08-26-2020, 10:40 PM
#161
Originally Posted by
GTBradley
The clutch pedal stop is nice too, is that a hardware store item?
It is a hood stop for a Camaro and I used a 2 1/16" circular hole saw to cut the backing plate from 1/8" aluminum. The backside of the hood stop has a nut on it as well.
Post Thanks / Like - 1 Thanks, 2 Likes
08-26-2020, 11:38 PM
#162
Looks great Fman. Fantastic work!
Fman thanked for this post
08-27-2020, 09:25 AM
#163
TMartinLVNV
Terry, thank you... I have been referencing your build thread (and many others) to help me out. I am starting the wiring now, I have to admit I am a little intimidated by the entire wiring process. There seems to be quite a few guys adding more fuse panels, relays, grounding blocks, etc. to what FFR sends with the car trying to keep it as simple as possible. I am still awaiting my engine completion and until my engine is installed have come to a little bit of hault in the build process. If you or anyone else does have any tips on wiring please post it up!
08-27-2020, 11:09 AM
#164
Are you using the autometer or classic gauges?
I really like my extra fuse box. It is only hot with the key in the on position. That way, if I leave my seat heaters on, USB acc plugged in, or cruise control on when I shut off the car, no power will be drained from the battery when off.
08-27-2020, 11:21 AM
#165
Nice work on the clutch stop! I don't know yet if I'll need one but I had a similar idea using a swiveling leveling foot from McMaster but the hood stop is brilliant.
MkIV Roadster build: Gen 2 Coyote, IRS, TKO600. Ordered 10/24/18. Delivered 1/29/19. Engine installed 8/8/21. First start 9/12/21. First go-kart 9/17/21. Off to paint 4/11/22. Back from paint 12/30/22.
Build thread here.
08-27-2020, 10:38 PM
#166
TMartinLVNV
I am using the classic gauges, also planning on using the RF battery switch. I will have to read over your build thread to take a look at what you ended up doing, sounds like a good setup!
08-27-2020, 11:00 PM
#167
08-27-2020, 11:20 PM
#168
Post Thanks / Like - 1 Thanks, 1 Likes
08-28-2020, 11:30 AM
#169
Fman
If you choose to use a secondary "key on" fuse box, this is how I wired mine (with assistance of BigBlocker).
10 gauge wire with a 40 amp inline fuse going from the battery to under the dash near the regular fuse box. My 6 bay aux fuse box is mounted adjacent to the regular fuse box. 10 gauge ground wire to the frame.
The two 10 gauge wires going to a 50 amp rated relay. Relay wired to be closed** until activated by brown radio power wire in the "Radio/Heater/Wiper" bundle which is keyed on.
I have my cruise control (10 amp), two seat heaters (10 amps each) and USB (minimal amps) wired to the aux fuse box. I still have two bays in the aux box open with probably about 15 amps of capacity left. I think when I looked at a wiring amperage chart, the 10 gauge wire was actually good for 50 amps for the length that I ran even though I put a 40 amp fuse inline.
I actually have third 4 bay fuse box that is HAAT that I use just for my dash clock that I added. I can use it for radio memory as well if I ever decide to put one in.
**I used the wrong term in the above description above. I actually wired the relay to be "open" (electrons not flowing) until the key is on. That way if i leave something on, it will not kill be battery with the key off.
Car hasn't burned down yet
08-28-2020, 05:59 PM
#170
25th Anniversary #9772
Fman
One other task I was able to accomplish was installing my footbox vents. I want to thank silver_pilate for giving me all the information to duplicate his system, it is mucho appreciated! He has been using this setup for awhile now with good results, you can get all of these items for around $120 all in. It is simple but seems like it is going to work great.
The only part I still need is some type of hose cushion clamp for a 3" hose, still searching around for something to hold them in place. I used some zip ties to temporarily hold them up.
Here is a link to all the parts:
Stainless duct clamps:
Blast gate:
Attwood bilge blower:
20' RV sewer hose:
https://www.ebay.com/itm/201997860428
I also used a couple small stainless buttonhead bolts with nylock nuts in each blast gate to hold them on (2 on each gate).
A very productive week, I am reaching a point where I need my engine to move forward. I will be holding off on fuel lines, regulator, electrical grommet holes in firewall until my engine is installed and I can get a good visual on where I would like everything to go.
WOW looks amazing Travis! Great work by your dad too!!!
I'm tossing around the idea of those footbox vents, seems like a no brainer for $120!
assuming those you have to manually reach down and open/close them?
08-28-2020, 09:35 PM
#171
toadster
Hey thanks! yes they are a manual open and close gate. You could add some type ofcable to attach to the gate which would not be hard to do. I figure I will more than likely always leave them open during spring/summer and close them during the cooler months.
08-28-2020, 10:26 PM
#172
Great progress, Fman! Hard to believe you've only had your kit for ~4 months. Very cool! I'm a bit jealous as I wait for mine to arrive.
I took a note on your foot box vents. Climate is a bit cooler up here in Spokane, but we surely have our hot days in July-Aug. I'm still following along. Keep up the great work.
