Thanks Thanks:  7
Likes Likes:  9
Results 1 to 40 of 40
Thread: Pomp and Circumstance
    So. Bay (So. Calif.)
    Guess it's that time. The graduation march. The build phase officially ended this week. Now I guess the adjustment phase starts, and I suppose in the next few months, the maintenance phase will begin.
    I'll have to do this in multiple posts to get all the info in. Since I didn't do a build thread, I'll start with my list of Features, Components, Modifications, Alterations, Fix’s, Extras, Upgrades, Options, Changes and Additions, in multiple posts because of the 10,000 character limit. Then, because I can only post 5 pic's at a time, I'll post the photos in 3 or 4 posts. I have to say, those of you that did do build threads, I don't know how you had time to build a car and chronicle it in a build thread. I barely had time to read the threads, let alone do one. My hat's off to you.
    I originally bought a used kit that had been started by the original owner. I figure I probably have done about 90% of the build since then. The original owner estimated he had about 200 hours in it, and I have kept a build log and tallied 1712 hours.
    As of today, I have 450 miles on the car (I stopped and took a picture of the odometer when it hit 427...), and most things are working just fine. A few little things, like a valve cover oil seeping, and a temperamental cooling fan relay, etc., will need to be addressed in the adjustment phase. But the big things like electrical, lights, running, starting, and stopping all seem good.
    Some of the things I put in the build I'm very glad I did, and a few things I'm not so sure. Some of the items I really like are the breeze radiator shroud, front battery mount, and stainless roll bar, Alex's wheel well liners, the old school carbureted 427 SBF (it's loud, rough, a little temperamental, and a bit smelly-like me), all LED lighting, stereo (just fine around town), adjustable seat sliders and power steering. Some of the stuff I'm not so sure about is the hydraulic clutch (works very good, but I had a hard time with master cylinders and line leaks, maybe still do), and the TKO 600 with the .82 5th gear. It's absolutely perfect for town/city driving, but a tad low gear for freeway driving above 65mph. Maybe that's a good thing-it will keep me from getting too carried away with the speed. I will say that there is definitely a learning curve on how to drive these things. Mine has already scared me enough to teach me that I don't really know how to drive it (yet). It has more horse power than should be allowed by law. Ooooh, did I just say that?
    For those in California, here's my SB100 title and registration thread. https://thefactoryfiveforum.com/show...d-Registration
    Anyway, on to the list... (the stuff in parenthesis are items I bought, but didn't use, at least not yet, because I changed my mind or couldn't decide on what to use.)
    General:
    · Factory Five Racing MK IV Roadster, #8439
    · Complete kit, original delivery 11/2014, I bought it 2/2016
    · First start 12/2016
    · First Go-Kart 12/2016
    · Registered, titled, licensed 3/2017
    · Paint 6/2018
    · Build complete 10/2018
    · Black powder coated frame
    · FFR Body cutouts
    · Non-donor build
    Engine:
    · The Engine Factory built Ford 427w SBF, 520 hp, 530 ft/lb torque, Built 9/1/2016
    · SHP SBF Dart block, New
    · Edelbrock Performer RPM Aluminum Intake manifold
    · Edelbrock Victor Jr. Aluminum heads
    · Comp Roller Cam
    · Comp Roller Rocker Arms
    · Canton 7 1/2-quart front sump oil pan
    · Ceramic coated 4 into 4 headers
    · Percy’s Vibe-Lock header bolts
    · “Cobra” branded air cleaner
    · “427 Cobra Ford Racing” branded valve covers
    · Holly 750 carburetor
    · Summit Racing Distributor
    · Summit Racing Cap and Rotor
    · Taylor 8mm Spiro Pro Silicone spark plug wires
    · MSD Blaster 2 Coil
    · Cobra Earl Thermostat Housing with elevated inlet and 16 lb filler cap.
