Likes Likes:  20
Results 1 to 20 of 20
Thread: Jeff Kleiner's #28, FFR 5946 FOR SALE
    This is a pretty well known car that has been used for attending the London Cobra Show, leading Hoosier Cobra Club cruises, for doing autocross, track days and even a few quarter mile passes. It takes my wife for ice cream on nice summer evenings and carries me to the grocery store, hardware store and Lowes or about anywhere else I need to go. It's even been in 3 car shows and brought home trophies! It's racked up about 25,000 miles doing those things, although over the past several years that's been limited to about 5-600 per year due to lack of time. Here's the basics:
    DRIVETRAIN
    Totally rebuilt 5.0 Windsor with TRW forged pistons topped off with Trick Flow top end featuring Twisted wedge heads with upgraded valve springs. TFS Stage 1 roller cam, double roller timing chain and Ford Racing rockers, TFS pushrods and roller rockers. Trick Flow Street Burner intake, 24# injectors, 70mm throttle body, ProM 75 mm meter and Walbro 255 lph pump. Exhaust is through FFR/Hooker long tube headers into the side pipes.
    Transmission is a Tremec "World Class" T-5 5 speed coupled with a Ford Racing "King Cobra" clutch and pressure plate package..
    Rear end is a Ford 8.8 that was rebuilt with all new bearings, a Ford Racing 3.55 ratio ring & pinion and new limited slip clutch/spring packs as well as new Yukon 5 lug axles.
    CHASSIS & BRAKES
    Front suspension was recently (May of 2024) upgraded to the Mk4 configuration allowing relocation of the upper control arms and a change to the FFR proprietary spindles. New ball joints were installed and the lower control arms' poly bushings were upgraded to spherical bearings. It uses Koni 30 Series adjustable coilovers with 750# springs.
    Rear suspension is Factory Five's 3 link setup with Koni 30 series adjustable coilovers with 500# springs. The rear lower control arms were recently (May 2024) upgraded to Breeze Automotive adjustable arms with rod ends and an offset to bring them to parallel.
    The car has hydraulic power steering and features a Heidt's adjustable valve which allows for variable levels of assist.
    Brakes were also upgraded in May 2024 and are vacuum assisted. Fronts use the big 13" rotors and twin piston calipers. Rears are the 11.65" rotor Cobra setup. A new booster and a .9375" bore 1994/1995 Mustang Cobra master cylinder was installed.
    The car is presently on Toyo R888R tires; 275/40-17 front and 315/35-17 rear mounted on 9" (F) and 10.5" (R) rims.
    BODY & INTERIOR, ETC.
    Body is satin black DP90 epoxy with gloss black stripes. Interior is fully insulated and carpeted. It has one of the original FFR carbon fiber dashboards with Autometer UltraLite gauges. Seats are the FFR Street Performer highbacks (same as Cobra Clubmans). Trunk is carpeted with a drop box; battery is under the upper trunk floor with a hinged access cover.
    The car is registered and titled in Indiana as a "1965 Factory Five Racing FFR65". Since it has been registered continuously for over 15 years it would be eligible for importation into Canada.
    Negotiations will start at $35,000. Shoot me a Private Message and I can send more info, hundreds of photos and we'll exchange contact information.
    Woodstock ,Illinois
    That's a steal for that car!
    Dublin, OH
    This car is iconic. It'll be weird to see someone besides Kleiner driving it.
    Can't wait to see your next project, Jeff!
    Senior Member MPTech's Avatar
    St. Louis, MO
    WHAT??!!
    Sorry to see this post Jeff. That roadster is a classic! Good luck with the sale, someone is getting a great deal on an excellent car!
    Are there plans for a new replacement??
    Senior Member DW66's Avatar
    Jan 2020
    Plymouth Mass
    I can't believe this hasn't sold already....
    MK4 Complete kit FFR9939. Gen 1 Coyote, Tremec 3650, IRS 3.31 ratio, Breeze radiator stuff, Breeze cubby and battery mount, North Race Cars heat and A/C, RT drop trunk kit, Replica Parts radiator aluminum and brake booster spacer, FFR soft top.
    Sir Jeffski, Say It Ain't So!
    Anyway, please know that I sent this message to several of my friends via E-Mail earlier this morning.
    Factory Five MK-3 For Sale "This Is A Go Have Fun Cobra!"
    Gentlemen,
    • The Famous #28 was never painted other than being shot in Epoxy.
    • The fellow that built & owns this car is a friend of mine.
    • Jeff is an expert builder who is a no nonsense guy.
    • #28 is set up for Auto Crossing & is a real driver.
    • On the Factory-5 Forum Jeff's advice is golden.
    • At $35,000.00 this car can be owned, driven hard, banged on & enjoyed.
    https://thefactoryfiveforum.com/show...882#post559882
    Dec 2017
    Southern Ontario/Cape Coral FL
    How is the body and paint?!
    Bump
    Higgy
    MK4 #11012 picked up 04/16/24
    351W, 3 link, single roll bar
    MK4 #10616 picked up 4/10/23
    MK4 #9759 picked up on 4/3/19
    Car is sold!
    Two hours after posting it outside of the forum I received funds via a wire transfer. New owners came to meet it in person this morning and it is bound for Utah.
    Stay tuned...something new will be coming soon!
    Jan 2020
    Plymouth Mass
    Congratulation's Jeff. I guess....
    Sep 2022
    Congrats Jeff! What's your next project?
    Craig C
    Salt Lake City, UT
    I'm looking forward to the next project and will keep an eye out for #28 out here.
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    The conspiracy theorist in me wants to believe that something new and amazing is coming from FFR and you're going to be the first to build one. Why else would you be selling this car?!
    Am I right?! AM I RIGHT?!?!?!
    Oct 2020
    Albany, NY
    I spoke to Jeff on the phone and he would only say "working on something new". I'm giddy with anticipation.
    Unless it's a MK5 then I'm going to be annoyed I didn't wait to buy another one.
    Build Thread #1 https://thefactoryfiveforum.com/show...been-delivered
    Build 2 MK4 #11061- Delivered 08/24/24
    Build Thread #2 https://thefactoryfiveforum.com/show...006#post562006
    Senior Member john42's Avatar
    Aug 2020
    Hollis, NH
    Or maybe a GT40 :-)
    MK3 Challenge Car, Boss 347, Sniper 2 EFI
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Gen 4 coupe!
    Aug 2021
    Congrats Jeff and I agree GT40 :>)
    Ray
    Oct 2020
    Albany, NY
    I came close to pulling the trigger on a RCR40, would have cost everything I had just to get into the kit but the resale is attractive. In the spirit of completely highjacking this thread I agree that seems like the logical thing. Can't wait to see what Jeff does with it.
    Also congrats on the sale and whoever got it was given an incredible deal.
    Not a 40. Or a Coupe.
    Senior Member ydousurf's Avatar
    Feb 2019
    Greality, Colorado
    I’m not a betting man, nor do I have a crystal ball, but if I was to take a guess… I would suspect that Jeff has a pearl or diamond ticket for a 30th Anniversary Roadster? I mean, I’m pretty good at connecting dots and still watch Columbo. Haha. Just don’t ask me for the lotto numbers! I think we’re all waiting to see what your next project will be? All the best Jeff!
    Doug
    Dj or Doug or TheLateDude
    ----- #19 of 25th Anniversary MKIV 9769 -----
    Build Link: https://thefactoryfiveforum.com/show...-Slow-Progress
    Ordered: Oct 07, 2019 / Production: Dec 28th, 2019 / Shipped: Jan 19th, 2019 First Start: In the future... / Graduation: Even further in the future...
