Quote Originally Posted by jiriza84641 View Post
Thanks for the imformation. Ill moew thannlikely get this tester and some fuel to test my system also. All is connected with the SS flexible fuenlines from breeze also. Thanks again.
did your pressure test and holds steady at 60psi while pumping, had a small leak at the fuel filter but took care of that and good. now, thanks.
