Thanks Thanks:  217
Likes Likes:  445
Page 5 of 15 FirstFirst ... 34567 ... LastLast
Results 161 to 200 of 574
Thread: Fmans Dart 427 build #9818 - 14" Leather steering wheel
  1. #161
    Senior Member Fman's Avatar
    Jan 2020
    State of Jefferson
    The clutch pedal stop is nice too, is that a hardware store item?
    It is a hood stop for a Camaro and I used a 2 1/16" circular hole saw to cut the backing plate from 1/8" aluminum. The backside of the hood stop has a nut on it as well.
  2. Thanks GTBradley thanked for this post
    Likes JB in NOVA, nucjd19 liked this post
  3. #162
    TMartinLVNV's Avatar
    Jun 2019
    Las Vegas, NV
    Looks great Fman. Fantastic work!
  4. Thanks Fman thanked for this post
  5. #163
    Jan 2020
    State of Jefferson
    Quote Originally Posted by TMartinLVNV View Post
    Terry, thank you... I have been referencing your build thread (and many others) to help me out. I am starting the wiring now, I have to admit I am a little intimidated by the entire wiring process. There seems to be quite a few guys adding more fuse panels, relays, grounding blocks, etc. to what FFR sends with the car trying to keep it as simple as possible. I am still awaiting my engine completion and until my engine is installed have come to a little bit of hault in the build process. If you or anyone else does have any tips on wiring please post it up!
  6. #164
    Jun 2019
    Las Vegas, NV
    Are you using the autometer or classic gauges?
    I really like my extra fuse box. It is only hot with the key in the on position. That way, if I leave my seat heaters on, USB acc plugged in, or cruise control on when I shut off the car, no power will be drained from the battery when off.
  7. #165
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Nice work on the clutch stop! I don't know yet if I'll need one but I had a similar idea using a swiveling leveling foot from McMaster but the hood stop is brilliant.
  8. Thanks Fman thanked for this post
  9. #166
    Jan 2020
    State of Jefferson
    I am using the classic gauges, also planning on using the RF battery switch. I will have to read over your build thread to take a look at what you ended up doing, sounds like a good setup!
  10. #167
    Jan 2020
    State of Jefferson
    I was able to spend a couple days working with my dad on the build, these are some special times, I really enjoy working with him on the car. I can't wait for him to take this car for a rip someday!
    I gave him rivet duty and he did the entire cockpit area, he is now a certified pro rivet master! he did such a good job I told him he could come back and hit the trunk later on in the build
    His finished product...
    We also were able to get the HF 2 ton hoist put together
    Speaking of engines, I got a few pics from my engine builder today... the Dart 427 is starting to come to life!
  11. Likes JohnK liked this post
  12. #168
    Jan 2020
    State of Jefferson
    Footbox vent - budget build
    Visit this page for fresh air vent change (hose and coupling)
    https://thefactoryfiveforum.com/show...-change/page11
    One other task I was able to accomplish was installing my footbox vents. I want to thank silver_pilate for giving me all the information to duplicate his system, it is mucho appreciated! He has been using this setup for awhile now with good results, you can get all of these items for around $120 all in. It is simple but seems like it is going to work great.
    The only part I still need is some type of hose cushion clamp for a 3" hose, still searching around for something to hold them in place. I used some zip ties to temporarily hold them up.
    Here is a link to all the parts:
    Stainless duct clamps:
    Blast gate:
    Attwood bilge blower:
    20' RV sewer hose:
    EDIT: NOT USING THIS HOSE ANYMORE
    https://www.ebay.com/itm/201997860428
    Went to this stuff: Insulated and much better.
    I also used a couple small stainless buttonhead bolts with nylock nuts in each blast gate to hold them on (2 on each gate).
    Drivers side
    Blast gate, I ended up reversing the lever so it was on the same side as the set screw. It is very easy to open and close the vents. You do need to manually open and close them, there is no cable on them but that could be added very easily if desired.
    Passenger side
    I was also able to get my elephant ears rivnuted to the F panel and cut the hole for the 3" footbox vent line.
    A very productive week, I am reaching a point where I need my engine to move forward. I will be holding off on fuel lines, regulator, electrical grommet holes in firewall until my engine is installed and I can get a good visual on where I would like everything to go.
