Thanks Thanks:  6
Likes Likes:  7
Page 7 of 8 FirstFirst ... 5678 LastLast
Results 241 to 280 of 285
Thread: Ducky2009 MK4 Build #9035
  1. #241
    Lilburn, GA
    David - the car looks great! My opinion - no grill, but that's just me. Sorry to hear about the nail in the tire, too.
    Al, I have a friend with a water-jet machine and he is making the grille parts for me. I still have to make the perimeter loop and weld it all together. Was originally going to make it from aluminum, thought I was going to mill the slots where it fits together. He suggested making it from SST and has some extra on hand. He thought it would look better, nice and shinny and it would, but told me I'd have to do the polishing. LOL. Pics to follow, but it will be a while. I'll be in Miami on and off until the middle of Nov. I'm retired but contracted to do some consulting work for an aviation company in Miami, and it happens to be 15 minuted from my 2 year old grandson. Couldn't pass it up.
  2. #242
    Lilburn, GA
    Carpet around door latches
    I ended up adding plates around the door latches. They're only visible when the door is open. As Paul suggested, I added plates in the wheel well. Also added edging to the carpet. The PS bulb seal is showing more than the DS. I'll try to adjust more.
    Trans re-assembled. Hopefully no more leaks in the future.
    Still need to add bulb seal around the hood and doors.
  3. #243
    Lilburn, GA
    Took a short ride on a cold day (55 degrees). Zero traction.
    https://youtu.be/7oHaXhmEFS0
  4. #244
    Lilburn, GA
    I was out of town for 2 weeks and when I came home, the Roadster would not start.... A dead battery. I charged the battery overnight. The headlights were bright but the car wouldn't start. Thought it was the starter. Tried using jumper cables to the starter after removing it. Solenoid engaged but the gear didn't turn. Was ready to buy a new starter. A friend suggested I use a different car and try again. Starter worked fine.
    Turns out the battery wasn't putting enough AMPS out. Powermaster starter's don't work with a weak battery.
    Moral of the story: I added a trickle charger for when I'm away.
    EDITED:
    Ending up discovering my radio was causing a drain on the battery. With the key (and master switch) off, the radio lights would be glowing. Removed the radio, added a blue tooth receiver and an amp. Now use my phone for music.
  5. #245
    Thanks For The Suggestions!
    We just got back from a recent trip as well.
  6. #246
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    I have two of these, and fully endorse them Battery Tender Plus
    I use one on my El Camino, and the other on the boat battery (when it's pulled for the season).
    John D. - Minneapolis 'Burbs
  7. #247
    Jan 2018
    I have one of the multi-head battery tenders on my wishlist to maintain the batteries on all the garage toys.
  8. #248
    Lilburn, GA
    OIL FILTER for a 2017 Coyote
    Just started to charge my oil. Problem is, I was told the engine is the same as a Mustang. That new filter is a Ford FL500S, and it hits the frame. It’s approx 3/4” longer than the one that came on the engine. I called Ford Racing, where I purchased the engine, and they are telling me the short one that came on the engine shouldn’t be used at all. Only installed to ship the engine and should be removed and replaced. They suggest using a remote setup, which I have, but didn’t use because it fit as delivered.
    How many people have used the supplied one?
    How many have used the remote filter?
    David aka Ducky 2009
  9. #249
    I have used the short one that fits. On my third one now. First I have heard about this.
  10. #250
    Nov 2012
    Tacoma, WA
    I am using the Ford one that came with the engine and have 800 miles on it no problems. Will be changing oil at 1000 using a Mobile one M1-113 filter it is the same size as the one that came on the engine. I believe Edwardb posted it in his roadster build. I am not using a remote oil filter myself. I think the smaller on is fine especially with most roadster owners who will take extra care of their cars. I plan to change it at 3000 miles where as a lot of OEMs suggest changing at 7-10k now days. This is from the owners manual for a 2017 Mustang GT 5.0
    When to expect the message prompting you to change your oil
    Interval Vehicle use and example
    7000–10000 mi (12,000–16,000 km) Normal
    Normal commuting with highway driving. No, or moderate, load or towing. Flat to moderately hilly roads. No extended idling.
    5000–7000 mi (8,000–11,999 km) Severe
    Moderate to heavy load or towing. Mountainous or off-road conditions. Extended idling. Extended hot or cold operation. High engine speeds and loads, engine braking and hard cornering.
    3000–5000 mi (4,800–7,999 km) Extreme
    Maximum load or towing. Extreme hot or cold operation.
