Ok..thinking ahead, does anyone see any possible problems with the way I mounted the brake reservoirs and lines (pics attached). I stayed away from the top rail as noted in other builds and tried to keep the distance and height similar to the build pics I've seen. My kit only included four self tapping screws, not the aluminum brackets I've seen in other posts.
For those I have not yet been introduced to, I'm a first time novice builder. Thank you for your patience, and any help is greatly appreciated!
