Likes Likes:  3
Page 12 of 12 FirstFirst ... 2101112
Results 441 to 477 of 477
Thread: JJ's 818s Build
  1. #441
    Okinawa, Japan
    Looks beautiful! I'm trying to get a ballpark for total material used. I really like a few of VViViD's colors, but am not sure which roll size to start with. Thanks!
    FFR Build Status: Reset button hit
    '03 Subaru Impreza eSi RHD...because Japan
  2. #442
    Sep 2014
    Dallas, TX
    Quote Originally Posted by Maximus View Post
    60-70ft by 5ft wide. I originally ordered 50ft x 5ft and was just a little too short.
    818S Chassis #288 2.5L 323hp
    joshuajach.com
  3. #443
    That much? They usually sell 50-55 for a car with top. Did you make a few mistakes and needed to trash some pieces?
  4. #444
    Okinawa, Japan
    I've seen elsewhere that it is recommended to add 10-15% if you are new to wrapping over a professional job.
  5. #445
    Sep 2014
    Dallas, TX
    It was because of those recommendations that I got 50ft to begin with. The issue I found was that the side panels are very long and if want a single piece run front to back you'll end up with alot of useless material. I made one mistake with a front fender where I had to scrap some material, but to counter that I did not apply any of the base color material to the rear humps. Also I used 5 pieces on the rear bumper to be more conservative.
    In total I needed:
    60ft x 5ft blue (1 mid size mistake) no rear humps
    15ft x 5ft black
    10ft x 5ft orange
    2 x rolls of knifeless tape
    If your experienced at wrapping and conservative with the material then 50ft may be enough. This was my first attempt at wrapping and honestly my side pieces would not be considered "professional quality" had I not done it myself I would be taking it back to the shop for them to redo it. Which means I need more material on top of the list above.
    joshuajach.com
  6. #446
    Thank you for making me buy another 20ft. Good thing is TODAY ONLY Vvivid is selling at 20% discount with "LOVEDAY" coupon.
  7. #447
    Saint Charles IL
    Car looks great! I do have a couple questions on your build - 1) I ran through the pages real quick, I didn't see any details on the headlights - custom? 2) The outside door handles - what are they off of? What all was required to add them?
  8. #448
    Sep 2014
    Dallas, TX
    Quote Originally Posted by axelthrasher View Post
    1) See the "Old Headlight Thread" http://thefactoryfiveforum.com/showt...ts-(old)/page3
    2) Handles are from a Fiat. The install was very easy, almost as if they were made for this car.
    Handles: http://thefactoryfiveforum.com/showt...l=1#post208880
    Install: http://thefactoryfiveforum.com/showt...l=1#post208825
    joshuajach.com
  9. #449
    Sep 2014
    Dallas, TX
    Had an alignment and corner balance performed. Here's the specs.
    Driver weight: 140 lbs
    Tire Pressure: 28 psi
    Vehicle Weight (with driver & 3/4tank fuel): 2243 lbs
    LF: 509, RF: 473, LR: 648, RR: 613
    Cross weight: 50%, Left: 51.6%, Right 48.4%, Front: 43.8%, Rear 56.2%
    joshuajach.com
  10. #450
    south-central CT
    Really a great looking car with a lot of attention to detail. I wished I had of looked you up when I was in Dallas recently.
    Would you say you balance is typical? Seems some were lighter in the front?
  11. #451
    Sep 2014
    Dallas, TX
    I'm not sure what typical is for this car. In the front I have a sway bar, ABS module, standard lead battery, steel LCAs, reinforced hood, AWIC radiator, speakers. I've also added sound deadener mat all around the cockpit, rubber undercoating to all the body panels and some of the aluminum panels. Hitting the 818kg mark was not a high priority for me so there are a lot of places where I could lose weight/mass.
    joshuajach.com
  12. #452
    Kirkland, WA
    Cross weights are right on, I assume you are not going to track the car a lot ?
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
  13. #453
    Sep 2014
    Dallas, TX
    It will see track time Just not sure how much.
    joshuajach.com
  14. #454
    Sep 2014
    Dallas, TX
    Mondays Dont Suck Car Show
    I took the 818 out to a local car show Monday night, I got to walk away with their Best of the Month award!
    joshuajach.com
  15. #455
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    Quote Originally Posted by TouchStone View Post
    Very Cool!!!
  16. #456
    Freeport, ME
    Looks awesome! Congrats
    Dan
  17. #457
    Great award! Well deserved!
    Just noticed your rear tires are quite inside the fenders. You have 255s?
  18. #458
    Sweet!
  19. #459
    San Diego Ca 92106
    Well done! It validates your awesome build.
  20. #460
    Mar 2015
    Houston, Tx
    That is too cool! Well deserved.
  21. #461
    Sep 2014
    Dallas, TX
    Yes they are 255s I also have 5mm spacers all around.
    joshuajach.com
  22. #462
    I'm impressed, I have 265s without spacers and they barely fit, will probably rub (fender-wise).
