Heck yeah...give it world...we will be watching this project
Jet
4-sure. Will be a jewel if you match or beat that picture.
Redding - great place to live. In 2007 I was out there several times installing radiology software at Advanced Imaging - when Dr. Hecht was building and opening his center. Took my wife along on the last trip to see the sights like your cool glass bridge. Next we went over the hill, stopped in Eureka (toking center of the world?), rode the "skunk train" and took in the Avenue of Giants, etc.
That looks really cool, and as you assess the side pieces may I suggest slope up and fallow the string hood lines and round off the forward corners....just like post 1
I could be wrong....but that's why we're here
Jet
Yeah but with your own spin....shallow grooves milled into the side walls will set it off.".just saying
Jet....
Nice work Bill!!!
Henry
Nice!
Nice job! I'll bet those carbs will thank you for that fresh air... Anthony
deleted.
Very impressive.
I need to learn how to do that.
Beautiful!
Very, very cool!
Excellent work! From what I can tell this is the engine setup I would do. Can you give more details on the engine and carb specs? Did you build the engine up yourself? I have built some Triumph and MG engines and would be a little lacking (OK...a lot lacking) in having any experience on what the best components would be for one of these thunderous engines. I know Webers and have good experience getting them to sing together, but the rest...ugh
Block is 90 roller block. 030 over, squared, and decked.
Crank is Scat forged steel stroker.
Probe industries forged I-beam rods, polished, full floating
Probe industries forged aluminum pistons for TW heads, domed, sides coated with Teflon
Probe industries lightweight steel wrist pins
Mains align honed
Everything balanced
Comp Cams Pro Magnum roller rockers
Hydraulic roller cam (.571/.587 lift, 112 LSA)
Aviad reproduction original oil pan
Weber 48 IDA carbs modified for low speed driving
Blue Thunder reproduction Weber manifold
Twisted Wedge aluminum heads (2.02/1.60, 65cc chambers)
Heads and intake manifold port matched and polished
Size 60 weber jets
Jim inglese fuel/water inlet with correct hoses and clamps
Stamped steel valve covers modified to original look
Period correct breather caps and decals
I have a total of $14,045 in the engine alone. Yes, I built the engine myself.
These specs are pretty much what I am looking to do for my Daytona Coupe. Have you had this on the dyno? I'm guessing something in the 425 Hp range? The step by step on the air box is very helpful too as I will at some point be fabricating one.
