These rugged, race proven cooling tubes are mandrel bent, with each end beaded to firmly grip the clamped hoses. They have been beautifully ceramic powder coated internally and externally for increased longevity. The come with custom fitted top quality hoses designed for the FFR Afco radiator and your engine application.
Their robust designs, developed from years of racing applications, combined with the beautiful ceramic powder coating have brought some customers to consider them “engine jewelry.”
They replace “one size fits all” corrugated hoses which can fracture while the rubber adapters can crack, leak, and slip off the radiator.
These cooling tube assemblies are a clean, custom fit, easy to install, and will provide you with years of worry free driving.
Cooling tube assemblies are available for the following engine installations:
#70706 - Upper Radiator and Tube Forward Kit for 302 or 351Windsor with Afco Radiator - Includes mandrel bent and beaded silver ceramic powder coated 1-1/2” OD steel tube into 1-1/2” ID coupler hoses. This kit replaces the corrugated tubing between your radiator filler T and the Afco radiator inlet.
#70690 - 302 or 351 Windsor upper to Afco Radiator with Filler Neck - 1-1/2” steel tube is beaded on each end. Pressure cap fitting is welded to the tube.
#70688 - Lower Radiator Hose and Tube Kit for 302 and 351 Windsor in Factory Five Roadster with Afco Raditor
302 and 351W Afco radiator lower
Click here to visit our website and order.
Boig Motorsports Parts
View our 818 Exhaust and Cooling Tubes!
View our Roadster, Type 65 Coupe, and Hot Rod Cooling Tubes!
View our Quiet Pipes Side Pipe Kits for Roadsters!