  11. Thanks Ducky2009 thanked for this post
  12. #251
    Lilburn, GA
    Quote Originally Posted by Paul2STL View Post
    ....... Will be changing oil at 1000 using a Mobile one M1-113 filter it is the same size as the one that came on the engine.
    Thanks Paul
    I picked up the Mobile One M1-113 and it fits. The FORD FL500S filter was about 3/4" longer and wouldn't fit (hit the frame). Took the factory supplied one to a Ford dealer and they didn't know what it was. The number on it wasn't in the books.
    The pic is showing clearance with the filter installed only a 1/2 turn.
    Scott, not sure what P/N you were referring to when you said the short one.
    FYI... I looked at the remote filter kit supplied with the kit. It doesn't fit the engine filter mount (different size threads).
  13. #252
    The same one you called the short one.
  14. #253
    Lilburn, GA
    Clutch Cable - Broken
    1,000 miles and now have a broken clutch cable. I know others have had this same issue, but can't remember who. Someone listed the Ford P/N but I can't find it. I also remember someone saying Forte has one. I looked it up. The definition says it's NOT adjustable. Not sure how well that fits.
    Please chime in and tell me if you had issues and how the new one is holding up.... and where you purchased it.
  15. #254
    Highly recommend the Ford Performance M-7553-C302 adjustable cable. It's what I installed in my first build Mk3 now almost 10 years ago and still working fine. Many others recommend it as well. Widely available for around $50 and a high quality piece. I personally haven't used the one from Forte, but understand what he's selling isn't the adjustable version.
  16. #255
    Lilburn, GA
    Thanks Paul. I found one locally and installed it. I purchased my engine, trans, CLUTCH, etc directly from Ford Racing. I always thought the heavy duty clutch was just harder than normal to push. I'm amazed how easy it is to push now. The new cable has nylon (or similar material) ends.
    Also, the old cable is .120" diameter cable. The new one is .145"
  17. #256
    Lilburn, GA
    Oil Cooler Opening - Screen Covers
    I purchased an oil cooler opening screen from Breeze. First off - It was exactly as described on their web site.
    My issue is the size of the screen mesh compared to the brake vent screens that I received from FF. The FF screens have a smaller mesh opening. I ended up making my own, using steel wire mesh, powder coated (black). (vs Breeze - aluminum). Not exactly the same mesh size, but as close as I could find.
    If anyone would like to purchase the Breeze screen, I'll make you a deal. Cost was $35, plus $9 shipping. Will sell for half price, $22, including shipping.
    If you want a steel on, I'll make you a great deal on one of those too! PM me.
    Edited: The third and fourth pics are the ones I made.
    Oil Cooler Screen - Breeze.jpg Oil Cooler Screen - Breeze - Comparison.jpg Oil Cooler Screen - Home Made.jpg Oil Cooler Screen - Home Made - Comparison.jpg
  18. Likes SerpantFL liked this post
  19. #257
    Senior Member cv2065's Avatar
    Dec 2017
    I experienced the same thing. Great quality and service from Breeze as usual, the screen size doesn’t align with the FFR ones and I like the finer mesh. Have a picture of the steel ones you made?
  20. #258
    Lilburn, GA
    The third and fourth pic are the ones I made.
  21. #259
    Dec 2017
    SW Fl
    Dave, nice work, I also prefer the ones you made. I think the slightly finer mesh will keep those stones from damaging the cooler...
  22. #260
    Lilburn, GA
    Brake and Oil Cooler Mesh Screen Covers
    Anyone need Brake and Oil Cooler mesh screens? I have a few sets.
  23. #261
    Lilburn, GA
    Bought a new Hot Rod!
    I'm finishing up my MK4 and wanted a new hot rod. Found one. LOL
    I have 11 grandkids. Thought they would enjoy this one.
  24. #262
    Nov 2018
    Beautiful color choice! Keep up the good work!
  25. #263
    Nov 2012
    Cool little hot rod for the kid.
  26. #264
    Lilburn, GA
    Four Corner Weight
    Took this down time to make some more progress on the car. Completed the four corner weights.
    The first scale pic is weights pre-adjustments. Last pic is final weights.
    Edited:Added final pic. I was surprised about the front to rear weight distribution. Rear weight 1,291, front 1,198
  27. #265
    Lilburn, GA
    Driveshaft Loop
    Finally installed the driveshaft loop. I purchased it long ago from a forum member. Was told it was from Forte, but can't confirm. He purchased it for his MK3, but had never installed it. Still need a hardware trip to pick up grade 8 bolts to finish the install. I was going to modify it, cut the bottom and make it a two-piece assembly, weld on blocks, drill and tap and bolt back together. Discovered you can remove the driveshaft without removing the loop, so no need to modify.
