0
0
Originally Posted by
Jeff Kleiner
Actually that is backwards---don't install the back wall until after you have riveted the trunk floor.
MBDSLPWR,
Your question is kind of broad; can you be more specific? It is possible to jump back and forth on many items when necessary due to convenience, supply or space issues. My general order is:
---build suspension
---run brake and fuel lines (a few aluminum panels need to be in place when doing this)
---install aluminum but leaving off the top and outside of the driver's footbox
---install wiring
---install drivetrain and cooling system
---initial body fit
---bodywork & paint
---insulation & carpet (body off)
---final body installation and trimout
Nothing is set in stone but that works for me.
Thanks for correcting me Jeff. Posted that to early this morning and had a brain cramp! I am deleting that from my previous post so there is no confusion.
http://thefactoryfiveforum.com/showt...e-build-thread