    · Closed PVC system (licensed under California SB-100)
    · Reverse rotation water pump
    · Summit 34 oz. coolant expansion tank
    · March pulley and bracket package
    · Ford Racing High Torque mini starter with solenoid
    · Russ Thompson Throttle block & pedal
    · Stainless throttle pedal stop & modification with strengthened backstop, Adjustable
    · Custom Mechanical throttle linkage
    · Breeze 3/8” fuel tank pickup, AN-06 to 3/8 stainless braided hose, no return
    · Stainless 3/8” fuel line and AN-06 fittings
    · Earl’s Plumbing power steering hoses and fittings
    · Earl’s Plumbing flex fuel lines
    · Summit Racing canister fuel filter with AN-06 connectors
    · Fuel tank vent modification, charcoal filter
    Transmission and clutch:
    · Ram 10.5-inch Clutch
    · Ram Pressure plate assembly
    · Clutch pedal stop, Adustable
    · Forte Hydraulic Clutch kit, CNC .875” slave, Wilwood 1.00” M/C
    · Stainless braided, hi-temp fiberglass covered hydraulic clutch hose
    · Clutch pedal/frame interference fix (frame relief and strengthening)
    · QuickTime SFI 6.1 steel bell housing
    · 3/8 inch removed from bottom of bell housing and backing plate for ground clearance
    · Tremec TKO-600 RR, 5 speed transmission (.82 OD 5th gear)
    · 7/8” one-piece spacer to shim up transmission
    Rear End:
    · Metco driveshaft safety loop
    · Moser M9, Ford 9” solid axle rear end
    · Eaton Detroit TruTrak limited slip differential
    · Custom 11½ inch drive shaft, 31 spline yoke, Spicer 1350NZ U-joints
    Suspension, brakes, wheels:
    · Halibrand Replica aluminum alloy wheels, 17 x 9-inch front, 17 x 10½-inch rear
    · Nitto 555 Extreme, Front 255/40ZR17, Rear 315/35ZR17
    · Koni coil-over shocks, 500lb spring Front, 350lb spring Rear
    · Front suspension upper control arm, ½ inch reduction on rearward arm modification
    · Energy Suspensions red lower ball joint dust boots
    · Energy Suspensions red tie rod end dust boots
    · Gordon Levy adjustable rear lower control arms, black powder coated
    · Wilwood 6 piston caliper front, Dynapro 6 12.88” dia. vented rotor
    · Wilwood 2 piston Caliper CPB (comb. parking brake) rear, 12.19” dia. vented rotor
    · CNC remote aluminum brake and clutch triple reservoir set
    · Earl’s Plumbing stainless braided reservoir to master cylinder brake and clutch hoses
    · Stainless ¼” brake lines
    · Rear wheel centering hole machined to 3.065” to fit the 3.060 boss on the axle
    · Wheel spinner/knock off ring modification
    · Breeze Power Steering rack, Maval, 3 turns L to L, with 1” extensions
    · Electric parking brake actuator
    · Parking brake cables re-routed through aluminum pulleys above 4” frame tube
    · Parking brake caliper helper return springs
    Continued in part 2....
  2. Thanks RBachman, mike8082 thanked for this post
    Likes RBachman, mike8082 liked this post
    Continued from part 1
    Interior, cockpit and trunk:
    · Removable transmission and drive line tunnel cover
    · Breeze stainless trunk prop rod kit with modified pivot attachment for DWC trunk mods
    · Breeze Russ Thompson driver dead pedal
    · Lizard Skin ceramic insulation and sound deadener, cockpit and forward trunk
    · Forward and inboard DS and PS footbox aluminum panel engine bay stand-off heat shielding
    · Passenger left, right, and dash Billet Clear Anodized Aluminum Grab Handles
    · Driver and Passenger double floor reinforcing
    · Full cockpit carpet, black
    · Transmission tunnel mounted accessory pouches left and right side
    · Rear cockpit bulkhead mounted accessory pouches left and right side
    · Removable cockpit door sills
    · ********** Cobra embroidered floor mats
    · (Factory Five Racing embroidered floor mats)
    · Full trunk carpet, black
    · Jeg’s Adjustable double latching seat rails, driver and passenger
    · Tangent Technologies steering wheel partial leather wrap kit, black
    · RoadWire Seat cushion and seat back heaters, Hi/Lo temp settings
    · Under dash support panels, 3 places
    · Watson’s Streetworks small stainless cup holders
    · Dark Water Customs drop trunk modification, powder coated black
    · Dark Water Customs trunk lid inside access cover
