Moonlight Performance
If all you are bonding are metal clips for wiring harness, you don't need to get crazy. Chad posted a good solution that I saw Glyn bump within the last week. It was small metal tabs that accept a zip tie. He also posted a two part quick cure glue that works well on nearly any surface. I am using the glue and tabs and they work great. No soecial tools needed. Sorry I cant remember the name of the glue but it is by loctite and is in his post.
Edit, found it: http://thefactoryfiveforum.com/showt...-tips!-Sharing
