Thanks Thanks:  6
Likes Likes:  7
Page 6 of 8 FirstFirst ... 45678 LastLast
Results 201 to 240 of 285
Thread: Ducky2009 MK4 Build #9035
  1. #201
    Lilburn, GA
    Beautiful!
    What color is that?
    Steve,
    I purchased the paint from "Paint My Ride", color B-5-09600.500. Not sure the color has a name but I'll double check. Picked it from a color chart. The paint is Mipa brand, a German company. I asked a friend (retired paint shop owner) about Nason paint, what a local supply house wanted to sell me. He told me it's OK, but not the easiest to spray and recommended Mipa. He also asked me if I wanted to spray two layers of different colors (base and top coat, plus clear), or one layer of a high quality paint and clear. It cost more, but about the same as purchasing multiple layers paint.
    Edited: The color doesn't have a name.
  2. #202
    Lilburn, GA
    Paint and Clear - Waits sanding/buffing
    The weather finally cooperated and I was able to apply the final coats of paint and clear. In a previous pic, the color looks light blue. That was after I wet sanded to prep for final spray. I purchased a darker blue but sample cards can be deceiving, depending on the light, but there was a pretty big difference. I'm now waiting a few days before sanding/buffing.
    NOTE: I did learn a neat trick recently. I didn't do it, but a friend did. He wanted a two-tone paint job, but did it with the primer. The body lines (1957 Buick) gave a nice separation point. He used two different primers, light and dark, and one color of paint.
  3. #203
    Lilburn, GA
    Final Paint and Wet Sanded - Ready to Buff
    Realized my last pics didn't really show the color very well. Finally wet sanded and ready to buff the body. Still need to sand the doors, trunk and hood. I ended up with one run in the clear but was able to sand it out..
  4. #204
    Lilburn, GA
    Carpet - Trunk
    I found automotive unbacked carpet for my trunk. It's 18 OZ weight, pretty easy to work with. Since the car is blue, I choose blue carpet.
    I also installed LED trunk lights. Found a 16' strand on-line. The didn't trust the self-adhesive backing, it didn't seem very tacky. Ended up buying 3/8" clear tubing and sliding the LED lights inside and attaching to the 3/4" trunk rails. Used 10' to go all the way around the upper part of the trunk.
  5. #205
    Oct 2017
    Williamsport, IN
    Beautiful color. Nicely done. I have the utmost respect for those of you that do your own body and paint work.
  6. #206
    Lilburn, GA
    Body Fit - Insulation
    I've been a little slow to get the body back on the chassis. Vacations and grandbabies has taken precedents.
    I checked the gap between the body and footboxes before removing the body to paint. Checking in a horizontal direction on the PS, the gap measured a little more than 2". The drivers side is a little less. Made a body template (inside of the body) then made the reverse image and held it over the footbox. The top of the DS footbox had a large gap.... see pic. The supplies insulation is not thick enough to seal this gap. Has anyone else had this issue?
  7. #207
    Senior Member DavidW's Avatar
    Stevensville, MD
    I just put the insulation in my Roadster between the footbox and the body, after paint and after the body was installed. I used this product from McMaster-Carr #7650A14, they do have other sizes and its easy to layer on top, or back to back to fill the gap. I took the advice from Edwards build. https://www.mcmaster.com/#7650a14/=1cp1k07
  8. #208
    Lilburn, GA
    Quote Originally Posted by DavidW View Post
    DavidW,
    Guess it never occurred to me to install after the body is on. The manual says to install first. With the McMaster product with the Adhesive back, was it difficult to install?
  9. #209
    Guys,
    Thanks for the tip for the Foot Box Insulation installation.
    I was looking at that yesterday since my body is on the car, which is unpainted at this point in time.
    PS: Love The Color!
  10. #210
    Stevensville, MD
    DavidW,
    It was easy. After its unrolled it stays compressed long enough to fit it in the gap, reaching in the wheel well.
