5
14
Originally Posted by
JimStone
GoDadGo: Dark Side it is! Your recommendations are spot on and I plan on following them whole-heartedly. It's amazing the power these LS engines can put out with just a cam change. Stroke them and the numbers are unreal. I would be perfectly happy with the 376ci LS (still 530 HP!), but for $2k more why not!? I'll rarely use all the power, but I'll know it's there and it'll sound meaner too.
I totally that I agree that spending the extra $2,000.00 made perfect sense.
.............If your plan is to run an Iron Block the added weight really isn't an issues.