    · Speed Dawg shifter ball, red cobra with rally stripe, 5 speed graphics
    · RedLine Goods Custom Leather shifter boot
    · ********** 427 Retro shifter with nonfunctional reverse lockout handle
    · ********** “Cobra” sun visors, top rail mounts
    · ********** “Cobra” wind wings
    · (********** interior door panels)
    · (********** Ray Dot brushed aluminum mirrors and aluminum brackets, L and R sides)
    · ********** Ray Dot chrome mirrors and aluminum brackets, L and R sides
    · Herb’s Interior Door Panels
    · Door latch handle pivot modification
    · Door latch knob modification
    · Replica Parts/Mike Everson Weather Stripping kit
    · Replica Parts/Mike Everson billet shoulder harness trim rings
    · Whitby Motorcars stainless windshield mount inserts
    · Upper Windshield mount for center rear view mirror
    · ¼ inch Rubber insert for upper windshield molding
    Electrical, lights and Stereo
    · 100 Amp circuit breaker and master cutoff
    · 1 wire alternator
    · 50 Amp alternator circuit breaker and cutoff
    · Speedhut vintage gauges with 4 button adjustments under dash
    · Accessory/cigarette lighter receptacles under center dash
    · USB Accessory receptacle rear cockpit bulkhead to stereo
    · Painless remote 7 circuit switched fuse block
    · Hot powered standalone 6 circuit fuse block above DS footwell
    · Remote standalone 4 circuit fuse block above DS footwell
    · Dash LED warning & status lights, Green-Turn/Hazard, Blue-hi beam/flash to pass, Red-low voltage (steady red)/Start attempt while in gear (slow flashing red)/Parking brake not released and clutch pedal pressed (fast flashing red)
    · Safety cutout, starter energized while in gear w/ clutch depress bypass and manual switch bypass (starter will not engage while in gear and clutch pedal not pressed, starter will engage if in neutral or clutch pedal is pressed)
    · Warning system, Starter engaged w/ in gear, adjustable flash rate red dash warning light
    · Warning system, Parking brake not released w/ clutch depress, adjustable flash rate red warning light
    · Sparkbright LED Battery/Voltage indicator (Green/Amber/Flashing Red voltage indicator)
    · Ron Francis LS-11 Low Voltage warning module, steady red dash warning light
    · Ron Francis SS-6 turn signal/flasher converter module
    · Ron Francis polished aluminum dash toggle switches, knobs, and bezels, with red accents
    · Russ Thompson VW self-canceling turn signal with hi/lo beam stalk button (and flash to pass)
    · Adjustable flash rate turn signal flasher
    · Watson’s Streetworks LED Headlights
    · Custom headlight mounting clips (that don't bend, and to allow better 'clocking' of the lens)
    · Super Bright LEDs Amber front parking and turn, dual brightness LED lights
    · Super Bright LEDs Red rear parking, brake, and turn, dual brightness LED lights
    · Super Bright LEDs Wheel Well LED lighting, blue
    · Super Bright LEDs Trunk and engine bay LED lighting, cool white
    · Super Bright LEDs Cockpit interior LED lighting, cool white
    · Kawell LED reverse/backup light
    · Lucas L539 front Clear Lens & Rims
    · Jeff Kleiner License Plate mount and light modification, with LED lights
    · Jeff Kleiner Front parking/turn light O-ring modification
    · Sony Bluetooth Audio System
    · RockfordFosgate Power Amp
    · Bazooka sub-woofer
    · Focal speakers and Tweeters with crossover
    · Advanced Keys keyless ignition and alarm system
    · Advanced Keys push-start ignition system
    Heat and Fresh Air
    · Footbox fresh air system, custom made stainless butterfly valves, hi-temp 3” ducting, either/or independent blower switching
    · Vintage Air heater, with custom through bolt and aluminum backing mounting modification
    · Engine compartment heater blower shroud, and hi-temp ducting to footbox intake
    · Vintage Air electric servo valve for heater control
    · Vintage Air Servo Heater Control Valve kit, with 3 speed blower rotary switch
    · ********** fresh air inlet scoops
    · ********** fresh air inlet scoop screens, powder coated black
    Body and exterior:
    · Breeze 1¾ inch Stainless Steel Driver’s side roll bar, polished
    · Replica Parts/Mike Everson polished aluminum roll bar trim rings.