  11. #211
    Lilburn, GA
    Paint update. Sad to say I had a few issues. Paint sprayed great and so did the clear (in March). Problem was... didn't spray enough clear and sanded/buffed thru it. Needed more paint to touch-up. Picked up paint and resprayed. Started to buff and realized the color didn't match. It was a little darker, but noticeably so. Also had silver metal flake in the beginning......Touch up paint had blue metal flake. Ended up prepping/sanding entire car for repaint. Sprayed paint, went great, but the clear was not going on very well (in June). It was 90 plus degrees out and I believe my air compressor is too small and the moisture trap can't keep up with the humid conditions. Home garage isn't the cleanest environment either.
    I was pretty frustrated and ready to pay someone at this point. I tried to reach out to a few painters, to turn it over to them, but never got any responses. UPDATE: Jeff did get back with me...... THANKS! He was just out of town for a few weeks.
    End result, found out a friend has a paint booth. He let me in over a weekend, so I can spray and not interfere with his schedule. Also making a slight change in color. Still metal flake blue, just a little lighter. Realized if it ever needs touched up and I'm not in Georgia, I would probably have issues matching it. Its Mipa brand... not something everyone carries. New color Lighting Blue Metal flake, same as on a 2018 mustang GT. Pictures to follow.
  12. #212
    Lilburn, GA
    As I'm cleaning chrome, prep for final assy, I noticed the speedo bezel "chrome" is starting to blister/peal. Called Speed Hut and they are sending new ones out to me, no charge. The speedo and tack are both flaking.
  13. #213
    Lilburn, GA
    Ready to paint, AGAIN. My friend is letting me in over the weekend.
  14. #214
    Lilburn, GA
    Front Body Mount Brackets
    Can someone check their front body mount brackets please. See attached pic. Are your brackets the same width, or different like mine. FFR tells me their good as is, build it. I can't install the DS unless I slot the bumper bolt holes in the frame or the brackets.
    Note: My brackets are bent in different places...... are yours?
    David aka Ducky
  15. #215
    Nov 2012
    Tacoma, WA
    David,
    Those are not right just checked mine and they are both bent at the first notch up the leg or second notch from where the light mounts. I think the person bending them must of been first day on the job.
  16. #216
    Lilburn, GA
    Thanks Paul.
    Sent pics and talked to FFR....... After sending more pics (attached below), they are now sending me new brackets.
  17. #217
    Lilburn, GA
    New Paint
    I finished the paint, second time around. Looks great. Nothing has been cut/buffed yet in these pics except the hood. Amazed at how well it came out. A friend let me use his paint booth over the weekend. I hadn't sprayed a car in years. With his guidance, I think I did a pretty good job.
  18. #218
    Heart of Dixie, Alabama
    Very nice job!
  19. #219
    Lilburn, GA
    Very nice job!
    Thanks Joe, and thanks for sending $$ for the studs/shipping. You didn't have to.
  20. #220
    Looks fantastic.
  21. #221
    Nov 2012
    Tacoma, WA
    David,
    Nice paint love the blue. Glad it worked out for you that you could find a booth to do it in. Its good that FFR replaced the bracket for you.
  22. #222
    Lilburn, GA
    Thanks Paul and Steve.
    Apologies for sounding harsh in an earlier post (now edited) about the brackets. Maybe if I had sent better pics in the beginning, it would have been resolved instantly.
  23. #223
    Lilburn, GA
    Final Assembly
    Starting final assembly. Bad part, leaving town till Monday.
  24. #224
    Wow!
    Looks Better Than Ever!
  25. #225
    Lilburn, GA
    Final Assembly
    Finally completing the assembly. A few minor things to do. Need to add FFR and Ford Coyote badging and the front bumper hoop. Thinking about adding a grill. No scoop at this time, but I did paint it. Debating adding it.
  26. #226
    Looks great. The no stripe/no hood scoop makes it somewhat unique. Great looking color.
