE00A64-BA82-4F8A-A706-1495E2CD7866.jpegE8CF9883-80F9-49AB-9EBF-7F6A081F11FF.jpg
    Here is a quick and cheap way to finish off the rear leg of the roll bars that you see when the trunk is open. I add some ABS plastic left after making the wheel well protector for all four wheels. I made a cardboard pattern that fit around the roll bar, transferred the pattern to a piece of ABS plastic, used a heat gun to soften up the plastic, put on a pair of welding cloves and formed it around a pipe the same diameter of the roll bar, let it cool. Cut away some of the back so you can stretch it around the roll bar, after some trimming wrapped it to match..
  10. #48
    On a roll Al_C's Avatar
    Wheaton, IL
    Wow. Truly amazing build. Congratulations!
  11. #49
    Dan-
    Thank you very much for all the detailed pictures! I didn't think the e-brake would fit there, but it looks like it had plenty of room!
    I also like the pvc you used to cover the wiring. I will try and find some of that to protect my wiring as well. Nice idea!
    Thank you again for the great pics!!
    Sep 2011
    Few more pictures of the E-Brake pulls system, hope this helps
  13. Thanks WIS89 thanked for this post
  14. #51
    Senior Member Mick40's Avatar
    Mass
    Wow, the level of detail you're a true craftsman. Thanks for sharing!
    Mick
  15. #52
    Dan-
    Thanks for the additional pics! You engineered a great system there! I will see if I can copy it a bit for my car. I really appreciate your help with this!
    Sep 2011
    6AD0D9B2-36D5-4BE6-88D2-BBB2436E35D4.jpgBB924AA2-510C-4C5C-9D72-587312FD7AFA.jpgFAC57724-45AB-4A68-B2A5-C6EDFBA3F08A.jpg6C58214C-43F6-4861-AFB6-F926A2BE460B.jpg
    Here are a few pictures of the hood latches, if you look at the fipped over body by the hood opening you see two pads. I used 1/4 inch thick metal 3 inches square. Drill and tap two 1/4-20 all thread studs and bonded them to the body with 3M marine fiberglass bondo, this was used to attach the cables plungers mounts I made. Also of you look you see a 1/2 square metal tubing that runs between the two mounts, I used this to mount the popper.
  17. Thanks WIS89 thanked for this post
  18. #54
    Thank you again Dan! Some great and useful pictures! You did a really terrific job, and the car looks wonderful.
    Some really great ideas you came up with, and the little details make all the difference. Sincere thanks for sharing them!
  19. Likes DANW liked this post
  20. #55
    Sep 2011
    I keep calling the parking brake E-Brake, it is actually call E-Stopp..
  21. #56
    Sep 2011
    F257C41B-073A-4FB0-807C-F4FFB0734397.jpegD4FF694A-1A84-4515-9F9C-361AF73DD939.jpgF582513F-6FC9-4F63-83D4-721AED103C11.jpg
    I spent a lot of time making sure the rivet spacing was correct then cover them up with a 3/8 inch aluminum rod milled down and then milled a channel on the back side so the rivets could set inside the channel so it fit flush. After that sent to chromer and installed with 1/4 inch 3m molding tape.
    Dan
  22. #57
    Sep 2011
    2FFBFEAA-2E25-4CCB-8485-6142D54B5DC8.jpgFF1BE151-4B82-468E-828D-BB0CE8AF8679.jpg22D199EB-DB15-4B38-87C5-E73781E55CC4.jpg
    My powder coated didn’t have a good way to powder coat the rivets. I didn’t want to give up so I made a wood box, made a sheet metal top with a tab hanging out so he good ground it. Drilled holes in the sheet metal for the rivet stems, after that installed DYNA Matt to the back side, that helped hold the rivets in place and the thin foil help ground the rivets when I pushed them from the top side..
  23. #58
    I absolutely love your creation! Your dash is tasteful and very well executed. The nice touches are everywhere. The engine and engine bay are perfectly dressed. Jeff Kleiner clearly outdid himself on the paint. The entire car is stunning! You can be very proud!
  24. Thanks DANW thanked for this post
  25. #59
    Sep 2011
    C6354355-D4BB-4F45-A218-D7EE4BC8A756.jpeg60DD6440-8D7C-48FF-A655-B6B337E5B1E0.jpegEFA3366A-5952-498D-BAA2-DE5B9946B7DA.jpeg
    Here are some pictures of the two ground terminals I welded to the frame, the one is just behind the starter the other is in the trunk area. You can see I placed a copper plate over the studs. From the ground terminals different size ground wires go to other smaller terminal blocks behind the radiator, seperate ground to the alternator and starter, a ground to the engine block and heads. I’m sure it is over kill but seems like most electrical problems are ground related..
