Likes Likes:  3
Results 1 to 11 of 11
Thread: pulling rear wheel studs
    Oct 2021
    Durham, NC
    Friends,
    Apologies that this has been kind of discussed in multiple threads already but I'm having a maybe unique issue I'm hoping you all can help with.
    I'm working on replacing the studs on the rear wheel hubs with the Dorman 610-519's.
    After reading through threads on this forum, I purchased the Lisle device ( https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 ).
    All good screwing the lug nuts on down to the device on the stud, but upon trying to tighten further to pull the stud, I got a lot of resistance. In all honestly I brute forced it with my impact wrench, which pulled the stud but you won't be surprised to hear that the stud threads are now not so pristine, so I need to try a different approach.
    I could put a bit of grease or oil on the knurl to reduce the resistance, but I'm hesitant to lubricate something that I'm trying to permanently fix to the hub.
    Thanks all for advice in advance.
    ST
    Dec 2021
    Flower Mound TX
    Find a local auto parts store or machine shop that has a hydraulic press. It will make short work of them.
    I bought a 12-ton press a few years ago for $30 on Craigslist and have used it for a bunch of stuff. It's one of those tools you don't know you need until you have one.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Member of the The Gateway Cobra Club
  4. Likes narly1 liked this post
    Sep 2015
    Hamersville, Ohio
    I used a press on mine.
    Kit #361, arrived 10/2015, still in progress
    818C highly modified, corvette suspension
    Estimated completion summer 2023!
    1989 turbo Supra 5 sp
    2017 Tundra
    Senior Member JJK's Avatar
    Jul 2022
    DFW Texas
    I bought some sacrificial lug nuts and used one per lug to pull them in. used grease and washers as well. not as good as a press, but managed at home
    Vero Beach FL
    Ditto on the press. Now I have one. Wish I got one sooner
    Mk4 #10605 Ordered 5/28/2022. Received 3/18/2023
    Build Thread https://thefactoryfiveforum.com/show...-Roaster-Build
    Senior Member RBachman's Avatar
    Jul 2019
    Quote Originally Posted by JJK View Post
    Dittos on that. Some lubrication, line things up, abuse a sacrificial lug nut with the impact, and teach those studs some respect. LOL.
    Jun 2015
    Fairfax Station VA
    Quote Originally Posted by RBachman View Post
    I did much the same, except by hand with a ratchet. Install the stud by hand, slip a 5/8" nut (or spacer) over the stud, plus a couple of liberally greased washers, then a lug nut. Tighten by hand & they'll pull right in. It takes time, but you'll get'em in.
    MK IV Roadster #8631
  10. Likes RBachman, BRRT liked this post
  11. #9
    O'Fallon, MO
    If it took so much force to pull them in that the threads were damaged, I would check to make sure you have the correct studs. They do have different sizes at the knurl.
  12. #10
    Senior Member BRRT's Avatar
    Sep 2020
    Quote Originally Posted by phileas_fogg View Post
    I did the same. Did not even need an impact. Grease the threads, grease the knurl, grease the washers. Went in without a problem.
    Roadster delivered 8/27/23
    Chevrolet Performance LS3
    Senior Member ydousurf's Avatar
    Feb 2019
    Greality, Colorado
    I tried the grease with a stack of washers and, well, stripped the threads on the stud. I called FFR and ask them what they reccomend to get these installed, Dave advised to use an ABN Wheel Stud Tool.
    I searched the interwebs and found them being sold from many places. I ordered one, along with more studs from FFR too!
    Butter! The ABN tool is a bearing built for this very task. Sure, try the cheaper way with washers, but a few buxs and your golden!
    Also, don't forget to grind down one side on the "head or back" so they seat better on the wheel bearing itself and don't interfere with the seal. If you have a wheel grinder, it can grind the "arc" pattern to match the wheel bearing. All the best in your build journey, ST!
    Doug
    Dj or Doug or TheLateDude
    ----- #19 of 25th Anniversary MKIV 9769 -----
    Build Link: https://thefactoryfiveforum.com/show...-Slow-Progress
    Ordered: Oct 07, 2019 / Production: Dec 28th, 2019 / Shipped: Jan 19th, 2019 First Start: In the future... / Graduation: Even further in the future...
