Results 1 to 4 of 4
Thread: Positioning the CNC 1483 Reservoir
    Huntsville, AL
    Guys,
    I'm trying to locate the post that shows the dimensions for positioning the CNC triple reservoir. The post showed how far the reservoir top can be positioned below the 3/4 bar and the maximum distance it can be positioned from the DS front foot box panel. Does anyone have a link to that post or can anyone answer the question for me?
    FYI, my engine is a coyote w/o power brakes.
    Damien
    Senior Member Jdav's Avatar
    ATL GA
    No dimensions, but here is WarEagleScotts post about it:
    http://thefactoryfiveforum.com/showt...l=1#post245195
    EdwardB's build thread may have info as well
    MK4 #9028 - Coyote - TKO600
    Santa Clarita, CA.
    Thread is in the other forum.
    Here
    http://www.ffcars.com/forums/17-fact...ml#post2500078
    Another thing to keep in mind. Make sure the reservoirs are level to the ground when at ride height.
    Turns out where I put it the engine oil dipstick is tight against it coming in and out. Works ok but if I were to do it again I would move it forward about 1/2-3/4" for the coyote.
