16
4
Top Notch Builder
Jeff Kleiner
I actually have a Gen3 Coupe chassis sitting on it right now. The dolly measures 60" long and 38" wide and needed no modifications to accommodate the Coupe chassis.
what is the measurement from center to center of the two indentations where the frame sits?
Thanks Jeff for the help
Another question for the community.
The supplied brake reservoir I believe is a single reservoir and uses a T between the 2 master cylinders. Am I safer buying a dual reservoir such as this? Is my conclusion correct that this would make the front and rear brake systems truly independent of one another or am I missing something?
https://www.polyperformance.com/cnc-...IaAmRNEALw_wcB
