Two issues here: first - whether I upload my photos right side up or upside down, they come out upside down. What's up with that? Obviously, I am photographically challenged... Photos were taken on an iphone, emailed to myself, saved to hard drive, then uploaded to forum gallery. Finally, I got tired of screwing around trying to get them to show up correctly, so hopefully you can right them in your mind. I'm not asking you to stand on your head, although if you find that entertaining, go right ahead.
On to the issue at hand. Two (upside down) photos here. The fill plug on my IRS center section is not cooperating with my attempts to remove it. What I have done so far:
a) tried a breaker bar: no movement.
b) WD-40 then a breaker bar: no movement.
c) scratch off paint from around the plug, WD-40, Impact wrench: no movement.
d) (latest attempt) WD-40, compressed air spray (keyboard cleaner), Impact wrench: no movement. (after a minute or so, the can freezes up and no more cold air comes out...)
Upon close inspection, you'll see that the edges are starting to wear. Not good. Obviously, I want to get this thing off without completely stripping the plug. Any suggestions on next steps?
