8
So, I assume you intend for the mega fuse and PDB to be powered continuously. I used my cutoff switch as a true disconnect and it appears to work just fine and it has the added benefit of truly shutting of all power. It's nice when you are working on something and realize that your tool is getting a little too close to power circuits - just reach over and turn the key and everything electrical is off. Just a suggestion.
Bradley