  23. #463
    Bowling Green, KY
    Man your car looks great and a ride to be really proud of, congrats.
  24. #464
    Sep 2014
    Dallas, TX
    Time to move on to bigger and better projects!
    For sale at: http://r.ebay.com/mFjASd
    joshuajach.com
  25. #465
    nice you got the obligatory car show plaque. next stop is one of those creepy leaning dolls.
    selling already? you didn't even get a full summer of driving out of it.
    GLWS
    edit:
    "Hybrid 2.5L Subaru Boxster STI "
  26. #466
    Sep 2014
    Dallas, TX
    GLWS
    edit:
    I want to build another kit, maybe a 65 Coupe. Its taking up my garage and selling it would help fund the new project!
    joshuajach.com
  27. #467
    I'm disappointed, your car looks really awesome. But in the end it's a matter of progressing in your fun and projects, so I support your sale.
  28. #468
    Sep 2014
    Dallas, TX
    joshuajach.com
  29. #469
    Administrator
    Enterprise Alabama
    Looks great Josh
  30. #470
    Mar 2017
    SW Ontario
    I'm interested in how much you put into it (both hard cash and time) vs. how much you sold it for. It's generally accepted that all kits are money losers unless you can turn them over very efficiently.
  31. #471
    Sep 2014
    Dallas, TX
    Quote Originally Posted by CdnCarNut View Post
    That's difficult to answer. I think you need to decide whether you are building a kit as a hobby or as a business. I believe if your build it as a hobby then your time should not be factored into the price as its for enjoyment or a learning experience. If your trying to turn a profit you would need to come up with a build model that minimizes build time and parts cost while maintaining a high standard of quality. While the latter of these would be interesting to design I personally would not want to actually take part in the actual build/s.
    To answer your question about my build cash cost plus time cost was around $55K-60K. Cash cost only $35K-$40K. Since I built it for fun and learning and got to do some autocross and driving afterwards I think it was well worth it. I should also mention that this kit introduced me to a number of great people and new friends; introduced me to autoX and track days; I'm now building a Spec Miata racecar and doing the build out myself; I also perform all the service on my daily driver. If you consider all this then I definitely came out ahead.
    joshuajach.com
  32. #472
    Senior Member DSR-3's Avatar
    San Jose, CA
    Like (most) race cars (or kit cars), don't expect a good $$ return on your investment- the fun factor in building and driving it is the best you can do.
    I used to try to make myself feel better about my race cars by considering what the "arrive and drive" or rental types pay for a weekend. At those rates, you can justify a lot of the costs of building or buying if you do a even a few races per year. 'Agreed on the benefit of meeting great people along the way!
  33. #473
    How did you factor in the time cost? 50/h? You built fast!! At that rate, my time cost alone is 165k! lollll
    You really did an awesome job on the wrap quality, too bad I couldn't pay you to do mine.
  34. Likes Canadian818 liked this post
  35. #474
    Sep 2014
    Dallas, TX
    How did you factory in the time cost? 50/h? You built fast!! At that rate, my time cost alone is 165k! lollll
    165K! Thats a 18 month 9-5 job! I just guesstimated the time at ~600hrs. It seems reasonable but I could be off by quite a bit. I stopped counting hours after the 2nd week.
    joshuajach.com
  36. #475
    Yeah 1.5 years full time, at the minimum. Then if I take your way of calculation, I'm off the charts. lolll But that being said, your wrap is astonishing and the buyer has to take that into account. That work alone is worth a lot of money.
    And yeah you did build fast! Sticking to H4 saves a lot of time.
  37. #476
    San Jose, CA
    Loving the colors, and planning to try to wrap my car as well, so you and Frank are clearly inspirations to follow when I get to that step. On the black and orange, how do you apply the different colors? Would love any tips you have there on getting the seams right when you do that too.
    Sep 2014
    Dallas, TX
    Miata Project Report
    Quick update on what I've been doing:
    About a year and a half ago I bought a 92' Miata and have been building it out for Spec Miata racing. The build is now finished and I've been running the car mostly on HPDE track days. Last month tho we took it out for its first competition event a Champ Car endurance race at Harris Hills Raceway. During race 1 of 2 we had the engine blow out spectacularly, complete with fireball under the car. Our team spent the entire night successfully swapping the engine. On the next day, second race, we ended up 9th of 42 overall and 5th of 17 in our class. I'm super excited and looking forward to running more events.
    I've got build photos and videos from various track events on my youtube channel.
    https://www.amazon.com/photos/share/0OUqztB5Ganwn2DybZOOx04A8SlvsOu0DKbtWqGyyAQ
    https://www.amazon.com/photos/share/...mhMveYuGBr7sGC
    Car on the day I picked it up. Paid about $1,600
    On grid for its first competition race.
    joshuajach.com
  39. Likes Mitch Wright, Canadian818 liked this post