  28. #266
    Nov 2018
    Centennial, CO
    Nice distribution! Can I ask where you got the scales from? I need to do this.
    Bradley
  29. #267
    Lilburn, GA
    A friend owns a auto garage and a friend of his has a oval track race car. We borrowed their scales. I was off about 40 pounds on the rear (and maybe 10 in the front). While installing the spinners/covers, thinking I'm done, I gave the DS rear adjustment an extra 1/4 turn and ended up this close by accident.
  30. Thanks GTBradley thanked for this post
  31. #268
    Lilburn, GA
    Fog Lights
    I heard that the Tangent fog lights were no longer available, but liked the look and wanted some. I purchased the fog lights separately (P/N UW3682) and made the mounting bracket and center grill. Each center grill piece is a separate slice of aluminum, .090" thick.
    By the way, don't drop the light before you install it. Ordered another set, guess I now have one spare light.
    QUESTION: I've seen the running/parking light toward the inside and outside. The original Tangent instructions show to the inside. What do you think looks better?
    Spacers made and installed. Wiring complete. Chose to have the running/park lights on the inside, same as the Tangents lights. I wired the running lights in with the cars running lights. Installed the switch next to the headlight switch. Used the original fan relay location in the fuse box and the unused fan relay. Also added a 3/4" SST washer to dress up the switch face, same as all the other switches on the dash.
  32. #269
    Lilburn, GA
    Grille
    I decided to add a grille. The originals looks like this. The original was also quite a bit smaller and a different shape.
    Here's my attempt at making one. It's not finished yet and only sitting in place. Still need to weld and add mounting tabs.
  33. #270
    Nice work. I like that look, especially with no hood scoop.
  34. Thanks Ducky2009 thanked for this post
  35. #271
    Lilburn, GA
    I got tired of hearing the fan run non-stop.
    Added the Cooling Fan Controller last week (Maradyne Perf. Fans Mfa136 Maradyne Pwm Contoller). I've seen several people add the Sensor Adaptor (Dewhel Aluminum Black Water Temp Meter Temperature Gauge Joint Pipe Radiator Sensor Adaptor Clamps 38mm) in the lower radiator hose. I added it to the top hose, to read the temp of the engine, prior to cooling in the radiator. Being temperature adjustable, it would probably work in the bottom hose as well, but that temp would very based on the outside temp and how fast the coolant cooled off in the radiator. I don't park my car in the winter. The temp doesn't varies enough to park it in Atlanta, so it's out often.
  36. #272
    Lilburn, GA
    Finally added LED Headlights. What a difference. Thanks Fman aka Travis for the part numbers.
    PL700 Tri-Bar Headlamps 54520293 - PAIR
    AUXITO H4 9003 LED Headlight Bulbs 12,000LM Per Set 6500K Xenon White for High and Low Beam Hi/Lo Plug and Play, Pack of 2
    EDITED: Plug and Play.... No additional parts needed. No modifications to the existing wiring.
  37. Thanks GoDadGo thanked for this post
    Likes GoDadGo, 460.465USMC liked this post
  38. #273
    Hummmmmmmm, You Got Me Thinking About An Upgrade Mr. D!
  39. Likes Ducky2009 liked this post
  40. #274
    Anything more than plug and play for the LED swap?
  41. #275
    Lilburn, GA
    Yes, Plug and Play. Nothing extra needed. Approx $160 total cost. Took less than 30 minutes to install.
  42. #276
    Lilburn, GA
    How to track your car if stolen
    Want an inexpensive way to track your car location? Do you have an Iphone? Check out Apple AirTag. $29 investment and works great.
  43. #277
    On a roll Al_C's Avatar
    Wheaton, IL
    This is a great idea! I trust your car is still in your possession...
  44. #278
    Lilburn, GA
    Yes, I still have possession. Just a precaution. Thanks for asking.
  45. Likes Al_C liked this post
  46. #279
    Lilburn, GA
    Exhaust Baffles
    I purchased exhaust baffles from Car Chemistry. The 2" Dia baffles measure approx 1. 875" O.D. ... The size of the I.D of a 2" pipe, according to them.
    I purchased 2" O.D. SST perforated tubing to use as a sleeve. The FFR Polished SST side pipes I.D. measures approx. 2.03". To retain the baffles, I installed two #10 x 2" self tapping screws on the underside.
    The two caps shown are to restrict the flow, a little or a lot. I used the ones with the hole. The instructions say you can use both, the one with the hole closest to the engine and the solid one at the exit end. I'm temped to remove the baffles and install the solid ones too, to see the difference.
    The noise level dropped significantly while cruising.
  47. #280
    How bad did it hurt your performance?