    · Jeff Kleiner Rear Quick Jack/Body mount coupling nut modification
    · ********** fender louvers, Powder coated silver-chrome
    · ********** front body mount rubber grommets
    · ********** “Cobra” hood and trunk badging
    · ********** “427 Ford Cobra” fender badging
    · ********** Polished Stainless Quick Jacks
    · Grade 8, 7/16” threaded rod for rear Quick Jacks
    · Grade 8, 7/16 x bolts for front Quick Jacks
    · ¾ inch OD Stainless Tubing, polished, front and rear for Quick Jack mounts
    · ½ inch OD plastic liner for Quick Jack bolt and stainless tubing
    · Removable front and rear elephant ears, powder coated black
    · Hood and trunk hinges powder coated black
    · Alex’s inner wheel well liners
    · Rear Elephant Ear left and right-side lower supports
    · (Replica Parts/Mike Everson Front license bracket mount)
    · Replica Parts/Mike Everson billet roll bar trim rings
    · (Replica Parts/Mike Everson billet windshield trim rings)
    · Jeff Miller Customs fiberglass hood scoop
    · Jeff Miller Customs paint, 3-color with stipe inside hood and trunk lids, Ford Red Fire Pearl Metallic main color, BMW Bright Silver stripe, Black accent pin
    Miscellaneous:
    · Stainless side pipes, polished
    · Drummer Mike polished stainless-steel side exhaust shields
    · Custom designed muffler/side pipe hangars, adjustable, fully articulated
    · OEM Ford fuel tank/filler tube gasket
    · OEM Ford fuel filler cap
    · Pegasus Stainless radiator screen, powder coated black
    · Speedway Racing Nomex honeycomb radiator screen, black
    · Removable radiator cowls & screens
    · Radiator side cowl and screen mounting panels, powder coated black
    · Radiator cooling fan intake/block coolant sensor
    · Radiator cooling fan override-ON dash switch
    · Radiator cooling fan isolation relay, with selectable constant-on or ignition-on mode
    · Radiator cooling fan relay bypass / power ON switch
    · Radiator cooling fan COMMAND ON/FAN ON/OFF (red/blue/green) status LED indicators, with ignition-on/off/override-on LED power modes
    · Breeze Adjustable Thermostatic Cooling Fan Switch (Radiator cooling fan radiator coolant sensor)
    · Breeze aluminum radiator fan shroud (EzePak Cool)
    · Breeze hinged upper radiator mount (EzePak Cool), rubber mounted
    · Breeze lower radiator mount (EzePak Cool)
    · Breeze lower radiator hose mounting bracket
    · Breeze top radiator cowl cover
    · Breeze stainless engine bay battery mount
    · Breeze ½” exhaust 4 into 4 wedge (PS)
    · Black Powder Coated engine bay, wheel well, and trunk aluminum
    · Snap-On Tools road/emergency tool kit
    · Battery Boost/Jump Start, Air Pump, Tire Repair emergency roadside kit
    · Safecraft Halon 1211 fire extinguisher, Stainless tank, cockpit
    · Safecraft Halon 1211 fire extinguisher, Stainless tank, trunk
    · Summit Racing aluminum billet fire extinguisher mount, cockpit
    · Summit Racing aluminum billet fire extinguisher mount, trunk
    · Vibration dampening clamps riveted to frame/panels for electrical harnesses
    · Removable DS foot box outer panels
    · Personalized California 1960 legacy license plates FAYK SNK, UNN REEL
    Suppliers and Services
    · Jeff Miller Customs (at the Bat-cave)
    · Breeze Automotive
    · Finish Line Accessories
    · Forte’s Parts Connection
    · Levy Racing
    · Replica Parts
    · Drummer Mike
    · Cobra Earl
    · Metco Motorsports
    · Whitby Motorcars
    · Alex’s AC Interiors
    · Vintage Air
    · Ron Francis Wiring
    · Herb Fraser Custom Door Panels
    · Amazon.com
    · McMaster-Carr
    · On-Line Metals
    · Advanced Keys
    · Aftermarket Suspension Parts
    · Summit Racing
    · Jeg’s
    · Speedway Motors
    · Pegasus Auto Racing
    · Speedhut
    · Powell Electronics
    · Appletree Automotive
    · Superbright LED’s
    · Earl’s Plumbing/ANPlumbing
    · D & D Performance
    · Crutchfield (stereo components)
    · Speed Dawg
    · Redline Goods
    · Wilwood Disc Brakes
    · Rogers Motors
    · Eddie Marine
    · Drive Shaft Pro, Gardena, CA
    · America’s Tire Co./Discount Tire Co.