  13. Thanks toadster thanked for this post
    Likes toadster liked this post
  14. #169
    Jun 2019
    Las Vegas, NV
    If you choose to use a secondary "key on" fuse box, this is how I wired mine (with assistance of BigBlocker).
    10 gauge wire with a 40 amp inline fuse going from the battery to under the dash near the regular fuse box. My 6 bay aux fuse box is mounted adjacent to the regular fuse box. 10 gauge ground wire to the frame.
    The two 10 gauge wires going to a 50 amp rated relay. Relay wired to be closed** until activated by brown radio power wire in the "Radio/Heater/Wiper" bundle which is keyed on.
    I have my cruise control (10 amp), two seat heaters (10 amps each) and USB (minimal amps) wired to the aux fuse box. I still have two bays in the aux box open with probably about 15 amps of capacity left. I think when I looked at a wiring amperage chart, the 10 gauge wire was actually good for 50 amps for the length that I ran even though I put a 40 amp fuse inline.
    I actually have third 4 bay fuse box that is HAAT that I use just for my dash clock that I added. I can use it for radio memory as well if I ever decide to put one in.
    **I used the wrong term in the above description above. I actually wired the relay to be "open" (electrons not flowing) until the key is on. That way if i leave something on, it will not kill be battery with the key off.
    Car hasn't burned down yet
  15. Thanks Fman thanked for this post
    Likes Fman, toadster liked this post
  16. #170
    Folsom, CA
    Stainless duct clamps: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Blast gate: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Attwood bilge blower: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    20' RV sewer hose: https://www.ebay.com/itm/201997860428
    WOW looks amazing Travis! Great work by your dad too!!!
    I'm tossing around the idea of those footbox vents, seems like a no brainer for $120!
    assuming those you have to manually reach down and open/close them?
    Todd
  17. #171
    Jan 2020
    State of Jefferson
    Hey thanks! yes they are a manual open and close gate. You could add some type ofcable to attach to the gate which would not be hard to do. I figure I will more than likely always leave them open during spring/summer and close them during the cooler months.
  18. #172
    Aug 2019
    Spokane, WA
    Great progress, Fman! Hard to believe you've only had your kit for ~4 months. Very cool! I'm a bit jealous as I wait for mine to arrive.
    I took a note on your foot box vents. Climate is a bit cooler up here in Spokane, but we surely have our hot days in July-Aug. I'm still following along. Keep up the great work.
  19. Thanks Fman thanked for this post
    Likes Fman liked this post
  20. #173
    May 2020
    Stewart Trans will be here tomorrow yea
    Your thread has been so helpful with great ideas and lots of pictures along with email address of suppliers in getting prepared. Thank You Travis
    Hope GrassValley gets your power done soon. Looks like a beefy lower end.
    DaveThanks
  21. Thanks Fman thanked for this post
  22. #174
    Jan 2020
    State of Jefferson
    Glad my posts are giving some people a few ideas, most have been taken from other builders on this forum. I am also currently doing the same following other build threads trying to figuring this car out. Currently starting to plan out my wiring, just starting to look over the wiring schematic... good times ahead
    v1-vr and 460.465USMC looking forward to seeing your builds...
  23. #175
    Jan 2020
    State of Jefferson
    Slow week... did get a little more electrical work done and ran rear harness, wired ignition switch and also installed my Aeromotive stealth in tank fuel pump and ran my first short line of Fragola PTFE steel braided line. I did get a few more engine pics from my builder he passed along, slowly coming together.
  24. Likes toadster liked this post
  25. #176
    Jan 2020
    State of Jefferson
    Fragola fuel line/Aeromotive install complete
    Hope everyone is doing well and staying safe, California is having a terrible fire season, work has been ridiculously busy and the air quality has been the worse I have ever seen.
    This week I was able to make a little more progress on my build, I completed my Fragola PTFE fuel lines, Aeromotive pump, filter and pressure regulator install. I chose to run Fragola 3/8" PTFE lines the entire run with no hard lines. The Fragola line is very strong and durable, not expecting any issues with it more than likely this stuff will be around long after I am gone. I also found a local label shop to make some labels for my CNC triple reservoir and added a vent cap to my diff breather line.
