Results 1 to 23 of 23
Thread: ********** 427 T5 Shifter
Hybrid View
    Does anyone know if the ********** T5 shifter will bolt directly to the Tremec TKO-600?
    https://www.**********accessories.co...le-427-t5.aspx
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Santa Clarita, CA.
    You will need to enlarge the two mounting holes. Other than that I love the shifter.
    Quote Originally Posted by CDXXVII View Post
    You will need to enlarge the two holes. Other than that I love the shifter.
    Awesome! Thanks for the help. I found a source for a weighted, polished stainless steel knob with the threads of my choice. I'll order the 1/2" x 20 and the shifter.
    Legal: 1/30/2020
    Raleigh NC, OIB NC
    Yes but you will need a smaller diameter bolt than comes with the FFR kit or enlarge the holes in the shifter. Went with thinner grade 8 bolts.
    Kevin
    MKIV #8234
    Senior Member christenfreedman's Avatar
    It will work fine! I wouldn't take time to enlarge the holes as you can just get smaller bolts and have them pass through rather than thread into the tko.
    Senior Member Yama-Bro's Avatar
    Jul 2012
    Kearney Nebraska
    I received the shifter for Christmas. It's a nice piece. I don't have the transmission yet to attach it to, though.
    Purchased Complete Kit 6/9/2017, Delivered 9/4/2017, Rolling Chassis 3/30/2018, Engine Dyno'ed 3/4/2022, Engine installed 8/27/2022
    Serial #9158
    So. Bay (So. Calif.)
    I didn't want to drill the shifter out, and I didn't want to through bolt it with a loose fit either. I'm out of town at the moment, so this is from my memory.
    The stub coming out of the turret (the rear one) has two threaded holes, I think 3/8. I got some threaded inserts from McMaster to put in there, that make the holes 1/4 (x28 I think, probably these https://www.mcmaster.com/#90259a136/=1b73y65 ). The holes in the shifter I believe are 5/16, so I pressed in bronze bushings, so the whole assembly is set up for 1/4-28 (maybe 1/4-20, I wish I could remember) bolts. I used Grade 8. They aren't going to break. Nice snug perfect fit.
    Santa Clarita, CA.
    Not intended to offend.
    I'm assuming we all built these cars so clearly we have tools.
    A drill and a drill bit equals a solid installation in less than a couple of minutes. I don't understand taking any other approach to this.
    What am I missing here?
    Nothing. I've done it that way twice. Simplest and easiest solution.
    Senior Member jrcuz's Avatar
    Stafford Virginia
    I also enlarged the holes and now it is very solid fit.
    JR
    No worries. I just didn't want to ruin a spendy part, or induce a weak spot, or whatever. Putting the inserts and bushings in probably took as long as drilling. Some say tomato, some say tomahto.
    Mine should be here tomorrow. Looks like it'll get to spend a little time on the drill press. I also got my shifter ball today. It is beautiful! ~400 grams of solid stainless steel, polished to a mirror (chrome) finish, with 1/2-20 threads ready to go into the shifter.
    Legal: 1/30/2020
    The shift lever arrived today and here is what it looks like with that stainless ball threaded on.
    Legal: 1/30/2020
    Santa Clarita, CA.
    Cool looking shift knob. One word of caution though. In California after a few hours in the sun it will be as hot as your side pipes. Perhaps the sun is kinder in Colorado.
    Thanks for the warning. Yes, the sun in Colorado is intense. Our temps are pretty mild, but I still use a sun shade in my other cars all year round. With the topless roadster, I'll go hi-tech and throw a towel over the seats and controls and will keep a set of driving gloves in the glove box.
    Legal: 1/30/2020
    Raleigh NC, OIB NC
    Found that the high tech beach towel work great. Put a few "zip-ties" in one edge & loop them over the control knobs on the dash. Covers the seat & console
    Kevin
    MKIV #8234
    I had the same shifter and a similar shift ball in my 20th Anniversary Roadster from Original Parts Group via Summit Racing. The shift knob does get a little hot in the sun I guess. But no worse than the black upholstery. Shift knob doesn't matter too much if you can't even sit in the seats. We also do the towel trick. I keep a couple in the trunk when the car's going to be out in the sun and throw them over the seats and center console. Especially 20-30-40 minutes before we plan to climb in and go somewhere.
    I love my shifter! I enlarged the holes
    Senior Member Mick40's Avatar
    Mass
    What is the difference between this sifter and the Factory Five one?
    Sorry for my ignorance, just curious.
    Mick
    Quote Originally Posted by Mick40 View Post
    Mick
    This is the one that comes with the kit.
    http://cdn8.bigcommerce.com/s-6661c/...882655.jpg?c=2
    I worked on fitting the shifter today. I enlarged the holes to 3/8" using my drill press. This the larger hole barely removed any material from the shifter, maybe 1/32 of an inch larger than the original hole. I then bought two 3/8"-24 x 1-1/2" grade 8 bolts to attach the shifter to the stub on the TKO-600. I then threaded on a couple of nuts to keep thing from moving. Perfect fit and rock solid.
    Legal: 1/30/2020
    Nice! Can I ask where you got the shift ball? Very cool piece.
    Quote Originally Posted by Straversi View Post
    Steve,
    Thanks! The shift knob was purchased from sweetknobs.com. I ordered through eBay, but they also work through their main website. They have quite a selection of knobs in different materials and finishes. If you end up deciding to order from them, PM me first. If you give them my e-mail address, you'll save $5.00 and I'll get a $5.00 referral as well.
    https://www.ebay.com/itm/Solid-Stain...72.m2749.l2649
    Legal: 1/30/2020
    Thanks, if I do, I will.