    · Snap-On Tools
    · Harbor Freight Tools
    · Victor Machinery Exchange
    · Home Depot
    · Lowes
    · O’Reillys Auto Parts
    · NAPA Auto Parts
    · Laron, Kingman, AZ
    · Western Combustion Engineering, Wilmington, CA
    · Color Code Painting, Gardena, CA
    · Custom Metal Finishing, Gardena, CA
    · Verne’s Chrome Plating & Powder Coating, Gardena, CA
    · Automatic Welding, Gardena, CA
    That ought about do it. Pic's to follow.
  4. Thanks RBachman thanked for this post
    Likes RAMRobAZ, RBachman, rezell3d liked this post
  5. #3
    Part 3.... Pictures.
  6. Thanks mike8082 thanked for this post
    Likes mike8082 liked this post
  7. #4
    Part 4... More pictures.
  8. Thanks mike8082 thanked for this post
  9. #5
    Part 5... Still more pictures.
  10. Thanks mike8082 thanked for this post
  11. #6
    Part 6... And still more pictures.
  12. #7
    Part 7... The last part. And yet still more pictures. The end.
  13. #8
    Well done, Dan. It looks great. Can’t wait to go take a few laps around the peninsula.
    Love the color and all of your modifications.
    Congratulations.
  14. #9
    Jun 2018
    North Vancouver, BC, Canada
    great work!! Now enjoy!
  15. #10
    Great job. Enjoyed following along. Enjoy many happy miles.
  16. #11
    Congratulations Boat! Beautifully done. Nice machine.
  17. #12
    mburger's Avatar
    Punta Gorda FL
    Beautiful car!
    Mark
  18. #13
    Very well done! Enjoy it
    Chino Valley, Arizona
    Dan ~
    Beautifully crafted and lots of very nice quality detail touches. I really like the black accent pin stripe against your main colors. What did you cover your dash with?
    Just some incredible builds graduating lately, the bar just gets higher & higher!
    Hope you enjoy it, it never gets old...
  20. #15
    Beautiful car; well done! I love the license plate.
  21. #16
    Dan-
    She turned out beautifully! Congratulations on a really terrific build!
    I appreciated the way you laid out your graduation post with all the details outlined, and all the follow on pictures.
    Very nice job, and I know you will enjoy the heck out of her; well done!
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    Nicely done.
    Congrats and enjoy !!
  23. #18
    RJD's Avatar
    Northern Virginia
    Well done! What a fun and beautiful car to drive along the Pacific Coast Highway or up through wine country.
  24. #19
    Excellent Job & Very Well Done!
    Jealous, You Bet I Am!
    Congratulations!
  25. #20
    Thank you all very much. I'm honored, and humbled, because a lot of the ideas came from all of you. There are so many talented and helpful builders here that have contributed a lot to my build, again I say thank you. There is a lot of all of you and a lot of your ideas in this build. So pat yourselves on the back.
    Had the car out again today to a little car show at Golden Cove Center. It's a gas guzzler. I love it. Also, lots of waves and thumbs up.
    Boyd, pet the dog. (my old dog, my miracle dog, is getting near the end. She's going to break my heart. 10 years ago we were both hurting and we saved each other.)
    Chris, as I said, I didn't start the build, so the dash was one of those things that was already covered when I got it. I 'think' it's a patterned leather, or if it's vinyl, it's pretty darned good. So I'm not really sure...
    Dave, the plate is my second. I started with FAYK SNK, but decided on this one afterwards. Make's it a bit easier when asked "Is it real?"
    Steve (go Dad), Where is that Cajun Enthusiasm?
    I will have to get the car back up on jacks, since I found a crack in the PS side pipe. It looks to be about an inch long so I hope I can just get it repair welded. The adjustment phase has officially begun.
  26. #21
    Thought I would post some of those little things that make the build unique. Some of the items are copied from others, but changed or modified, and some are ideas that I came up with. Here goes... Part 1...
    1 -- The upper rear-view mirror mount. Didn't want to drill holes in the body, and the bent angle mount seemed incomplete. So made it out of angle, with a piece welded in to hide the hardware.
