Results 1 to 15 of 15
Thread: Kirk Seats issue
    Dec 2018
    Kirk Seats issue
    Are they supposed to sit at a slight angle? Our client wanted the seat track for adjustment, but the only way for it to work is at an angle. the steering wheel and petals are offset slightly so the seat kind of lines up with them
    Grand Rapids, MI
    Yup, The seats are angled. They sorta follow the transmission tunnel.
    Jim
    Dec 2018
    Quote Originally Posted by Jim1855 View Post
    Jim
    Ok Thanks Jim.. I thought maybe so
    I recommend that you make sure the client is informed that the Kirkey seat is designed to be used with a brace in the back, so will be significantly compromised if mounted with tracks and no brace. Fine if that's what they want, so long as all are aware.
    Quote Originally Posted by mikeinatlanta View Post
    Precisely! The backs are pretty floppy without the rear mount, which is not compatible with tracks.
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    If your client wants that style of seat, consider the Ultrashield cobra bucket. I'm using them on my build, and they are very rigid and don't require any sort of rear mount.
    Senior Member john42's Avatar
    Aug 2020
    Hollis, NH
    I put tracks under my Kirkeys and made 2 aluminum spacers that I bolt in for the back support depending on if I am driving or my wife is driving. It's cumbersome but not terrible. Better then unbolting the seat completely to switch drivers.
    MK3 Challenge Car, Boss 347, Sniper 2 EFI
    Grand Rapids, MI
    I have the Kirkey 65 Series seats, their seat mounts, and Sparco seat tracks. Will build some form of adjustable back brace. No expectations that it will be real convenient.
    From what I've seen the Ultrashield seats are very good.
    Jim
    Never heard of Ultra Shield before. They look nice. Much nicer upholstery that Kirkey. Please send photos of your car when you get them installed.
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Yes, the stock upholstery is nicer than what comes on the Kirkey's but I did have them reupholstered in leather. They're not permanently installed yet, but you can see what they look like reupholstered in leather here.
    Mike, Jeff, John, and the others that have responded-
    Can you tell me a little more about the brace that you are supposed to use on the low back Kirkey's?
    I have a set, although not installed, and I had not been made aware of the need for a brace in the back.
    Thanks in advance; and as always I appreciate y'all and your guidance and assistance!!
    Steve,
    Here is the mount:
    https://www.kirkeyracing.com/product...65-SERIES-SEAT
    And the installation guide:
    https://www.kirkeyracing.com/images/...ide%281%29.pdf
    Although I confess that when I have installed Kirkeys I have used the floor brackets but fabricated the rear mounts (50 bucks seems a little salty )
    Aug 2020
    Hollis, NH
    I have high back racing seats, but that concept is the same.
    Steve,
    Here is the mount:
    Jeff-
    Thanks for the quick response, and all the good info! I like the idea of fabricating my own mounts; I may have to give that a go myself!
    I appreciate the assist -- again!!
    Grand Rapids, MI
    Just a comment/question on the Kirkey's being "floppy".
    I have the newer 65 Series seats. These are a 2-piece with a seat & back that is bolted together and adjustable for height. Kirkey has also added a formed angle/corner braces that wrap from the side to the back. I don't believe that this was part of the earlier 47 Series seats.
    I do know that Kirkey recommends the back brace and will fabricate and install something but have yet to understand where the seats are lacking support or strength.
    Insight appreciated.
    Jim
