Results 1 to 10 of 10
Thread: Starter options for the Coyote?
    Administrator David's Avatar
    Eldo CA
    Hey guys, I need to pick up a starter for the Coyote crate motor. I would prefer not to run a external solenoid(not on the starter).
    I read recently that a 2011-2012 Mustang 5.0 starter would be a good option for that. Anyone have some tech they are willing to share on what the best starter options are?
    Senior Member tcoon's Avatar
    Angwin, CA
    I used the Powermaster heavy duty unit from Summit...a bit pricey but have had several previous starter failures on the challenge car with cheaper units. The nice thing about this unit is it has an adjustable base which allows you to rotate the starter for best fit...and frame clearance is very tight so adjustability is a virtue. This is the unit for the 2011 mustang.
    -T
    Coyote powered Daytona Coupe Competition Racecar #21
    Challenge series #21
    FFR 33 Hot Rod
    2009 3rd place NorCal series
    2010 3rd place West Coast series
    2011 2nd place NorCal, 2nd place West Coast Series, 3rd place WERC class E1
    Eldo CA
    Thanks... I saw that one... looks really nice and that's a top runner for sure Trying to decide if its worth 2x the 2005+ starter.
    Novice builder
    Jan 2013
    Northern VA
    ok perhaps I am just slow, but what bolts did you use to install the starter? I don't have any for this and nothing lists the size.
    Fubar94
    1970 Mach1
    2012 Boss 302
    Mk4 - under construction
    Member stroked 6t5's Avatar
    If you want to save a fewbucks you can use a 4.6 unit.
    2bking's Avatar
    Garland, Texas
    I got the M-11000-MT164 Ford Racing starter but haven't installed it yet. It's a bit pricey compared to the stock one but it is the small diameter with rare earth magnets.
    King
    Mustang Convert bansheekev's Avatar
    Morgan Hill, CA
    Quote Originally Posted by fubar94 View Post
    I bought the OEM bolt kit for mine from Latemodelrestoration.com part #HDW-11002E. They fit my power master starter on the Coyote perfectly.
    Kevin
    MKIV, IRS/TruTrack/3.55s, Coyote, TKO600, Wilwoods
    Delivered: 1/6/2012
    First Start: 1/19/2014
    First Go-Kart: 2/1/2014
    Graduation: 1/4/2015
    Graduation Thread
    Senior Member chrisarella's Avatar
    Clearwater, FL
    What is the part number on that Powermaster unit. Summit is listing 107 options for a coyote with a manual trans.
    Mark IV Roadster #7679
    Coyote 5.0, T56, Hydraulic Clutch, IRS, Torsen Diff, Wilwoods, Hydraboost, ABS Power Brakes, Power Steering, & tons more extras.
    Morgan Hill, CA
    Quote Originally Posted by chrisarella View Post
    Here you go:
    POWERMASTER XS TORQUE HIGH TORQUE MINI STARTER 4.6L/5.4/COYOTE 5.0L
    Part #9532
    http://www.summitracing.com/parts/pwm-9532
    Kevin
    Delivered: 1/6/2012
    Graduation Thread
    Clearwater, FL
    Thanks Kevin!!
