Likes Likes:  6
Results 1 to 28 of 28
Thread: Paint Protection Film
    Senior Member kobra01's Avatar
    Mar 2013
    Chino Hills, California
    Before I start driving my cobra I want to get Paint Protection Film installed across the front, top of doors and front of rear fenders. Any recommendations for installation near Chino Hills would be appreciated.
    Thanks, Ken
    MK4 Roadster # 8548, Ford Performance X427, TKO 600, 8.8 3 Link, Paint by Jeff Miller, Suspension setup by Frank Maslowski I.E.427
    RR20AC's Avatar
    Puyallup/WA
    I bought a large enough piece on amazon. Put some on the front lower corners of the front end. Not all over the front. My painter recommended just touch up paint for the chips. The corner protection is for hitting cones accidentally. Hit one and did its job. Top of passenger door piece for excited riders that flip the shoulder belt to the paint. Spats made out of them for rocks and dirt. Easy to make. Make a pattern with blue tape right on the area and transfer it to the 3M product, Cut, Install and your done.
  3. Likes Cobradavid, cgundermann liked this post
    Senior Member Geoff H's Avatar
    Edmonton, Alberta
    I used this for my Mk III. It has held up really well and saved countless chips. I heard a few years back they were developing a Mk IV kit - would be worth asking.
    https://www.autotrimdesign.net/Facto...ction_MkII.asp
    Geoff
    Nov 2012
    Tacoma, WA
    Quote Originally Posted by RR20AC View Post
    I did the same as Jim it worked out good and a lot cheaper. Jim more driving less writing.
  6. Likes RR20AC, cgundermann liked this post
  7. #5
    Mar 2013
    I got a quote from Octintshop in Orange County to do the front, top of doors and front of rear fenders. Are you ready for this! $1998. I guess I will be attempting this myself like you guys.
  8. #6
    It is hard to find a shop that will even want to do it as there is no premade pattern like they use for all production cars. This has to be a custom job and with basically the entire front being one curve to the next it is tricky to even find someone competent enough to do a really good job on the entire front end. I put some around the oil cooler opening and it has held up nicely.
    You quote seems in line with what I would expect. I paid about that for the front half of my 911 and the front of the rear wheel arches and that was working from a precut pattern.
  9. Likes Aircontroller liked this post
  10. #7
    How long has the paint been on? Don't even consider it until at least 90 days. That said...2000 bucks is ridiculous in my opinion.
  11. Likes cgundermann liked this post
  12. #8
    Member 7tvette's Avatar
    Sherwood Park, Alberta
    I had the front done half way up to the hood, spats and top of doors. 3M product done by a local shop. This was done 14 years ago. Took 2 days and $500.00. The shop owner swore me to secrecy never to tell anyone where I got it done because he never wants to do it again. Still looks fantastic. Do not use a power wheel on it though.
    Troy
    " The journey is the reward" Chinese Proverb
    FFR Roadster #5380
    FFR Spyder GT #030
  13. #9
    TMartinLVNV's Avatar
    Jun 2019
    Las Vegas, NV
    Quote Originally Posted by Geoff H View Post
    Geoff
    This is something that I would be really interested in. Hmm, wonder how difficult it is to install? Does it need to be shrunk with a heat gun like window tint?
  14. #10
    Senior Member NiceGuyEddie's Avatar
    The LBCeeeee
    https://premierarmor.com/clear-bra-p...otection-film/
    My friend shopped around A LOT and got his stingray done here.
  15. #11
    Edmonton, Alberta
    Quote Originally Posted by TMartinLVNV View Post
    No heat needed. Just soap/water solution, sponges, squeegee. At the time I had never done anything like it so hired it out. Now I have done a couple of cars and it so quite easy to work with. But the help of a friend makes it much easier.
    Geoff
  16. #12
    Senior Member Cobradavid's Avatar
    League City, Texas
    I seem to recall NiceGuyEddie used to have a drawing/pattern for the spats if you want to do it yourself.
    My Saving Grace: John 3:16
    FFR6687, Graduate #39 in the Class of 2009
    The Factory Five Forum March 2012 POM
  17. #13
    The LBCeeeee
    I indeed have a pattern for the fender spats. Prints 1:1 from a .pdf or dxf. P/M me for my email if interested.
    There once was a "free" share site to host files, I only wish it were still free.
    You can cut the cost down from a pro job if you do the fenders yourself, they are really easy.
