Thanks Thanks:  6
Likes Likes:  8
Results 1 to 18 of 18
Thread: Wood Dash
    May 2023
    Frisco, TX
    Wood Dash
    After months of working on this dash, I finally finished it! This was my first time working with varnish, and it is very temperamental. I had to completely strip it once because I didn’t know how temperamental varnish was with humidity, and I brushed a coat on while it was raining outside. FML….
    Anyway, it’s a waterfall bubinga veneer with 7 coats of Captain’s Varnish. Once it cured for long enough, I cut it down to a satin finish with 0000 steel wool and Bowling Alley paste wax. I couldn’t be happier with how it turned out. I’ll also be doing the trans tunnel cover, but not until after I have the trans in, just in case I end up relocating the shifter hole.
    Not dash related, but in collaboration with Mike Bray, I got my custom steering wheel
    Hub done, and it looks awesome. But, since the only thing I want to be shiny on my car is the body, we’re working on an alternative design.
    MKIV Complete Kit # 207585
    Ordered 8/19/2023. Completion date 11/11/23. Delivery date 11/27/23
    Build Thread: http://https://thefactoryfiveforum.c...577#post535577
    Man that dash looks awesome! Great job! Wood dashes were a big thing back in about the MKIII days.. I haven’t seen one in a whil; yours came out fantastic!
    Congratulations!
  3. Thanks Mbufford thanked for this post
    Jul 2022
    DFW Texas
    That is beautiful, good job.
  5. Thanks Mbufford thanked for this post
  6. #4
    Senior Member Lidodrip's Avatar
    May 2020
    Yarmouth, Maine
    Great job, can't wait to see everything come together!
  7. Thanks Mbufford thanked for this post
  8. #5
    Nov 2023
    Beautiful! I once had a TR6 and put a rosewood dash in it. I always miss having a wood dash. Your's is awesome.
  9. Thanks Mbufford thanked for this post
  10. #6
    Very, very nice. Car color will be???????
  11. #7
    Oct 2021
    Sarasota, FL
    Great looking dash. You are true artisan.
    Roadster MK4 #10653 Date: 4-27-23; First Start: Oct 2023; Go Kart: Nov 2023; Body and Paint: To Kleiner EDD - April 2024; Graduated: TBD
    SBF Boss 347, Edelbrock ProFlo 4, Milodon Road Race Oil Pan, Tremec TKX 2.87/0.81 OD, IRS Dakota Digital Dash, FFMetal Firewall Forward, BOIG Lower Cool Pipes, Forte's Mechanical Throttle Linkage and Hydraulic Clutch, Breeze Radiator Fan Shroud- Radiator Support Kit and Battery Forward
  12. Thanks Mbufford thanked for this post
  13. #8
    May 2023
    Frisco, TX
    Kind of hard to explain that part. But I basically want to do what is in this picture: IMG_0729.png
  14. #9
    May 2023
    Salisbury, NC
    Did you plumb fresh (front) air into both foot boxes or will that be for AC?
    MkIV Complete - Dart 427/TKX/Sniper II/IRS from Forte
  15. #10
    Sep 2019
    Bothell, WA
    Great looking dash!
  16. Thanks Mbufford thanked for this post
  17. #11
    May 2023
    Frisco, TX
    Quote Originally Posted by jeskam View Post
    Yeah, it’s just foot box vents. More info in my build thread, but I used electric valves with the fans and wired it to one button for each side—on opens the valve and starts the fan, and off closes the valve and stops the fan. IMG_1060.jpgIMG_1059.jpg
  18. #12
    Jun 2022
    Nice, mine are still in progress. I'm going to attempt this pour on once the weather warms up a little more.
    MKIV Roadster - Complete Kit - Delivery 10/12/23
    May 2023
    Frisco, TX
    Is that an epoxy resin? I’ve played with those recently as well. Just like any other gloss coating, dust nibs will be a big problem. Wasn’t much of an issue for me, since I sanded and rubbed it to a satin finish. But for anything high-gloss, you need to have an absolutely dust-free environment to do it. The other option is to painstakingly sand out the nibs, then polish and buff your finish back to high gloss.
    I don’t have any shots of it, and my dash is currently covered with plastic for the body-work phase. But, I was able to get my veneer all the way around the bottom without any cracking. Granted, I was surprised I pulled this off—I think it was mostly due to the species I used being more flexible.
    Good luck, can’t wait to see pictures!
  20. #14
    Jun 2015
    Fairfax Station VA
    If you cover your dash with epoxy, you'll need to protect the epoxy from UV degradation, else after a few years the finish will become cloudy. I'm not aware of any UV-resistant epoxies. Most boat guys cover their epoxy with spar varnish (which is somewhat sensitive to humidity when applying). Rust-Oleum 207008-6PK Marine Spar Varnish holds up better than most, according to several marine application studies...
    MK IV Roadster #8631
  21. #15
    Jun 2022
    my edge on the lower dash is pretty flush with the bottom lip, I'm pleased with that. The tunnel cover is a bit of a wreck and I don't know if I have a simple solution to make it look good in the transition to the carpet on the sides. I'm considering using some sort of bathroom tile trim on the edges: https://www.lowes.com/pd/Schluter-Sy...rim/1000674199.
  22. Likes Mbufford liked this post
  23. #16
    Jun 2022
    Quote Originally Posted by phileas_fogg View Post
    Honestly looking at the spar varnish, I may go with that. I'll have to do some more research.
    May 2023
    Frisco, TX
    Quote Originally Posted by nashuanuke View Post
    Yeah, varnish is the premium and longest lasting option. I used the Pettit Captain’s Varnish because all the marine folks recommended it, and those guys know varnish. It’s just such a pain to apply because it attracts dust so much. It took me a few coats before I finally set up a dust-free booth with drop cloth plastic, and air filter, and a fan. Even then, I quickly learned I needed to spray the entire inside of the booth with water before moving the project inside for a coating. If you do those things, it’s manageable.
    Also, worth mentioning is that, in the end, I found the spray-can varnish to be much easier. Brushing layers on is tough because if you lay it on too thick, it’ll wrinkle and not cure with a smooth surface. Spraying gives thinner layers, but much easier to control.
  25. #18
    Jul 2021
    Big Canoe, GA
    Epifanes.
    Art Shand, Big Canoe GA
    BPE 347 FI, Hydraulic Tremec TKX, Wilwood front & rear, GAS-N Headers/Touring Pipes, many functional upgrades.
