Thanks Thanks:  10
Likes Likes:  18
Results 1 to 40 of 365
Thread: #9196 475hp 347 MK4 Roadster Build (Insurance and Plates)
Threaded View
    May 2016
    The goal... Have every nut and bolt hand assembled by this wing-nut (Air Force Aviator Joke). I feel that if you are willing to try you can do anything in life and with these cars. Everyone that sees my car and asks me about it wonders what it takes to build one. I tell them my life motto. "Fake it till you make it." To me that means you have to ACT like what you want to be until you ARE what you want to be. Through proven resources and research, I was able to build a high end car for low end money. The cost benefit analysis was applied to each step of the multiyear build. Through these tactics, techniques, and procedures I was able to have a car that is high in options but low in overhead costs.
    Installs and Builds
    The T5Z transmission build
    The 347 engine build
    When the car came in a big cool truck
    Heater Core Install
    The 475hp/440torque Dyno Day
    The engine install
    Wheel and Tire Install
    Aircraft Rivet Spacing
    Hand Braided Chassis Wiring
    Factory Five Driveshaft assembly
    Lokar Throttle Cable and Bracket
    First Start
    Coolant Overflow Tank and Filler Neck Gates Brand Install
    Wilwood Brake Reservoir install
    Clutch Safety Switch Install
    Air Cleaner & Engine Pics
    High Mount 3rd Brake Light
    Initial Body Fitment
    Custom Factor Five Center Caps
    Weather proof Weather Pack connectors
    Professional 3M Interior Carpet Install
    Chrome Mirrors Trim and Gapping Hood/Doors
    Power steering install
    LED 3rd Brake Light
    LED Interior lighting, Bluetooth Stereo Amp install
    ENGINE
    TRE Performance California 302 race prepped and blue printed block, honed and plugged
    Moroso Main Cap Girdle
    Scat 3.4 Crank Shaft
    Scat Connecting Rods
    RaceTec Custom billet forged pistons Autotec -5cc (11.5:1 compression)
    Trick Flow Stage 2 - 0.542/0.563 lift, 224/232 @ 050, 286/294 adv duration
    Felpro .039 head-gaskets
    Trick Flow 11R 190CC CNC heads with 2.055 1.6 valves .600 springs 56cc Chambers
    Comp Cams aluminum roller rockers 1.6
    Hand Fabricated Aluminum Valve Covers
    Trick Flow Chromoly pushrods
    Ford Performance Hydraulic Roller Lifters
    PAC .600 valve springs
    Trick Flow SS valves
    Ford Performance Single Plane Intake Manifold
    FiTech Go EFI 4 600 Horsepower system
    Mr Gasket 1" Intake Spacer
    KMJ Performance 15" Oval Polished Air Cleaner 2" Tall filter
    Bosch 4.2 with AFR meter
    MSD Foxbody Style Coil
    Ford Raing 9MM Black Wires
    Ford Motorsports Chrome Distributor Hold Down
    Professional Products Locked out Distributor. My Lockout video. https://www.youtube.com/watch?v=yynJWYp4KR0
    Walbro 255 LPH Fuel pump
    March Billet Pulley Kit
    Gates 57.3 6 Rib Serpentine Belt
    Gmb Waterpump
    LMR Thermostat Housing
    Ford Motorcraft 180 D Thermstat
    Gates Water Filler Neck
    LMR Aluminum Overflow Tank
    LMR 29 Inch Wide Radiator
    Trick flow 28oz Dampener
    Felpro Gaskets including .039 Headgasket
    Fitech coolant, temp, pressure sensors, and computer
    Dorman Oil Pan
    Ford Motorsports Chrome Dipstick and Tube
    Melling Oil Pump
    Ford Parts Pickup Tube (Modified)
    Steeda Air Oil Separator System
    Ford SN95 PCV Valve on PS Grommet and Valve Cover
    Amsoil 30 Weight Zinc Break-in/ 10w30 Synthetic after Break-in
    Powermaster Alternator
    Yellowtop Battery
    FUEL/IGNITION SYSTEM
    Rhinohide 5/18 fuel line
    Rhinohide 1/4 return line
    Earls 6 AN Fuel Fittings
    Gates 30R9 High Pressure Fuel Hose
    Motorcraft Mustang OEM Fuel Filter
    Walboro 255 LPH Fuel Pump
    Ford In-tank Fuel pump bracket
    FFR Fuel Cap and Retrofit
    Ford Mustang Fuel Level Sender
    Ford Electrical connectors retrofitted to chassis harness
    Lokar throttle cable
    Lokar throttle bracket
    Lokar tandem return springs
    CLUTCH/PRESSURE PLATE
    King Cobra Clutch Kit (Made in Korea) 5-spring
    Ford Racing Hex Flywheel Bolt Kit
    RPM FPH-30228 Billet Flywheel, SFI 1.1 Rated
    McLeod Clutch TOB Fork
    Ford Adjustable Clutch Cable
    Maximum Motorsports Billet Firewall Adjuster
    Maximum Motorsports Billet quadrant
    TRANSMISSION
    T5 Z Tremec Transmission (hand built to t5z spec with the addition of electronic speedo and tail housing)
    Motive 2.95 Alloy First Gear
    Motive .60 Alloy Final Gear
    Motive 5th gear lock/syncro
    Ford Carbon Fiber Blocker rings (Syncros)
    Ford 2000 Mustang tail housing
    Electronic speedo conversion
    Custom Billet retainer plate
    Ford 1 piece finger selector
    Ford Smooth no hole top loader style case cover
    Pro 5.0 PRO-7210T5 Billet Shifter base
    FFR Classic Shift Pattern Knob, Handle, Billow, and Chrome Bezel
    Amsoil ATF Synthetic
    DRIVESHAFT
    FFR Chromoly T5-8.8
    REAREND
    Ford 8.8 10 bolt live solid axle
    Ford 3.73 Gears
    Ford Cobra Limited Slip Differential
    Ford SN95 5 lug Alloy Shafts
    Ford Cobra Rear Break Strengthening Brackets
    Ford Performance Parts SVO Diff Cover/Girdle (old school)
    Amsoil Gear Oil 75W-90 Synthetic (does not require friction modifier)
    SUSPENSION
    KONI Front and Rear Coilovers
    FFR Upper and Lower Front Control Arms
    Ford SN95 knuckles/spindle
    FFR 3 Link Rear
    STEERING
    Ford Sport Suspension 2.5 Power Rack and Pinion
    March Pulley/Bracket
    Gates 57.3 Serpentine Belt
    Ford Power steering pump
    Castrol Transmax Type F Fluid
    Ford Power steering lines
    Maximum Motorsports Aluminum Steering Rack Bushings
    Maximum Motorsports Tie Rod Ends w/Bumpsteer Kit
    FFR Leather Wrapped Steering Wheel
    BRAKES
    Wilwood Reservoir kits (2)
    AGS Poly-Armour and Rhinohide 3/8 Hardlines
    FFR Stainless steel braided brake lines
    Ford Performance 2300-K Big Brake kit includes:
    Bendix (PBR) SN95 Ford Performance Brake Booster
    Bendix Ford Performance Master Cylinder
    Ford SN95 Spindle Knuckles
    Ford PBR Cobra 13" 5-lug Front Dual Piston Caliper and Rotor
    Ford PBR Cobra 11.65" 5-lug Rear Caliper and Rotor
    Ford Cobra anti-moan braces
    WHEEL TIRE
    LMR Staggered Bullitt Anthracite
    275/40/17 Nitto G2 Tires
    315/35/17 Nitto G2 Tires