    While we are on the subject, I had good luck with my SECOND go at spray bra. Lay it on thick and it will peel right off. It doesn't look perfect, but it's a great way to protect the nose if in the event you were going to take a long road trip to another state, etc.
    It's also good for a track day, if you are afraid to put tape directly on your paint this is a good under-layment.
    https://www.youtube.com/watch?v=fqXJ4DwhiqQ
  18. #14
    Mar 2013
    NiceGuyEddie thanks for the referral. I found them in google search and already asked them for a quote. Do you have a pattern?
  19. #15
    The LBCeeeee
    p/m sent to Kobra01 with my email
  20. #16
    Mar 2013
    Thanks Ed for sending me the spat pattern. Jeff your friend out here on the west coast painted my car over 6 months ago so I'm good to go. Got another quote locally and it was $1500. Guess I will try the fenders and door ledges myself. If I screw it up just peal it off, right.
  21. #17
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    Even with all the $$$ & labor involved with body & paint work... "Them's hard-earned battle scars".
    I'll take FFR's slogan "Built... Not Bought" to another level. "Driven... not Trailered". I've already got a serious DENT in the lower corner of the windshield frame from a big rock. An inch up & over would've been new glass. If I built the car to "flip", it'd be a different story. I built this one to drive.
    John D. - Minneapolis 'Burbs
  22. #18
    Jun 2019
    Las Vegas, NV
    I've tried to submit a question about updating their design to the Mk IV to AutoTrimDesign a few times but keep getting error messages. Are there significant differences between the front end of the III and IV?
  23. #19
    Senior Member NC Cobra's Avatar
    Mar 2019
    Getting ready to try autocross this spring so I thought I would see if anybody had tried the auto trim product on a mark 4 cobra. Also wondering how much of a job it is to remove this stuff if my first attempt goes poorly.
  24. #20
    Millis, MA
    I just found this stuff on Amazon,looks perfect for auto cross or track days.
    https://www.amazon.com/dp/B07F3DW4TQ...xpY2s9dHJ1ZQ==
    “Privateer”
    289 USRRC Chassis #9188 p/u 9/11/2017 Go kart 3/18/2018, road legal 6/16/2018
    Ford full roller 306 built by my son and me Holley Sniper EFI
    TKO600 2015 IRS 3:55. 17” FFR Hallibrand replicas, Power steering
    FFR Vintage instruments, Wipers and Heat/defrost
    Lots of parts and advice from Mike Forte & Mark Reynolds (Breeze Automotive)
  25. #21
    Millis, MA
    “Privateer”
  26. #22
    The LBCeeeee
    https://www.youtube.com/watch?v=fqXJ4DwhiqQ&t=1s
    The two products above look very promising for track days or a cross-country run. If you use the roll on stuff, be sure to lay it on thick, otherwise I'd suspect too thin a coating will result in my dilemma above....
  27. #23
    Mar 2013
    I had xpel ultimate plus paint protection film applied on my car yesterday. Very happy with the company in Corona that did it, it looks great and the price was very reasonable. If anybody wants to check it out your welcome to come to my house and see it. This is what they did. https://www.facebook.com/10000678369...6426097260151/
  28. #24
    May 2020
    Odessa, MO
    For those who may be considering Paint Protection Film, autotrimdesign.net now has a MKIV precut kit. Their prices are going up! I just paid $480 with shipping for the nose area kit. Michael, at auto trim design, says the install is pretty straight forward for someone who does this professionally and the install time is 2.7 hours.
    MK IV Base Kit #9370 w/ FFR Lower Control Arms, donor 1996 Cobra 4.6 L DOHC; stage 2 Comp Cams, Manley forged Pistons & Rods, IMRC Delete Plates, T-45 transmission HD extra build w/ single disconnect reverse mod, 3-link w/ Koni Coil Overs 3:73 rear end. Painted and re-assembled Jan 2022.
  29. #25
    Mar 2018
    I used 3M product from amazon. Installation was a struggle.
  30. #26
    Chino Valley, Arizona
    I saved the templates I made for the rear spats. If you do these yourself, I can copy these if you want...
  31. #27
    mburger's Avatar
    Punta Gorda FL
    Quote Originally Posted by kobra01 View Post
    I was quoted $2,500!
    Mark
  32. #28
    mburger's Avatar
    Punta Gorda FL
    Mark
