Thanks Thanks:  6
Likes Likes:  19
Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 132
Thread: Paul2stl #9122 Graduated
    Lilburn, GA
    Looks great Paul. Making good progress.
    Nov 2012
    Tacoma, WA
    Time for another update. Getting closer to official first start and go cart. Did a try at starting last weekend and ran into problems. Not so much with the engine but with the transmission. I did get the engine to run for a few minutes but shut her down right away when i realized i had no engagement with the clutch. At that point I was so mad thinking i would have to pull the engine and transmission. So took a brake from that and worked on some wiring and other little things. Well on Monday I went out to try and see what the problem was. Disconnected the slave cylinder, I'm using a hydraulic clutch set up from Forte Parts Connection. And realized that the clutch was disengaged no matter how far the fork was moved back. Then I thought maybe I shouldn't have put the Ford clutch fork arm pivot ball on the transmission that came with the bell housing and left the Tremec one on the transmission. So call Mike to confirm and sure enough this has happen before to other that received an pivot ball with the bolt kit from Ford he was sending with the kit he put together. Must have missed it on the forum. All is good know and read for first start and possibly a go cart.
    Here are some pics of the problem and what the fork did to the clutch. Just scraped it a little so should be fine.
    The black ball is the one that came on the trans. The shinny one came from Ford since I used a Ford bell housing thought hey that should be used with this set up. WROMG you know what that say about assumptions, they are the mother of all F#$%ups. About 1/2" kept the clutch engage all the time.
    Installed side pipes getting ready for the first start and go cart.
    Seats and harnesses install along with roll bar, not planning to run the chrome FFR roll bar just temporary. Bought the rake and shorter one from Breeze.
    Added a power port and switch in the trunk. The switch controls the LED lights and has a volt cage also.
    Chino Valley, Arizona
    Sorry to hear about the glitch Paul; love your setup in the trunk.
    Nov 2012
    Tacoma, WA
    Thanks Chris, got the idea from Jim. But wanted to have an on off switch for the lights in the truck.
    Nov 2012
    Tacoma, WA
    Here is a video my wife shot and edited. This was after a good break in on the engine and fixed a few leaks . The Speed Hut oil pressure sending unit stopped working. Also I was sent a celsius reading temperature gauge. Guess I’m calling Speed Hut to get replacements. Did get a mil light come on after the break in and few starts. It turned out to be a coolant issue, I’m guessing it was a air pocket in the system since it was a little low. Reset the light and hasn’t came on again after adding some coolant. Other than that has ran smoothly. This thing is freakin fast!! Enjoy the video!
    https://youth.be/EErbusyeYYo
    Congrats Paul! That’s awesome...
    Mark Eaton's Avatar
    Medford, Oregon
    Wow, great work!
    RR20AC's Avatar
    Puyallup/WA
    Sounds great Paul. Great video. My oil pressure gauge failed too, and the temp gauge is Celsius. I left the temp gauge as is and they did send out a replacement for the other. The pollen is really bad right now and you can see in your video how much there is.
    Congratulations. Sounds great.
    Your Progress Is Impressive!
    Nov 2012
    Tacoma, WA
    Quote Originally Posted by RR20AC View Post
    Jim, thanks I call Speed Hut today and they said they could change the gauge out for $15. I just have to send it back. They put me on hold to talk to someone about the pressure gauge for over 30 minutes. I was tired of waiting so just hung up. I will call them tomorrow again and see if they will send a new one. Yeah the pollen is bad it got all over the car. Not happy about that, but I love how fast this thing is. The Coyote has an instant response.
    Nov 2012
    Tacoma, WA
    Thinks I wish I had roads to drive on like you in your first drive video. I did a Go Pro video on the same ride like yours but did like how it turned out.
    Nov 2012
    Tacoma, WA
    Thanks, Steve
    Dec 2017
    Paul2STL, looking earlier in your build there are some great pictures of the front suspension. Wondering what spindles you are using? Are those FFR's?
    Nov 2012
    Tacoma, WA
    I’m using the Factory Five spindles I got them as an upgrade to my base kit. I have a set of the 94-98 Mustang ones that I was going to use, but got the FFR ones when they had the half price sale. Better geometry with the FFR set up.
    Nov 2012
    Tacoma, WA
    Well its been a while since a good update. I have been putting time to other indevors. I planned to do a Comp dash lay out from the very beginning. I thing the biggest challenge was getting the glove to the correct shape. I wanted the upper curve to match the curve of the body.
    I decided to make my own glove box out of fiber glass, tried making aluminum glove box but that was a fail. Used insulation board as a die for laying the fiber glass sheets. Came out pretty good for first time making anything out of fiber glass.
    It came out pretty rough.
    Cleaned it up and trimmed to the correct size then painted.
    Leather was installed in the interior of the glove box. It came out a little wavy thinks to the contact adhesive that sticks immediately.
    And here is the glove box with the door attached.
    Lilburn, GA
    Haven't seen anyone use fiberglass. Adding new choices for the newer builders to consider in their own builds. Nice work!
    Kearney Nebraska
    Nice! what did you use to make the door? Is it just the left over piece that was cut out of the dash?
    Serial #9158
    Nov 2012
    Tacoma, WA
    Thanks David, I saw it some where on one of the forums before. One of my coworkers suggested it to me. It was definitely a practice in patience’s to get it just right. Also thanks for the hazard switch you sent.
