Likes Likes:  2
Results 1 to 20 of 20
Thread: Placement of turn signal switch
    I have the padded dash with glove box from factory five and I'm putting two and two together and realizing that if i place my horn button, ignition switch, and headlight switch in the three holes provided, I will have to find a spot for my turn signal/hazard switch. Any ideas???
    The 20th Anniversary edition on the FFR website photo gallery has the padded dash w/glove box. They mounted the horn, ignition and headlight control in the holes provided and mounted the turn signal toggle under the dash. You can see it in one of the photos. I assume the hazard switch is under dash as well. Not my preference but might be the best way to go since the other three holes are located and you cant control the spacing. I think FFR should cut the gauge holes but leave all the others blanked for personal preference.
    I always put them to the left of the wheel where you can easily reach it---I can activate my own without having to take my left hand from the wheel (it's actually a momentary rocker switch that triggers an electronic self canceling module). Here's a photo of one that I built for a customer that uses a momentary toggle for module activation:
    The first switch left of the speedo is turn signals, the other one farther to the left is high/low beam toggle.
    I've got mine just to the right of the wheel at about the 3 o'clock position on the wheel. I can activate it without taking my hand off the wheel. Since I just used the basic FFR switch(well upgraded to a chrome handle but same idea) that means I also have to turn it off. Since almost every time I am coming out of a turn I am taking my hand off the wheel to shift I have developed the habit pattern of just turning it off when my right hand is leaving the shifter and coming back to the wheel. Works pretty good for me. My first few drives I found I was constantly driving around forgetting to turn the blinker off. Now with associating it with the shift I am about 98% at getting it off before coming out of the turn.
    I am not saying I wouldn't enjoy a self canceling because I would but the positioning just to the right of the wheel where I can activate it with my finger tips is quite nice. Almost prefer that to the standard turn signal lever on the left in all my other cars.
    It is the one just above the horn button.
    From what I can figure, I need my turn signal switch, a hazard switch of some type, ignition switch, horn, light switch, anything else necessary?
    Wareagle what are the two red switches for?
    Quote Originally Posted by Usudno View Post
    Headlight high/low beam switch. Obviously a wiper &/or heater fan switch if you have them. Not absolutely required but I consider it a REALLY good idea to include a cooling fan manual override switch in parallel with the automatic thermo switch.
  8. Likes BlueMud liked this post
  9. #8
    One is the high beam, the other is the emergency flashers. We have those guarded switches in the airplane so I used those to go along with my fighter stick. Not particularly all that functionally efficient but I rarely will use either anyways.
    The only other hole I made in the dash other than what is pictured was for the Coyote MIL light. That is closer to my steering wheel.
  10. #9
    Mine is to the left of the steering wheel because that is where it is on most street cars. I have a toggle switch w/ a plastic extension which makes it real easy to operate w/ my hand still on the wheel.
    http://www.elecdirect.com/cole-herse...-long-handle-1
    http://www.elecdirect.com/cole-herse...xtension-black
  11. #10
    Senior Member smithbks's Avatar
    Mar 2014
    Atlee, VA
    Hey Jeff - not to take over the thread, but can you tell us more about the cancellation on your switch? I hate getting miles down the road and realizing my blinker is still on!!
    Mk4 #8340, 351w/427, 3-link, Wilwood 4 piston rear brakes, 3.27 gear, TKO600, delivered June 18th, 2014
  12. #11
    Quote Originally Posted by smithbks View Post
    Not Jeff (obviously ) but here's a post from the other forum where he described it. http://www.ffcars.com/forums/5613737-post7.html
  13. #12
    Jeff, I will not be running a heater or wipers. I will however need a high/low beam switch and a fan switch. What switches are you guys using for these?? I know the complete kit comes with a few switches.
    Thanks for the help. This is really helping clear up my dash layout.
    I think I'm set on the key to the left as well as turn signal switch. I would like to keep the 3 holes that are already cut into my dash for the horn, fan, and headlights. That leaves me adding one near there for the high/low selector and some sort of hazzard switch. I will probably run indicators for the left and right signals and a blue for high beams.
  14. #13
    Senior Member skidd's Avatar
    Jan 2016
    SA-TX
    I'm not done with my dash layout, it's only in mock-up at the moment.. but..
    I'm running metal toggle switches for everything (left-to-right) (main ignition, parking/head lights, fan, hazards).
    I got all mine from these guys (http://www.12voltunlimited.com/Switches_c_14.html) mainly because they were one of the few places I found that sold a off-on-on progressive DPDT switch for my headlights.
    http://www.12voltunlimited.com/Progr...itch_p_40.html
    Also, I'm going with a Push-Button Starter, and using a DEI PKE-2102T keyless entry module. No Ignition Key! Just get in and go!
    The starter button, ignition, headlights, fan and hazards will all be to the right.
    The turn-signal is a momentary toggle and will be to the left of the wheel.
    But. to answer your question.. this is what I use to switch my high-low beams.
  15. #14
    Everything you will need is included with the complete kit:
    SPDT ON/ON for headlight high and low
    SPST ON/OFF for the fan
    DPDT ON/OFF/ON for hazards; this one confuses some people. What is actually needed electrically is a DPST ON/ON but FFR has always included the DPDT, I suspect because a matching DPST is not available through their supplier. Simply wire it as if it were a DPST and leave the second pair of load terminals unused resulting in an ON/OFF/OFF configuration or redundantly connect the two load pairs to create an ON/OFF/ON. Either way works but keep in mind that you must use the double pole switch so that left and right turn signals remain isolated from one another otherwise they will cross feed.
  16. Likes BlueMud liked this post
  17. #15
    Raleigh NC, OIB NC
    I use a long metal handle toggle switch that is spring loaded to center (off). Its on the left side near the wheel.
    Kevin
    MKIV #8234
  18. #16
    Slide... I really like that setup for high lows... were did you get that switch?? My local auto parts store has a momentary switch similar but not a in off.
  19. #17
    Jan 2016
    SA-TX
    Not sure .. did you mean to ask ME that question?
    If so... this is the switch I bought. I got this one specifically, because it has a much shorter base where the spade terminals are. Thus, ensuring I had plenty of clearance between the terminals, and the aluminum side of the foot box.
    As it is, the wires just touch the aluminum, but it'll be fine since I will wrap them in plastic wiring loom.
    Not that really mattered, but had I gotten this one, then the wiring harness I used (speedway motors 12 circuit) would have fit clean since it had a compatible plug. Since I chose the other switch, I had to pull out the plug connectors, and wrap with shrink-tube and attach them 1-by-1. But.. that really wan't hard to do, and this one has much bigger base, so would have gotten a little too close to the side aluminum panel .. so.. meh.
    https://www.amazon.com/Standard-Moto...6422223&sr=1-4
  20. #18
    Yessir I meant you. Autocorrect got me! Thanks for the info!
  21. #19
    Sep 2015
    Beachside
    Quote Originally Posted by skidd View Post
    I did the same for mine, except mounted it closer to the floor. Reminds me of my old Mustangs...
    FFR #8833 289 FIA 3-link
  22. #20
    I placed my switch on the opposite side of the steering wheel as that mentioned by Jeff Kleiner, but the same principle. Easy reach from the steering wheel without having to look for it. My hands are at 4 and 8 o'clock on the steering wheel with elbows tight to the body. The switch is right there. Again, easy access.
    Jeff, I love the idea of using the electronic cancelling. That might be a good winter project. God I dislike working under the dash. How fortunate are you to have your own forum secretary. Heehee
