Results 1 to 10 of 10
Thread: Tko 600 speed plug
    Tko 600 speed plug
    Ordered a plug for the side of my tko, it did not come with a screw. Anyone know the screw size and pitch? Car is sitting on the ground and would be really hard to figure out at this point....
    Bueller????? Anyone???
    I have the TKO, but it is installed and buried in the car. I would suggest a call to Tremec.
    I just found one in my hardware bin that fit. I'm going to guess it was a 5/16, but cant say if it was 18 or 24 tpi. If nobody answers by this afternoon, I'll pop the bolt out n let ya know.
    I've purchased them from Mike Forte, and they came with a machine screw. You could call him and ask. 5/16 sounds right, and don't believe it's a fine pitch. Couldn't find any documentation that gives the thread size. Mine too is installed and buried. Here's a picture of one FWIW: http://www.speedwaymotors.com/Tremec...ns,107161.html
    Quote Originally Posted by Boydster View Post
    I use one of these almost every day I work on the car. Super handy
    INCH & METRIC BOLT GAUGE WITH THREAD PITCH GAUGE (L GAUGE) - 2 PIECES https://www.amazon.com/dp/B01GBZ1K4C..._o.Lszb3M8ECZZ
    Senior Member Jdav's Avatar
    ATL GA
    I can look at mine this evening, but I dont have a way of measuring if it is fine or course
    MK4 #9028 - Coyote - TKO600
    Delivery: 1/30/17 First Start: 7/23/17 Legal: 10/5/17 Graduated: 10/15/18
    Build thread: http://thefactoryfiveforum.com/showt...8-Build-Thread
    So. Bay (So. Calif.)
    Well... The Tremec manual shows a part no. of 99796-0616, but it doesn't give the spec. Go figure.
    ATL GA
    Her is the one I got from Forte with his speedo plug
    Looks like 1/4
    Thanks guys. I had ordered the plug from Mike, but I did not receive a screw.
