Results 1 to 12 of 12
Thread: Cleaning Injectors (Possible?)
    Senior Member mistasherm's Avatar
    East Central PA
    I removed the intake and fuel rail systems in order to install a better (outlet location) coolant crossover pipe and have been taking this opportunity to clean some of the other parts. I would love to replace the donor fuel injectors but that is currently not in the budget. Is there a way to clean (or soak) the injectors while I have them removed? My donor is a 2004 WRX.
    Sep 2014
    Dallas, TX
    818S Chassis #288 2.5L 323hp
    joshuajach.com
    Reno, NV
    818R Build date 10/31/15
    Nov 2015
    When you get your engine back together and running, I suggest you use Techtron from Chevron you can pick it up at any auto parts place. My brother-in-law helped develop this product and he put it to the test before approving it and it cleaned everything. I use it in by gas tank every time a change the oil and there is a tremendous difference in performance and gas mileage. It cleans your injectors.
    Muggs
    East Central PA
    Quote Originally Posted by TouchStone View Post
    TouchStone
    Thanks - that's a great idea.
    I cannot recommend DW due to very poor customer service. A new set of blue rebuilt injectors they would not warranty. Two over fueling and fouling plugs. After numerous emails to Every body at DW they Finally sent me a new set of the Bosch injectors. Put them in tuned and fouling issues are gone. But I had to go to the top. Customer beware!!
    http://witchhunter.com/ is great as well.
    also +1 with the techron. I drop a bottle in the tank a week before oil changes.
    East Central PA
    Great information, thanks. I will look into a few of these and see what my options are. I am definitely a Subie Noobie and this project has me delving into the motor and wiring aspect further than I have in the past.
    south-central CT
    I found this informative: http://forum.miata.net/vb/showthread.php?t=14390
    A thoughtful guide to DIY.
    TMI? I am a curious guy. I love ultrasonic cleaners...
    Nepa
    https://www.injector.com/ Ive used marrin a few times. excellent turn around and service. also used ID to clean there own injectors thought that only made sense.
    I cleaned the injectors myself: used a homemade switched harness and then a large "feed store" syringe to pressure supply the cleaner to the injectors.
    Virginia
    I put this in my silverado and noticed a drastic improvement >> http://www.autobarn.net/stp-concentr...g_shopping.com
