Thanks Thanks:  85
Likes Likes:  149
Page 13 of 15 FirstFirst ... 31112131415 LastLast
Results 481 to 520 of 593
Thread: MJS Mk4 Build Thread
  1. #481
    Senior Member MSumners's Avatar
    Dec 2018
    Hudsonville, MI
    I used 1/8” volara sculpting foam for the trans tunnel under the leather. I believe I first saw it in Paul’s thread when he was using it on the dash. In my opinion gives the perfect cushion and appearance. I used it on my initial dash panels as well but I’m thinking of trialing one of them in 1/16”.
    https://www.yourautotrim.com/1thscfo.html
    On your trans tunnel, did you put anything between the leather and the metal or adheres directly to it?
    Coupe Kit Delivered 11/10/23
    Roadster Build thread: 2019-2022 https://thefactoryfiveforum.com/show...4-Build-Thread
  2. #482
    Oct 2020
    Albany, NY
    Thanks! Your upholstery looks great.
    https://thefactoryfiveforum.com/show...been-delivered
    Build 2 MK4 - Ordered 6/5/24
  3. Thanks MSumners thanked for this post
  4. #483
    Dec 2018
    Hudsonville, MI
    Still slowly plugging away. I decided awhile back I wanted something to fill the oil cooler space. After realizing I don’t need an actual oil cooler I decided to fab a setup with fog lights similar to many others. I believe a vendor used to sell one but doesn’t anymore.
    For those that have used a similar setup, maybe even from the prior vendor, how was it secured?
    My current plan is to HSRF four 10-32 thread adhesive studs in place as shown for a mounting platform.
    Anyone think this will cause any issues down the road?
  5. #484
    Properly roughed up and bonded with HSRF that should hold OK. FWIW, the Tangent Technology parts from the past had the base bracket directly on the fiberglass and just bolted through. The lights and grille were elevated so they lined up with the opening.
  6. Thanks MSumners thanked for this post
  7. #485
    Dec 2018
    Hudsonville, MI
    Thanks again for the info. I ended up direct bolting through the lower lip with some 1/4-20’s and rubber washers. The benefit here was some more adjustability in height with front and rear mounting sides. I think I’ve landed on a final version. No interference on any side and mounted solid. Time to get the body back on and final punch list before sending for paint in about 4-ish weeks.
  8. #486
    Dec 2018
    Hudsonville, MI
    Filling gas tanks from cans with safety spouts could be an Olympic sport
  9. #487
    Dublin, OH
    Anything larger than a 6gal tank is definitely like a strong man competition trying to hold that weight up
  10. #488
    Dec 2018
    Hudsonville, MI
    I’m working on Re-fitting the body today and have it forward so the jams are about 3/16 in front of the catch plate on each side. I’m working on centering the front end from the body wheel well lip to the shock mount and seem to be within 1/16. The rear is still a bit off. Is it common to have to adjust the rear end laterally at all? I have the threaded inserts in place that Jeff K has described and many do and with the all thread in place.
  11. #489
    Dublin, OH
    from my understanding, there's very little lateral movement in the rear. The QJ holes and the roll bar holes pretty much set the location. There's more movement in the front.
  12. #490
    Dec 2018
    Hudsonville, MI
    Thanks for the confirmation. I also haven’t had an official alignment yet so that is likely playing a role.
  13. #491
    Dublin, OH
    Yes, rear alignment will make a difference
  14. #492
    Dec 2018
    Hudsonville, MI
    And this is what a 1/4 20 tap looks like when it snaps in the lower part of the rollbar. Ouch. I spent about 15 minutes looking at how I can get this thing out before I realized I really don’t even need to. It doesn’t go through the back wall and now I just have the sleeve really well attached.
  15. #493
    Dec 2018
    Hudsonville, MI
    Re-assembly in full swing, busy day. Body back on, trunk and doors on, pipe cutouts trimmed, pipe hangers installed,
  16. #494
    Senior Member 460.465USMC's Avatar
    Aug 2019
    Spokane, WA
    Looking good!
    Coupe complete kit delivered: 4/22/24. Build Thread. Coyote. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
  17. Thanks MSumners thanked for this post
  18. #495
    Aug 2012
    Grand Rapids, MI
    Mike, Looks good. You are making great progress. Jim
  19. Thanks MSumners thanked for this post
  20. #496
    Dec 2018
    Hudsonville, MI
    Thanks gents.
    To those that used the bushing for hood latch support. Did you have to grind down the corners on the extension a bit to get through the bushing? Thought I bought a referenced size but the bushing is a bit small for the ID. Likely a fraction of a mm.
  21. #497
    Dec 2018
    Hudsonville, MI
    Trying to line up the radiator opening, middle of the windshield and midline between the rollbars. I feel like this may be a situation where you get to just choose two.
  22. #498
    These bodies are anything but symmetrical...the hood isn't centered...neither is the windshield...the plate lamp isn't centered and is offset from the handle...the headlights are crosseyed...the oil cooler scoop and radiator opening don't align and neither are perpendicular with sides of the body... This is not a place to be using a high tech tool like a laser. You just have to make it look right even though it isn't! So put away the laser and get a string. Measure between the headlights and mark the center. Install the license plate lamp and mark it's center. Now pull the string between the two and there ya' go! (Obviously the windshield can't be installed when you do this )You have to "fudge it" at the oil cooler scoop and jump the center between the plate lamp and handle (if you just "connect the dots" between the two the stripes will lean like this // when viewed from behind). You may need to adjust a little to hit center between two roll bars. Don't try to position the scoop on the hood until you have the centerline established because the center of the hood is not the center of the car.
