Page 8 of 9 FirstFirst ... 6789 LastLast
Results 281 to 320 of 344
Thread: San Diego builds, One the easy way, one the hard way
  1. #281
    Feb 2014
    Ramona, CA
    The dashboard is done! I really like it now. It holds my phone, Accessport, has USB, etc. For the gap between the sheet metal and the plastic dashboard, I designed, then 3-D printed, a piece that has the 818 logo and backlit with red leds. Now I can see all my switches and plugs at night. The sides are wrapped with carbon fiber vinyl, and the front is anodized black. It was one of those projects that went on for months.
  2. #282
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Slick! Looks like you got the Race Logic traction control all hooked up. How is it working for you? I'm just about done with my wiring harness.... the only factory wires left to add are the four pink injector wires and I saved those for last since they splice into the RLTC system. That digital adjuster looks really nice.
  3. #283
    great job on the dash console Matteo.
    I can se you put a lot of time into it.
  4. #284
    Feb 2014
    Ramona, CA
    Thanks! No unfortunately the race logic is no working yet. The system is not seeing one of the abs sensors. I've done all the simple checks; sensors are working fine. It almost seems like the bad sensor is moving around the car!? I've build an old lap top to run the race logic software under Windows XP. I will hook that up as soon as I get a gender bender. Long story.... The db9 cable ends at the most inconvenient place possible on the 818. So I ordered a DB9 extension cable but got the wrong genders. Argggg! I want to look into all modes of failure before I make the call for help over the pond.
    I really need the traction control working; the temp is dropping and the colder air, tires, whatever, is causing more power in the mornings. It will now spin the tires in third gear as the turbo kicks in.
  5. #285
    Denver, CO
    Quote Originally Posted by matteo92065 View Post
    Did you run shielded cable for your abs?
  6. #286
    Wow!! That's a really nice fighter jet!!
  7. #287
    Feb 2014
    Ramona, CA
    I know... Right! Thanks.
  8. #288
    Feb 2014
    Ramona, CA
    Yes I'm using the shielded cable from race logic taping into the Subaru twisted pair wires. Abs works fine. Sensors seem to be working. I have 3/4 reading correctly to the race logic display. Just don't know what's wrong?
  9. #289
    San Jose, CA
    That is a very serious looking dash! very nice job on putting it all together.
    Senior Member AZPete's Avatar
    Wow on the dash!Nice work.
  11. #291
    Hindsight's Avatar
    Atlanta
    While hooking mine up, I noticed what appeared to be an inconsistency in ABS signal wire color. From the research I did, the signal wire is always the white wire, but that's the white wire on the SENSOR side of the plug. On the ABS side of the plug, the wire colors were not always the same or even consistent (side to side, front to back) on mine. For example, one side of my car uses green and blue twisted pairs, and the other side used black and white. On the side that uses black and white wires, the signal wire color went from white to black as it passed through the ABS sensor connector in the front, and stayed white to white in the rear. Since I haven't turned mine on yet, I can't say that this is right but I'm pretty sure it is. You might check that out on yours.
  12. #292
    Feb 2014
    Ramona, CA
    That is a quick and easy test that I did not think of, Thanks! I'll try it this week.
  13. #293
    Hindsight's Avatar
    Atlanta
    Let me know if it works. You can see the wire color on the ABS side of the sensor just on the other side of the plug before it goes into the wire loom. It really made me scratch my head when I saw it.
  14. #294
    Feb 2014
    Ramona, CA
    I did this on Sunday morning: http://thefactoryfiveforum.com/showt...ars-and-Coffee
    It was nice meeting a couple of car fellas.
    On the way back I took a quick and dirty video of the dual temp intercooler gauge. Green needle is post IC, Red is pre IC. Engine was fully warm, pull was from 0 to ~80mph, up hill.
    https://youtu.be/DkB9QnhzHTE
  15. #295
    Denver, CO
    Looks great!
  16. #296
    Mechie3's Avatar
    Nice video. The green needle hardly moved.
    Zero Decibel Motorsports
  17. #297
    Feb 2014
    Ramona, CA
    And now it rained on my car! I always check the weather before I drive the 818 into work, and it was not going to rain!
    The cover worked great. Car was dry inside.
  18. #298
    Denver, CO
    I need one. Where did you get it?
  19. #299
    Then if it wasn't supposed to rain, how come you put the rain coat on it anyway?
  20. #300
    Super Moderator
    Ray's Avatar
    La Mesa, California
    See all those trees?
    Packed full of crows off and on during the day.
    Ray
  21. #301
    Feb 2014
    Ramona, CA
    Quote Originally Posted by Ray View Post
    Ray
    LOL,
    It's not a rain coat, it's strictly to protect the interior from the sun, falling stuff and help keep people honest. But it did keep the car dry.
    I'll get the name and link of cover tomorrow
  22. #302
    Leesburg, VA
    One of these perhaps?
    http://www.amazon.com/dp/B001S2XOB6/
  23. #303
    Feb 2014
    Ramona, CA
    Yes, that is it. thanks.
    I tried ordering from Amazon and they were out of stock. I ordered direct, and actually got a call back asking "Its going on what?". I explained a little about the 818.
    It could fit a little better on the 818, but I'm very impressed after yesterdays wind and rain. It stayed on and kept everything dry.
  24. #304
    Denver, CO
    It isn't the one for the mr2?
  25. #305
    Feb 2014
    Ramona, CA
    I'm pretty sure I got size "C14" to fit Porsche Boxster as seen here, http://www.capoptop.com/size.htm
  26. #306
    Feb 2014
    Ramona, CA
    "The HARD way" update
    The Hard way car is getting a body now.
  27. #307
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    Whoa! Neat!
    Tamra
    First autocross 3/29/15
  28. #308
    Hindsight's Avatar
    Atlanta
    Wow! Are you rolling all that on an English wheel?
  29. #309
    Mechie3's Avatar
    Finally I see pics of what you told me about almost a year ago! Are those BRZ headlights?
    That looks sweet!
  30. #310
    Feb 2014
    Ramona, CA
    Yes, English wheel and lots of other sheet-metal tools.
    The entire body will be hand formed aluminum.
    Yes, BRZ headlights.
    I don't have a thing to do with the body. I'll be watching it just like all of you.
  31. #311
    Puyallup, WA
    Do you have a rendering of the final goal? Id love to see the what you had in mind for the rear end.
  32. #312
    Mechie3's Avatar
    Note to self: If you ever move to SD try and get a job working for Victor.
  33. #313
    Denver, CO
    I want to see inside of hard way. I liked what you were doing with it.
  34. #314
    That's an 818? A "hard" one I guess.
    Note to Craig: if you ever move out of IN, you won't be able to register your car before you finish building it and you will have to comply to regulations. lolll
  35. #315
    Feb 2014
    Ramona, CA
    Part of building a car is testing it.
    I went for a long hard drive yesterday. It was awesome!
    https://youtu.be/WHqoVPTuNQ8
  36. #316
    Apr 2014
    Shelton, CT
    Beautiful drive!
    Tamra
  37. #317
    Edmonton, Alberta
    Great video
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  38. #318
    Hindsight's Avatar
    Atlanta
    Very nice! I miss California for the epic drives (and the weather that enables those drives).
  39. #319
    USA
    Matt, great video. The different views, including the suspension at work, are awesome. Nice job!
  40. #320
    San Jose, CA
    Thanks for the video, very nice. Do you have any more photos of the interior? I'm beginning to think about ideas, and I like the red glow on under the shifter.