  27. #227
    Lilburn, GA
    Thanks Scott. The original AC Cobra's didn't have stripes or hood scoops. I also painted the side louvers, same as the original cars.
    Thinking about adding the grill. What do you think, should I?
  28. #228
    Senior Member Jdav's Avatar
    ATL GA
    Great job David
    MK4 #9028 - Coyote - TKO600
  29. #229
    Lilburn, GA
    Quote Originally Posted by Jdav View Post
    Great job David
    Thanks Joel. How is your's coming. Any paint yet?
    Now that I'm finished, looks like I might be going to Miami for the month of August. Maybe it will be cooler when I return.
  30. #230
    ATL GA
    It was in slick sand this week so shouldn’t be too much longer!
  31. #231
    Lilburn, GA
    Carpet around door latches
    What does your carpet look like around the door latch? NOTE: The carpet edging is sewn to the front side of the carpet but not the back yet. Wanted to verify fit first, in case I needed to trim it. The under door aluminum has a small finger extending up that is not the width of the gap between the body and the latch mount. I don't believe that I trimmed the cockpit rear corner sections when installing.
    Please share pics.
  32. #232
    That's not an easy place to make look decent. I'm not 100% satisfied with what I did, but it's not something that sticks out. The first picture below is the best one I have. You can zoom in on the area in question. I did binding on the carpet, similar to what you're working on. The carpet on the back wall will finish it at the top. That little finger on the sheet metal is (I guess) supposed to fill the open area from the inside of the rear wheel well. I made fill panels for the wheel well and cut those fingers off. Second picture. Once I was done, there was a gap between the body and the latch, but it's dark when filled from the other side. Plus I think mine is a little narrower than yours.
  33. #233
    Mine looks like yours on the driver’s side. The finger looks odd. Haven’t decided what to do yet. The gap on the passenger side is smaller and the finger seems to close it off ok.
  34. #234
    Lilburn, GA
    Thanks Paul, Steve. Both sides are about the same gap. I think I'll add some filler plates. Surprised the carpet wasn't long enough to cover it. I did add cover/fill panels in the wheel wells. Without them, you could see through into the cockpit.
  35. #235
    Lilburn, GA
    600 miles on the tires and I pick up a roofing nail. You can see by the angel that it’s too close to the sidewall (actually in the tread, out the inside of the tire, in the sidewall area). Couldn't plug! Several new roofs in my neighborhood, should have know.
  36. #236
    On a roll Al_C's Avatar
    Wheaton, IL
    David - the car looks great! My opinion - no grill, but that's just me. Sorry to hear about the nail in the tire, too.
  37. #237
    Stevensville, MD
    That area at the door catch is covered up when the door is closed but it is an eye sore.
    Here are some pictures, you cant really see but that small aluminum piece is visible. I might take some black silicon or some other product and fill it in. Good luck.
  38. #238
    Lilburn, GA
    Thanks for sharing DavidW. Looks like you found some extra carpet to fill the void.
    Made/added an additional pieces around the doors. Pic doesn't show.... I added a 90 degree bend with a 1/8" lip on the body side to stiffen it up.
  39. #239
    Lilburn, GA
    0-60 mph
    I tried the 0-60 feature. Second try was 3.83. Could probably do a little better. First try (4.4) was an easy takeoff, didn't burn tires. Second was a little hotter, but not too hard a launch.
    Anyone else try it out?
  40. #240
    Lilburn, GA
    Trans Oil Leak - Second Time
    Took a short drive yesterday and when I parked, I discovered that I again have a trans oil leak. I originally called Tremec and was told to use Permatex Anaerobic gasket maker, and did. As I'm taking it apart I discover that the little bit inside is still soft/gooey. The cases must be a really tight fit, couldn't see a dried film where the flanges meet. As recommended, I let it cure 24 hours before adding oil (the first time).
    Anyone else have an issue a second time?