    Easy peasey
    Dec 2018
    Hudsonville, MI
    Jeff, Perfect thanks for the recommendation. I’ll use your method for center. Right now I’m just looking for the midline to measure out from for the hood latches. I’ll wait for the scoop then until the hood position is secure and Re-identify car center.
    I’ve read that the hood latches may be mounted with the long axis to the rib for better contact. If that is done will they still be able to orient to the rear and lock?
    Thanks again all!
  24. #500
    Dublin, OH
    I mounted mine oriented side to side, so along the axis of the under hood rib. the square nature of the post allows you to mount the latch in 4-90* orientations.
  25. Thanks MSumners thanked for this post
  26. #501
    Dec 2018
    Hudsonville, MI
    Saturday I made final decision on destination for body and paint work. I have a couple interior things to finalize but nothing to hold up bodywork and decided to pull the trigger. Booked transport Saturday afternoon with Reliable Transport. Car was picked up tonight and next stop Yuba City California on Friday for a short residency with Ken Pike.
  27. #502
    Aug 2019
    Spokane, WA
    Congrats, Mike! That's got to be a good feeling. What did you decide for color choices? (Sorry if you've already stated and I missed it.)
  28. #503
    Dec 2018
    Hudsonville, MI
    Yeah almost can’t believe it’s nearing the “end”, but I know the saying. I’m excited to see it in color but in no big rush to get it back, plenty of things to keep busy with in the meantime. Exact color codes to be determined but I know in my head exactly what I want it to look like. Something near midnight blue with vintage white stripes. I tried a few times throughout the build to convince myself I would do something different but ultimately always came back to this combo. All my favorite cars have been blue.
    Quote Originally Posted by 460.465USMC View Post
  29. Likes 460.465USMC, JB in NOVA liked this post
  30. #504
    Dec 2018
    Hudsonville, MI
    Car is at paint and I’m not one for idle time. Picked up a tinker project in the meantime.
  31. Likes Straversi, Mark Eaton liked this post
  32. #505
    Dec 2018
    Hudsonville, MI
    Body underway.
  33. Likes 460.465USMC liked this post
  34. #506
    Dec 2018
    Hudsonville, MI
    Interim project success. Rolling the country roads.
  35. Likes JB in NOVA liked this post
  36. #507
    Dec 2018
    Hudsonville, MI
    Anyone know the standard sizes of the circle front hood badge and the rectangular side badges off hand?
  37. #508
    Dublin, OH
    the ones offered by ********** are
    side badges: 4-3/16" by 1-5/16"
    hood badge: 2"
  38. Thanks MSumners thanked for this post
  39. #509
    Aug 2019
    Spokane, WA
    Hi Mike. Just checking in to see how the bodywork and paint are coming along?
  40. #510
    Dec 2018
    Hudsonville, MI
    A bit behind schedule but sounds like all is coming along well. Last I heard car was in primer and supposed to be finished approximately 3 weeks from now. Thanks for checking in. Once I get an update I’ll post. Can’t wait to see the colors!
  41. Likes 460.465USMC liked this post
  42. #511
    Dec 2018
    Hudsonville, MI
    And we have color! Should be right on schedule for final assembly, registration and as many summer miles as possible. About two weeks to completion and then the long trek back to Michigan. At least the shipping quote is less than it was when I checked a couple months ago. Next major posts should be completion as after it’s back it will primarily be Re-attaching everything and working on setup.
  43. Likes John Ibele, Chainsaw liked this post
  44. #512
    Dublin, OH
    Looks great. What color blue is that?
  45. #513
    Looking good!
  46. Likes MSumners liked this post
  47. #514
    Dec 2018
    Hudsonville, MI
    The blue is Lexus indigo ink. Stripe is actually lambo titanium and almost looks white in that picture.
  48. #515
    Dublin, OH
    Quote Originally Posted by MSumners View Post
    Great combo. Going with a similar blue
  49. Likes MSumners liked this post
  50. #516
    Aug 2019
    Spokane, WA
    Right on, Mike! Looks really nice. Congrats!
  51. Thanks MSumners thanked for this post
  52. #517
    Mar 2021
    Long Island, NY
    Love the color combination. Congrats!
    MK4 Complete Kit, EFI 427W/TKO 600, 2015 IRS
    Ordered: 11/6/20, Kit Completion: 2/13/21, Picked Up: 2/16/21, Build Started: 2/19/21, First Start: 6/13/21, Go Kart: 8/15/21, Sent for Paint: 12/23/21, Back From Paint: 6/16/22, Street Legal: 7/11/22
  53. Thanks MSumners thanked for this post
  54. #518
    Senior Member Chainsaw's Avatar
    May 2020
    St. Johns, FL
    Love that combo. I think that's the blue I've been looking for to use as the 289 nose stripe with the lambo titanium as the primary although the Missus thinks I should use the blue as the primary.
    Jack
    289 Roadster complete kit ordered 8/2/21. Delivered 3/14/2022. Chassis #10306. 17"x9" Halibrands, 3.55 IRS, PS, Wilwood brakes, BPE 306 with EFI and close ratio TKX. First start 7/20/2023. First Movement 9/24/2023. First go-kart 9/25/2023.
    Build thread - https://thefactoryfiveforum.com/show...rida-289-Build
  55. #519
    Oct 2020
    Albany, NY
    Can't wait to see it in the sun! I love that color combo, I thought it was white at first too. Now I'm intrigued with the titanium.
    Ken's work is exceptional.
  56. Thanks MSumners thanked for this post
  57. #520
    Dec 2018
    Hudsonville, MI
    Updated assembly pics. Getting closer to the Reliable truck pickup. My head may explode when I see this in person.
  58. Likes egchewy79, 460.465USMC, GTBradley liked this post