    2 -- Probably doesn't make that big of difference, but I didn't like the idea of the engine bay air (fumes) being pumped in by the heater blower. I made a shroud that gets it's air from the PS footbox. Here's the build thread on that https://thefactoryfiveforum.com/show...g-modification
    3 -- Needed a radiator screen that was strong, non restrictive, and filled the intake fully. I didn't like the look of a square screen, so I used the stainless mesh as a backup and the honeycomb Nomex as the face, and ran it laterally to the sides of the intake. Painted it black, and I really like the results. Fan never comes on with the car moving above about 20mph, so it's getting a lot of air flow. It doesn't look like it, but it's all removable. The upper and lower aluminum holds the honeycomb, and under that there are upper, lower, and side aluminum pieces that hold the stainless steel mesh. Nothing actually touches or sits on the radiator itself.
    4 -- Being such a small cockpit, needed some storage space. I made two pouches for the back cockpit bulkhead behind the seats, and two pouches for each side of the trans tunnel. They don't hold a lot, but every bit helps. Believe it or not, the trans tunnel top is still removable.
    Continued in Part 2
  27. #22
    Continued from Part 1....
    5 -- Needed some passenger grab handles, 'cause I didn't want the panic grab to be the windshield or the shifter (not that I would ever drive like that...) In addition, I made the top of the transmission tunnel, and the lower door sills removable.
    6 -- California wanted a back-up/reverse light. I really like how this came out. It's plenty bright.
    7 -- The old Mk IV license plate light vs. trunk handle latch interference problem. I did the Kleiner license plate light modification, which took care of about 65% of the problem. I didn't want to cut the license plate, so I had Professor DaBat build up the mounting pad on the trunk lid about 1/4 inch or so, to make up the rest of the clearance needed. Can't even tell it was changed, a perfect solution IMHO.
    8 -- The old side pipe hanger problem. It took me a month of thinking and pondering, but I came up with what I think, I hope, is a good solid fix. My hanger design is articulated on both ends with Heim joints, and allows the muffler to articulate and move in all directions, in-out, up-down, fwd-aft, yet still provides for upward support. A bonus is, it is somewhat adjustable. I have it set to provide about 20 pounds of lift. Time will tell if my design will hold up.
    9 -- For some reason, my headlight lenses were 'clocked' about 6 or 8 degrees counter-clockwise in the buckets on both sides. I don't know if it was the FFR guy who did the cutouts messed up, or the tabs on the LED headlights are off, or what, but it was bugging me. The options were to take the buckets out and re-drill them, or re-drill the body, or re-drill the holding ring, or do something about those wimpy clips. I ended up making new, stronger, clips that I drilled the holes off center to allow the headlight lens to rotate to perfectly aligned.
    There were dozens, maybe hundreds, more changes, modifications, additions, and fix's, but these are the one's that come to mind at the moment. Now take my ideas and make them better.
  28. #23
    Almost forgot... Since I'm tooting my horn here, might as well post pics of my emergency roadside tool kit. It's virtually all Snap-On hand tools, with a battery jump booster, tire inflater, tire patch kit, and Power-Probe analyzer. It's got to be the most expensive tool kit in the country that I hope will never have to be used. But if need be, I think I could disassemble nearly the entire car with this set. Well, a lot of it anyway.
  29. #24
    bobl's Avatar
    Spicewood, Texas
    Congratulations! Great looking build. Looking through your parts list is like a who's who of FFR upgrades.
  30. #25
    Sorry to hear about your miracle buddy. Amazing sometimes how we find the right one at the right time... or they find us. Pet the dog.
  31. #26
    Boat,
    Sorry for my lack of enthusiasm in my earlier congratulatory response.
    I was hanging side pipes yesterday in anticipation of my 2nd / 1st start and it took me all day to get them hanging right.
    So with the cat out of the bag all I can say is:
    Ayeee & Congratulations!
    Though I'm not of Cajun descent, Baby Geaux-Dad is a U.L.L. Ragin Cajun (2nd Year) studying Architecture.
    Again, please accept my apology for my previous lack luster, under the top, earlier response!
    Congratulation Again, But This One Is Coming From The Central Business District Of New Orleans!
  32. #27
    Copperhill, TN
    Beautiful build, go out and get some bugs on it ..... safe travels.
  33. #28
    BadAsp427's Avatar
    Greeneville, TN
    So I read and saved your post about the heater shroud. I agree and was planning to put a tube on the intake of the heater only to realize that it is sucking air from both ends and the shroud you made is exactly what I was thinking of trying to make... BUT, I was thinking of running the tubing out to the front to collect cold/fresh air. I checked out the heater valve (heater hose valve) and find that it cuts out 99.9% of water flow so that would mean that I could have cool fresh air coming into the cabin via the same ducts the heater uses.... Do you think that would work like that? I could even run the heater fan and not need an external fan. Am I missing something? Would you be willing to share your drawings/measurements for the shroud?