    My next hurdle is wiring, I have run front and rear harness, completed my gauge wiring harness and am starting to move into the IDIDIT and RT turn signal. My engine is just about done, we are waiting on some serpentine pulleys/PS pump from Levy Racing to arrive. Hopefully by end of next week my builder will be able to finish it up.
    3/8" Fragola lines with Aeromotive pressure regulator
    Nothing fancy here, definitely not the most glamorous fuel line run but hopefully functional
    Aeromotive 10 micron fuel filter, Aeromotive stealth fuel pump
    CNC Triple with alum labels installed
    Vent line cap, $6 and good to go.
    https://www.amazon.com/Dorman-924-28...0144137&sr=8-1
    Here is my next wiring venture, thanks again to Paul and Dave for the information on these items, now I have a much better idea of what I need to do.
  26. #177
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Nice work on the fuel lines. They look great! You must be excited to get the engine. It looks like it's coming together very nicely.
  27. Thanks Fman thanked for this post
  28. #178
    Senior Member JB in NOVA's Avatar
    Apr 2020
    Virginia
    Looking good! Nice work on the fuel lines.
  29. Thanks Fman thanked for this post
  30. #179
    Jan 2020
    State of Jefferson
    Thank you John, nothing near as nice as what you are putting together your SS lines look amazing!
    The wiring is going to be my biggest challenge with this build, feel very fortunate to have the more experienced builders here for help!
  31. #180
    Jul 2020
    Birmingham, AL
    I have spent the last hour or so between work catching up on your thread. First let me say just amazing work. Your powder coat is beautiful and your attention to detail is impressive. I have already earmarked your clutch stop and air vents for my build ( 11/14 finish date ). Thanks for the detailed explanations and links
  32. Thanks Fman thanked for this post
  33. #181
    Jan 2020
    State of Jefferson
    Quote Originally Posted by nucjd19 View Post
    Thank you, I am a newbie just learning myself learning as I go. As I have mentioned before just about everything in my build thread has been taken from some other builder on this forum. Maybe my claim to fame will be my $3 clutch stop
    I hope my thread helps you along your journey and congratulations on your order!
  34. #182
    Jan 2020
    State of Jefferson
    I was able to spend a little more time today wiring up the IDIDIT relay, RT turn signal, and started running my accessory wires. I definitely will be picking up a grounding bar, can see that will be needed. I have most of the "core" wiring hooked up, if it actually works TBD when I put a battery on the car.
    RT and IDIDIT important info, I was having problems figuring out the wiring for the IDIDIT relay, and RT turn signal and the host of other wires coming from the dash harness. Edwardb and Papa gave me a lifeline and explained how the wiring works along with what switches RT and IDIDIT were replacing. I wanted to post up EdwardB's reply so it is in my build thread for others to use down the road. I can guarantee in a few months I won't remember how to do it again I really can't thank them enough, would have been stuck without there feedback!
    "Exactly. Nearly everything is in the RF chassis wiring harness schematic.
    - The three turn signal wires on Russ's assembly replace the turn signal switch in the RF schematic. Wired exactly as pictured there. The grey feed wire is attached to the common lead. The dark green (left) and light blue (right) to the appropriate other two wires.
    - Assuming you want the button on the end of the turn signal stalk to do the high/low beams, there are the two wires from the switch out of Russ's assembly. One goes to ididit switch tan wire. The other to ground. Doesn't matter which. Pushing the button grounds the tan wire and switches the ididit switch.
    - For the actual high and low headlight wiring, the iditit switch replaces the dimmer switch in the RF schematic. Wire exactly as pictured there using the purple, green and yellow wires from the ididit switch. You just need to add +12V battery power and ground for the ididit switch. You did get the instructions that came with it, right? Shows and explains pretty clearly. Just got that piece for my new build and it seems exactly suited to our needs. Much simpler than putting together the circuit yourself like the schematics that came with your RT turn signal assembly. And does the same thing, e.g. high/low beam switch plus flash to pass.
    From TedG's build a very nice wiring schematic to simplify the IDIDIT/RT turn signal wiring. Thanks Ted!