    Thanks Dan
  26. #60
  27. #61
  28. #62
    Super clean and wonderful build. A lot of nice touches through-out the build. Nice job!
    Paul
  29. #63
    Sep 2011
    Questions have been asked as to how I cut the holes in my custom dash. Plasma cutters are fairly inexpensive nowadays and it makes a nice cut. Here you go!
  30. #64
    Sep 2011
    5E5A8CDF-C533-4B92-A172-52C3F0F8F336.jpeg126D4731-64C9-4C23-8EA7-995C5D4FB1E4.jpegFE3375F2-6069-44FB-9983-9D91854DD3F8.jpeg91365D70-B973-4786-9E38-317DCD806F0F.jpegCF5E3696-BAEA-46BB-9119-1DE6853884CF.jpg
    I wanted to dress up and seal the front and rear fender wells. I used .08 aluminum to make the panels, and then purchased a 4x8 foot piece of ABS plastic that was cut to fit tight in the wells and secured lower front and back. Hope the pictures help explain. I didn’t take pictures of the rear fender wells during the process but will this winter.
  31. #65
  32. #66
    Senior Member John T's Avatar
    Feb 2018
    Springfield, Missouri
    There is a lot here to like. I like your interior and what you have done with the wheel wells. You've got a great build. Thanks for sharing.
  33. #67
    Dan, look at you go... few days ago Kay was having to coach you on posting pictures and now you're putting up vodeos Really happy to see you showing all of these details and features so that others can see how outstanding this build truly is!
    Sep 2011
    Thanks Jeff, I wish I would have taken more pictures over the years including all the mistakes trying to get it right. My eyes could see what I wanted for changes or modifications but my skills had other ideas. I hope the pictures help explain some of the mods, over the years I sure appreciate all the info on this forum.
  35. #69
    Aug 2018
    I'll join the group and say it...totally amazing
    Your eye for detail is just spectacular
    Enjoy the miles...you deserve it
  36. #70
  37. #71
    Sep 2011
    501F17B3-FE3D-4814-85EF-0C34993D4FCC.jpegFC390E05-C2A3-4FC8-825B-4582E3EB6FE3.jpeg022D6A43-64E1-4F45-9891-5C3EC6E66BD6.jpegEC7C0256-DD4F-4BDD-8621-3311765B0F5E.jpeg33FC0692-77B6-4F40-87C7-AA56263A3268.jpg
    I had a few guys PM me about the dash, found a few more pictures. Made out of .08 Aluminum. Lots of template paper, used a laser level and made 1inch grid lines. Hope this helps..
  38. #72
    Sep 2011
    Couple pictures of the seats and center console. You can see how I extended the Factory seat backs and some pictures of the wood center console that I sent to the upholstery..
    Dan
  39. #73
    Sep 2011
    68C79AC3-91D4-4B6B-8362-89A71ABF79F4.jpeg70C4D7AF-21AF-4F2F-8554-804FB5B0FF97.jpeg29054CB6-7261-4A0F-ABE8-F5C5E3EC9604.jpeg54C3E389-0940-4DF1-8537-80AF95DFD1F1.jpeg
    Few PM’s asking how the Headers can fit on the passenger side footwell since i moved the foot well in front of the 1.5 inch round tube. The notch worked for this..
  40. #74
    Mark Eaton's Avatar
    Medford, Oregon
    I wish I was your neighbor
  41. #75
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    Hey Dan,
    I'm still reviewing you pic's (with envy).
    I am starting the wiring for my Coyote. I really like how clean you set-up is under the hood. I am curious where you mounted the Ford Performance Power Distribution Box as I don't see it on the firewall (typical location).
    Thanks in advance.
  42. #76
    Chino Valley, Arizona
    Dan, an absolutely stunning car and your attention to detail and thinking outside the box is surreal!
    Congratulations on a unique and finely crafted killer snake.
  43. #77
    Sep 2011
    Lewis
    The power distribution box is mounted in the raised part of the passenger side foot box, it is directly behind the PCM. I don’t have a picture but I mounted it on rails so I could lower it into the passanger foot box if need for maintenance.
    Dan
  44. #78
    Sep 2011
    Thanks Chris I had a great time building this. All the members on this sight gave me a lot of inspiration. I had more pictures of the build but lost some of them in the Cloud. I’m trying to post all I come across.
    Thanks again Dan
  45. #79
    Feb 2018
    Frisco, TX
    What an amazing build. I am humbled by what you created under the hood and in the cockpit. You should be winning Best in Show for years to come with this car!
  46. #80
    Mar 2017
    Lewis
    Dan
    Neat idea. I was thinking about the same location but was scratching my head on how to access.
    Just curious, where you located the terminal block/fuse ?
    Mark
