Looking for suggestions/recommendations on thermal barrier for foot boxes, floor boards, etc., ideas?
Kevin
MKIV #8234
This is discussed in dozens (literally) of threads. Here are a few. More links inside these. Even more on the other forum since it's been around longer.
http://thefactoryfiveforum.com/showt...ation-Question
http://thefactoryfiveforum.com/showt...sound-and-heat
http://thefactoryfiveforum.com/showt...our-engine-bay
http://thefactoryfiveforum.com/showt...-sound-barrier
If it's not too hard on your budget:
This for the engine bay side of the footboxes and firewall: https://www.summitracing.com/parts/the-13590/overview/
This for the entire inside of the cockpit, and underside of the tranny tunnel top (it will really quiet the car down): https://www.summitracing.com/parts/dyc-10455/overview/
I used this everywhere:
https://www.summitracing.com/parts/dei-050503
I went with the koolmat from breeze. It came precut and very accurately too. It is a little pricey but does the job. Attaching carpet to it was easy with silicone as it allows for movement to get the carpet in proper location.
JRL16
I used Dynamat. It does go on sell periodically at Jegs and Summit.
Doug
FFR 7995
347 SBF Prestige Mototsports, Moser 8.8 (3.31) 3 Link, TKO 600, Nitto 555s, 17" Halibrands, PS, AC, Heat, Color Redfire Pearl, with Wimbledon White Stripes
