My stack of boxes and body parts looked like every one's did. That is why I am going to try and focus on the things I am doing to make this like no other 33 Hot Rod in the world. Isn't that what it's all about. Shortly after placing the order for my 33 kit I started building a truly one of a kind intake manifold to cap off the 427 Ford Racing small block I had ordered. Why is it unique? Not only does it have 8 stacks like a normal setup but in an effort to make it more friendly on the street I added 2 primary stacks in the center of the engine to be used for idle and cruise. These 2 small stacks feed a sub manifold system that go underneath the normal system. Will it work? So far it has only been on the dyno with apparently good results but the real proof will be in the driving. Hoping to get it done this spring.