Coupe complete kit. Index. Delivered: 4/22/24.
Build Thread. Coyote Gen 4X. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
MK4 Complete kit.
Build Thread Index. Delivered: 10/15/2020. Legal: 7/25/23. Coyote Gen3. TKO600 (0.64 OD). IRS w/3.55. PS. Wilwoods. Sway bars. This build is dedicated to my son, Benjamin.
Build Thread.
Fman liked this post
08-29-2020, 10:10 AM
#173
Stewart Trans will be here tomorrow yea
Your thread has been so helpful with great ideas and lots of pictures along with email address of suppliers in getting prepared. Thank You Travis
Hope GrassValley gets your power done soon. Looks like a beefy lower end.
DaveThanks
08-29-2020, 04:17 PM
#174
Glad my posts are giving some people a few ideas, most have been taken from other builders on this forum. I am also currently doing the same following other build threads trying to figuring this car out. Currently starting to plan out my wiring, just starting to look over the wiring schematic... good times ahead
v1-vr and 460.465USMC looking forward to seeing your builds...
09-03-2020, 10:31 PM
#175
09-14-2020, 11:35 PM
#176
Fragola fuel line/Aeromotive install complete
Hope everyone is doing well and staying safe, California is having a terrible fire season, work has been ridiculously busy and the air quality has been the worse I have ever seen.
This week I was able to make a little more progress on my build, I completed my Fragola PTFE fuel lines, Aeromotive pump, filter and pressure regulator install. I chose to run Fragola 3/8" PTFE lines the entire run with no hard lines. The Fragola line is very strong and durable, not expecting any issues with it more than likely this stuff will be around long after I am gone. I also found a local label shop to make some labels for my CNC triple reservoir and added a vent cap to my diff breather line.
My next hurdle is wiring, I have run front and rear harness, completed my gauge wiring harness and am starting to move into the IDIDIT and RT turn signal. My engine is just about done, we are waiting on some serpentine pulleys/PS pump from Levy Racing to arrive. Hopefully by end of next week my builder will be able to finish it up.
3/8" Fragola lines with Aeromotive pressure regulator
Nothing fancy here, definitely not the most glamorous fuel line run but hopefully functional
Aeromotive 10 micron fuel filter, Aeromotive stealth fuel pump
CNC Triple with alum labels installed
Vent line cap, $6 and good to go.
https://www.amazon.com/Dorman-924-28...0144137&sr=8-1
Here is my next wiring venture, thanks again to Paul and Dave for the information on these items, now I have a much better idea of what I need to do.
09-14-2020, 11:44 PM
#177
Nice work on the fuel lines. They look great! You must be excited to get the engine. It looks like it's coming together very nicely.
Build thread here.
09-15-2020, 06:56 AM
#178
Looking good! Nice work on the fuel lines.
MKIV Complete Kit #9822 l BluePrint 347 EFI l TKO600 l Power Steering l Heater/Defrost l
09-15-2020, 09:20 AM
#179
JohnK
Thank you John, nothing near as nice as what you are putting together your SS lines look amazing!
The wiring is going to be my biggest challenge with this build, feel very fortunate to have the more experienced builders here for help!
09-15-2020, 05:05 PM
#180
I have spent the last hour or so between work catching up on your thread. First let me say just amazing work. Your powder coat is beautiful and your attention to detail is impressive. I have already earmarked your clutch stop and air vents for my build ( 11/14 finish date ). Thanks for the detailed explanations and links
09-15-2020, 10:11 PM
#181
nucjd19
Thank you, I am a newbie just learning myself learning as I go. As I have mentioned before just about everything in my build thread has been taken from some other builder on this forum. Maybe my claim to fame will be my $3 clutch stop
I hope my thread helps you along your journey and congratulations on your order!
09-15-2020, 10:31 PM
#182
I was able to spend a little more time today wiring up the IDIDIT relay, RT turn signal, and started running my accessory wires. I definitely will be picking up a grounding bar, can see that will be needed. I have most of the "core" wiring hooked up, if it actually works TBD when I put a battery on the car.
RT and IDIDIT important info, I was having problems figuring out the wiring for the IDIDIT relay, and RT turn signal and the host of other wires coming from the dash harness. Edwardb and Papa gave me a lifeline and explained how the wiring works along with what switches RT and IDIDIT were replacing. I wanted to post up EdwardB's reply so it is in my build thread for others to use down the road. I can guarantee in a few months I won't remember how to do it again
I really can't thank them enough, would have been stuck without there feedback!
"Exactly. Nearly everything is in the RF chassis wiring harness schematic.
- The three turn signal wires on Russ's assembly replace the turn signal switch in the RF schematic. Wired exactly as pictured there. The grey feed wire is attached to the common lead. The dark green (left) and light blue (right) to the appropriate other two wires.
- Assuming you want the button on the end of the turn signal stalk to do the high/low beams, there are the two wires from the switch out of Russ's assembly. One goes to ididit switch tan wire. The other to ground. Doesn't matter which. Pushing the button grounds the tan wire and switches the ididit switch.