    Here is a pic of the IDIDIT relay, RT turn signal and accessory bundle from the RF dash harness
    The rats nest of wires forming behind my dash, I am going to hold off on housekeeping until I confirm everything is working properly. I am 96.4% confident I did everything right....
    Started to pull my footbox blower wires through along with the accessorie bundle from RF harness. I am going to be using the heater, wiper, and radio hot wires to power my heated seats, USB charger and footbox vents.
  35. Thanks Ted G thanked for this post
    Likes toadster, Ted G liked this post
  36. #183
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Hey Travis, thanks for posting the question about the Ididit relay. I'm a bit behind you but I'm planning to use that same Ididit relay with the RT turn signal so I'm very thankful that you've documented the wiring of that.
  37. Likes Fman, toadster liked this post
  38. #184
    Jan 2020
    State of Jefferson
    Engine has arrived!
    I was able to pick up my engine today along with my tk0600 and QT bellhousing. The engine has a few bolt on items remaining to be completed which I will take care of myself. Unfortunately after I got home and was looking over the engine I noticed the oil pan is 8" deep which I think is not going to work and hang down below the frame rail. I am a little bummed about this because I requested a 7.5" deep oil pan. Not a huge deal but a little bit of a buzz kill of the hype of the new engine.... Oh well, things happen and we will have to switch it out. If anyone has a link for a good 7.5" pan please send it my way, I found a Moroso 20534 that I think will get the job done.
    I was also able to get my tko600 tailshaft cut off and started coming up with a game plan for mating up the TKO an QT BH. My engine builder already spec'd everything for me and installed my clutch, he said just bolt it together and should be good to go. The clutch fork is the only thing I have to do some more research on, I believe it needs to be at 90 degress with BH attached to the engine and TOB touching clutch? Maybe someone could confirm this is how I should do it? It seems pretty straight forward but definitely want to make sure I do this correctly.
    Here is the Dart 427 with the Edelbrock Pro Flo 4
    Here is the Canton oil pan at 8" deep, I ran a level on it and it definitely looks too low to me...... bumma! my engine builder wants me to install everything and see where everything lands. He said he would install another pan later on if needed.
    Tko tailshaft cut down, I ended up using a sawzall to cut it
    Looks like another trip to Ace, these bolts that were sent with my transmission mounts are not even close to being long enough. Not quite sure what they were thinking on this one? EDIT: these short two bolts are for the underside of the mount, the two longer bolts that attach to the transmission do not come with the mounts.
  39. #185
    Jan 2020
    State of Jefferson
    Couple other little items, I was able to get my grounding bar installed which helped clean up a little more wiring.
    Here is the link for the grounding bar:
    IDIDIT relay is also mounted to firewall now temporarily held up with some heavy duty velcro. Will add a couple stainless bolts later on, better having it tucked out of the way to clear up some space behind the dash.
    Mike Fortes hydraulic clutch setup
  40. Likes toadster, Ted G liked this post
  41. #186
    Sep 2019
    Bothell, WA
    I purchased this one for my ford racing 427. It fits perfect and I hear these guys built the original cobra pans.. It is part number 155-55356
    http://aviaid.com/shopsite_sc/store/.../155-55356.gif
  42. Thanks Fman thanked for this post
  43. #187
    Jan 2020
    State of Jefferson
    Engine installed
    Today was a fun day, I want to thank Dave (V1-Vr) and my dad for helping me get the engine installed. Also want give a shout out to Elliott at Mustang Corral and Gordon (Levy Racing) for giving me phone a friend to make sure everything was done properly.
    Overall a few small challenges but in the end everything went great! Still have plenty of items to take care of but slowly getting closer to my first start!
    We made sure engine was leveled before tightening down motor mounts
  44. Likes egchewy79, toadster liked this post
  45. #188
    Apr 2020
    Virginia
    Nice! It looks great. Looking forward to your first start.
  46. Thanks Fman thanked for this post
  47. #189
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Congratulations on getting the engine in. Looks great!
  48. Thanks Fman thanked for this post
  49. #190
    Jan 2020
    State of Jefferson
    Thanks fellas, it definitely is nice to have her in the cradle. The harbor freight load leveler worked fine other than the crappy plastic handle they use on it. That handle is a joke, needs to be replaced with a metal handle that can sustain the force of turning the handle. The two ton engine hoist worked great.
