4
55
edwardb
Congrats on your kit receipt. Missing about 30 items in addition to POL items? That's a lot. I haven't had that many missing items combined in the kits I've built. Not to take anything away from what you're doing, but are you positive? What kind of items are missing?
I felt like it was on the higher side. Given this is my first build, its also very possible my inexperience in properly identifying items has led to the high number. I went through the whole list once and then went back to the boxes with the missing items and did them again while also validating there wasn't anything left over that I could be misidentifying. Granted, 1 of the items is a fastener pack and if you count that as one item it bring the list total down to 18. Currently my POL list is at 34 (down from 50). Here is my MIK list:
PART DESCRIPTION QTY BOX
25507 BRAKE LINE T ADAPTER, 2 FEMALE, 1 MALE 1 2A
16908 8' 16GA BLUE WIRE 1 2A
12470 QUICK JACK BENT LEFT 2 3A
12471 QUICK JACK BENT RIGHT 2 3A
15834 CHROME SIDEVIEW MIRROR 1 3A
14511 HUB NUT 2 14
13964 3/8"-16 NYLON LOCKNUT 2 18
13972 GAS STRUT BRACKET, 90 DEGREE BENT SHORT 2 18
15859 HORNS 1 18
17062 ALUMINUM DEFROSTER VENT 1 22
14949 TRACTION-LOK BRACKET FASTENER PACK 1 11B
10833 4 11B
13706 2 11B
13751 2 11B
10834 4 11B
13976 12 11B
10520 2 11B
13964 2 11B
13877 2 11B
12217 2 11B
12218 2 11B
13210 2 11B
13127 180 DEGREE THERMOSTAT SWITCH 1 19
16460 INLINE FILLER NECK w/CAP 1 19
10834 LOCK NUT, NYLON, 1/2"-13 4 4D
16703 1/2"-13 X 1.50" BOLT 2 4D
15439 T-5/TKO/TKX TRANS MNT PLATE 1 4D
13930 RADIATOR HOSE ADAPTER SET W/CLAMPS 4 4D
MK4 Complete Kit #10315 / Coyote G3 / TKX / 427 HardTop
Build Thread Production Date: 2/26/22, Registered 5/19/22, Graduated 3/1/2023