- For the actual high and low headlight wiring, the iditit switch replaces the dimmer switch in the RF schematic. Wire exactly as pictured there using the purple, green and yellow wires from the ididit switch. You just need to add +12V battery power and ground for the ididit switch. You did get the instructions that came with it, right? Shows and explains pretty clearly. Just got that piece for my new build and it seems exactly suited to our needs. Much simpler than putting together the circuit yourself like the schematics that came with your RT turn signal assembly. And does the same thing, e.g. high/low beam switch plus flash to pass.
From TedG's build a very nice wiring schematic to simplify the IDIDIT/RT turn signal wiring. Thanks Ted!
Here is a pic of the IDIDIT relay, RT turn signal and accessory bundle from the RF dash harness
The rats nest of wires forming behind my dash, I am going to hold off on housekeeping until I confirm everything is working properly. I am 96.4% confident I did everything right....
Started to pull my footbox blower wires through along with the accessorie bundle from RF harness. I am going to be using the heater, wiper, and radio hot wires to power my heated seats, USB charger and footbox vents.
Ted G thanked for this post
09-15-2020, 10:36 PM
#183
Hey Travis, thanks for posting the question about the Ididit relay. I'm a bit behind you but I'm planning to use that same Ididit relay with the RT turn signal so I'm very thankful that you've documented the wiring of that.
Build thread here.
09-26-2020, 09:49 PM
#184
09-26-2020, 10:02 PM
#185
09-26-2020, 11:04 PM
#186
I purchased this one for my ford racing 427. It fits perfect and I hear these guys built the original cobra pans.. It is part number 155-55356
http://aviaid.com/shopsite_sc/store/.../155-55356.gif
10-01-2020, 11:29 PM
#187
10-02-2020, 06:26 AM
#188
Nice! It looks great. Looking forward to your first start.
10-02-2020, 09:47 AM
#189
Congratulations on getting the engine in. Looks great!
Build thread here.
10-02-2020, 11:05 AM
#190
Thanks fellas, it definitely is nice to have her in the cradle. The harbor freight load leveler worked fine other than the crappy plastic handle they use on it. That handle is a joke, needs to be replaced with a metal handle that can sustain the force of turning the handle. The two ton engine hoist worked great.
I have a long punch list of items to still take care of but starting to see the light.
10-03-2020, 10:13 AM
#191
Sweet! Great milestone reached. That motor looks like it's begging to roar to life. Keep up the great work.
MK4 Complete kit.
Build Thread.
10-03-2020, 10:32 AM
#192
Motor looks good there at home!
10-04-2020, 10:53 AM
#193
Fman, that thing is going to be a beast. My little baby 347 scares me. I can't imagine driving a car with the power that yours will have. Your engine bling choices all came together really well. Everything compliments each other without look gaudy. I am happy with my Holley Sniper, but I do sometimes think about the Edelbrock multiport FI setup. It seems to be a great setup from all of the reviews that I have read.
10-04-2020, 11:09 PM
#194
TMartinLVNV
Terry, thank you I appreciate the motivating words... so far everything is slowly coming together. The engine cam on this 427 is on the mild side but still right around 480-500 HP. I am hoping the Pro Flo 4 will live up to the feedback I got from a few guys running it who all seem to really like the setup. Time will tell, I will definitely give a full report on how the pro flo 4 ends up working out.
10-05-2020, 07:21 AM
#195
Engine looks fantastic! Congrats on this milestone. I am also interested in how the Pro Flo 4 performs for you. From reading, it seems like a great solution.
Kyle
10-08-2020, 10:33 PM
#196
10-09-2020, 01:19 PM
#197
great job you are doing on your kit. It's wonderful to know there are so many Cobras close to where I live in Petaluma. Hoping to get one going my self. Searching for a place to build one. A question I have, pardon me but I see these copper sleeved studs sticking out of the sheet metal, what are they?
10-09-2020, 01:24 PM
#198
Do yourself a favor. In order to make sure you have the clutch actuator rod cut to the right length, get in and push the clutch pedal all the way to the floor. Make sure the piston stays inside the housing and none of the O-rings are visible. It can lead to rides on a rollback. Ask me how I know.
Scott
Built FFR9457. 351 Windsor, TKO600, 3.73. Fitech EFI. Russ Thompson throttle pedal, turn signal, and trunk pan. Carbon Fiber dash with Speedhut Revolution gauges. Paint by Jeff Kleiner.
10-09-2020, 03:58 PM
#199
mark jones
Thank you, as you probably can tell I am learning as I go. This forum has been a huge help for me, first time I have ever tackled this big of a project before.
The coppered sleeved studs you are referring to are called Clecos, they are basically a temporarily rivet that can be removed and installed instantly. A must have to build one of these cars, I have used them countless times throughout this build.
10-09-2020, 03:59 PM
#200
Sdonnel
Scott
Scott, are you referring to the master or slave cylinder? I am assuming this can only be done after the system has been bled out? Do you have a clutch stop installed on your build? How far forward should the slave arm move for full clutch engagement?