    I have a long punch list of items to still take care of but starting to see the light.
  50. #191
    Aug 2019
    Spokane, WA
    Sweet! Great milestone reached. That motor looks like it's begging to roar to life. Keep up the great work.
  51. Thanks Fman thanked for this post
  52. #192
    Feb 2020
    Chicago
    Motor looks good there at home!
  53. Thanks Fman thanked for this post
  54. #193
    Jun 2019
    Las Vegas, NV
    Fman, that thing is going to be a beast. My little baby 347 scares me. I can't imagine driving a car with the power that yours will have. Your engine bling choices all came together really well. Everything compliments each other without look gaudy. I am happy with my Holley Sniper, but I do sometimes think about the Edelbrock multiport FI setup. It seems to be a great setup from all of the reviews that I have read.
  55. #194
    Jan 2020
    State of Jefferson
    Terry, thank you I appreciate the motivating words... so far everything is slowly coming together. The engine cam on this 427 is on the mild side but still right around 480-500 HP. I am hoping the Pro Flo 4 will live up to the feedback I got from a few guys running it who all seem to really like the setup. Time will tell, I will definitely give a full report on how the pro flo 4 ends up working out.
  56. #195
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    Engine looks fantastic! Congrats on this milestone. I am also interested in how the Pro Flo 4 performs for you. From reading, it seems like a great solution.
    Kyle
  57. Thanks Fman thanked for this post
  58. #196
    Jan 2020
    State of Jefferson
    Forte stuff, Jones Racing PS pump, serpentine
    Chipping away at my punch list, still lots to do but checked off a few more items. I was able to get my serpentine belt system installed with Alternator and Jones Racing PS pump. Still waiting for the lines to arrive but everything is mounted. I was also able to get Fortes throttle linkage installed and hydraulic clutch set up. Still have to fill and bleed the system but everything is mounted and ready to go.
    If anyone notices any issues please red flag them for me. Everything I installed pretty much has no directions other than pics I could find online.
    Serpentine belt system all set up. The Jones PS pump comes with a cooler and remote reservoir which I installed. This complete serpentine system can be purchased from Gordon Levy, he has been excellent to work with.
    http://lrclassicsllc.com/
    Forte's throttle linkage, everything seems buttery smooth
    https://fortesparts.com/product/mech...e-linkage-kit/
    Forte's hydraulic clutch setup - I ended up allowing 3/16" clearance between the TOB and clutch pressure plate diaphragm springs, this is what Forte recommended.
    https://fortesparts.com/?s=hydraulic+clutch+kit
  59. #197
    Sep 2020
    great job you are doing on your kit. It's wonderful to know there are so many Cobras close to where I live in Petaluma. Hoping to get one going my self. Searching for a place to build one. A question I have, pardon me but I see these copper sleeved studs sticking out of the sheet metal, what are they?
  60. #198
    Maumee, OH
    Do yourself a favor. In order to make sure you have the clutch actuator rod cut to the right length, get in and push the clutch pedal all the way to the floor. Make sure the piston stays inside the housing and none of the O-rings are visible. It can lead to rides on a rollback. Ask me how I know.
    Scott
    Built FFR9457. 351 Windsor, TKO600, 3.73. Fitech EFI. Russ Thompson throttle pedal, turn signal, and trunk pan. Carbon Fiber dash with Speedhut Revolution gauges. Paint by Jeff Kleiner.
  61. #199
    Jan 2020
    State of Jefferson
    Quote Originally Posted by mark jones View Post
    Thank you, as you probably can tell I am learning as I go. This forum has been a huge help for me, first time I have ever tackled this big of a project before.
    The coppered sleeved studs you are referring to are called Clecos, they are basically a temporarily rivet that can be removed and installed instantly. A must have to build one of these cars, I have used them countless times throughout this build.
  62. #200
    Jan 2020
    State of Jefferson
    Quote Originally Posted by Sdonnel View Post
    Scott
    Scott, are you referring to the master or slave cylinder? I am assuming this can only be done after the system has been bled out? Do you have a clutch stop installed on your build? How far forward should the slave arm move for full clutch engagement?