    Thanks for the beautiful car to aspire to...
    Carl
  34. #29
    Carl
    I have run the heater blower with the heater valve closed, and yes, it does move air around the knee area (where my vents are), but it's not what I would call cool air. It's probably a degree or two warmer than ambient just due to the fact that it is recycling the PS foot box air. I do have pretty good insulation in the footbox's with heat shields on the engine compartment side, and Lizard Skin and carpet on the cockpit side, so it's more of just a subtle fan. The fresh air blowers do seem to provide slightly cooler air, since they are ducted from the brake cooling ducts in the front. Nothing short of air conditioning will actually cool, but air movement helps when sitting in traffic. Moving along you can't even tell if the blowers are working.
    If you go the shroud route, here's a thread I did a while back on my blower mod and shroud fab. Also, make sure you leave enough room between the blower intakes and the interior of the shroud ALL around the blower motor in order to maximize airflow. https://thefactoryfiveforum.com/show...g-modification. I don't really have any plans or sketches for the shroud, I just started with some Cheerios box cardboard, and mocked up a version, and went from there. HTH...
  35. Thanks BadAsp427 thanked for this post
    Likes BadAsp427 liked this post
  36. #30
    On a roll Al_C's Avatar
    Wheaton, IL
    Looks great, Dan! Congratulations! I like your pouch ideas. I need to check this out further.
  37. #31
    Oct 2017
    Wow.
    Very nice attention to detail.
    Great looking build!
    Have fun driving that beauty.
  38. #32
    Very nice and congratulations. I really like the color scheme
  39. #33
    Senior Member Pat427's Avatar
    New Braunfels, TX
    I wanted to get your opinion on the Engine Factory. I'm considering the 427 from them and was hoping you could share your thoughts on it. Specifically, how do like driving around town with a 427? Any other thoughts would be much appreciated. And your car looks fantastic. Thanks, Pat
  40. #34
    Conesus, NY
    Great looking build. Congrats!!
    Chuck Krueger
    MK4 Kit - Picked up 4/5/14, Complete Kit, 3-Link, Wilwood upgrade, Coyote, TKO 500, First Start 7/25/15
    2000 C5
    2003 C5 Z06
    2007 C5 Z06
  41. #35
    Lost Wages, Nevada
    WOW . . . just WOW!! Congratulations . . . Beautiful car and the attention to detail is class A . . . now get the little things done and I'll see ya at next years Huntington Beach Cruise-In [events], right?
    Doc
  42. #36
    Member rick8928's Avatar
    Baltimore, MD
    Dan,
    Absolutely superb build: choices/mods/attention to detail/execution. first class! Were you by chance an airline pilot, where such attention to detail is mandatory? Enjoy the well earned driving.
    Rick
    Mk IV 7329, '04 Mach 1 donor, 3 link, FFR lowers, heater, Kirkey seats, seat heaters, CobraEarl vents, dual rollbars, 9/10.5 x 17 Halibrand replicas; Kumho Ecsta XS 255/315s, Lexus Indigo Ink Pearl/Artic White stripes, picked up 9/25/10, engine in 7/16/11, first start 3/9/12, go kart 3/18/12, first drive in primer 4/1/12, tags/title 4/16/12, paint 6/8/12, complete 7/24/12
  43. #37
    Quote Originally Posted by rick8928 View Post
    Dan,
    Rick
    Ahhhhh.... You found me out. 40 years at UA. 727, 737, DC8, DC10, 777, 747, 787. Also 20 years water ski racing -- Team 737, hence my forum name. I'll bet we crossed dirt paths back in the day up in the hills too. Here's a couple of pics of days gone by. (look hard in the first one...)
    Thanks Rick for the Atta-boys.
  44. #38
    cv2065's Avatar
    Beautiful car...Enjoy driving the hard work. You inspire me to get mine done!
  45. #39
    Thank you all out there for all the kind words. I have to say it was (still is in some aspects) fun to build, but man-oh-man, the real fun is in the driving.
  46. #40
    Nov 2018
    Chandler, AZ
    Wow, awesome build.