    Nov 2012
    Tacoma, WA
    No, wasn’t usable once I cut it out would have been nice if I could. It was a little challenging to get the exact shape of the cut out, but 1/8 smaller. I used two pieces of .040 aluminum sandwiched together. With 1/8 foam under the leather on the front panel to match the rest of the dash and just leather on the inside one. Basically copied what Edwardb did on his last Roadster build.
    Nov 2012
    Tacoma, WA
    Roadster #9122 is almost ready to have its body mounted. I finished covering the dash in blackleather. It was a tedious process ofcutting the dash building the fiber glass glove box and getting everything tofit just the way I wanted. I think itpaid off.
    Here is the glove box I made decided to line it with leather. I used some of the 1/8 foam on the rear wall of the glove box. Probably should of just lined it with leather and no padding.
    Tried to keep the wiring as neat as I could.
    I have a question or would like everyone’sinput about mounting the body. I plan totake the car down to "The Bat" in California in October for paint. Should I mount the body and all the piecesalong with it like latches, quick jacks, windshield, trunk latch etc...? I know Jeff would do all the fitting and thatwould probably include mounting door and trunk latches. I would like to license and title it before Itake it to him. I do not need aninspection done here in Washington, so having it all together is not necessary. Therefore, should I mount the body and somewhatfit it with all the components or just wait until I take it down to Jeff?
  22. Likes cgundermann liked this post
  23. #62
    Looks nice.
    Call Jeff Miller now and discuss your plan. He'd prefer that you don't install hood and door latches and a few other items. He can explain why. Don't know if you can register without latches but I'm sure you can work something out.
    Just picked mine up from Miller and couldn't be happier.
  24. Thanks Paul2STL thanked for this post
  25. #63
    Senior Member Jdav's Avatar
    ATL GA
    While Miller would probably prefer an unmolested body, I'd recommend getting to to a driveable shape so you can put some shakedown miles on it. That way, if you find any issues, you can correct them without having to worry about scratching your brand new paint. Granted, I had my hood duck taped on for probably 100 miles with no issues, so you might be able to find a happy medium
    MK4 #9028 - Coyote - TKO600
  26. Thanks Paul2STL thanked for this post
  27. #64
    Dec 2017
    Southern Ontario
    Quote Originally Posted by Paul2STL View Post
    Nice job on the dash!! Where does the grab bar come from?
    Higgy
  28. #65
    Nov 2012
    Tacoma, WA
    Steve, Jdav thanks for the input. I think I will mount the body, windshield, lights and quick jacks. All the body pieces will be duck taped in place. I’m going to give Jeff a call just to double check.
  29. #66
    Nov 2012
    Tacoma, WA
    Higgy,
    Bought the grab handle from a marine supply place. It’s the polish aluminum with clear coat.
    https://www.eddiemarine.com/shop/dec...et-aluminum-10
  30. #67
    Nov 2012
    Tacoma, WA
    Well found some time to mount the dash and adjust everything. It is pretty tight behind the dash with all the Coyote, Ron Francis, and additional fuse box. This is the look I was after, took a lot of work but I think it paid off.
    Also decided to do the Kleiner mod on the license plate light. I didn't want to cut my plate up. This is an extra plate I had that was already chewed up at the bottom to trimmed it to fit as of now. I plan to cut more material off the light to get the plate up higher so I don't have to cut up my good plate. Also found this license plate frame on the other forum does anyone know where to buy this frame? I looked on Shelby's, Superformance and the company that made it but no luck.
  31. #68
    Kearney Nebraska
    Your dash turned out great! Good job.
    Serial #9158
  32. #69
    RR20AC's Avatar
    Puyallup/WA
    Very nice Paul. Is that a push button start above the key? I'll look around for that frame. I didn't do a grab bar but would have been helpful on all the hard launches. The competition dash is different and if will be fun to compare when we are all on the road together. I'm used to the tach and speed between the wheel now an not sure if it would distract me to look at the center of the dash. Is it going to be on the road soon before paint? we'll all have to go for a run if so. Jim
  33. #70
    Nov 2012
    Tacoma, WA
    This weekend I plan to prep the body for install. Yes the plan is to get it licensed, registered and on the road before paint. No puss button start just the horn. I have a puss button start but not sure if I am going to use it. If I do it would probably be out of sight.
  34. #71
    Nov 2012
    Tacoma, WA
    Making some progress toward mounting the body. After a few trial and errors I finally got the Breeze roll bar fitted correctly. She slides right in with no pushing or pulling on the tubs. Once the body is mounted she should slide right in. I mig welded the hoop slugs to the hoop itself then tack welded the down tub. I took it to a fab shop and they tig welded the leg up for $30. Thought that was a pretty good deal. Then had it powder coated chrome. Was hoping it was a little more mirror like. From ten foot away it looks really shinny like true chrome.
  35. #72
    Lilburn, GA
    Making some progress toward mounting the body...... Then had it powder coated chrome.
    Looks great Paul.
  36. #73
    Nov 2012
    Tacoma, WA
    Thanks David
  37. #74
    Nov 2012
    Tacoma, WA
    Another update. Worked on preping the body for install. First thing was to mount the louver mounting studs to the body that I got from McMaster Car. Used Evercoat Fiber Tech to secure them to the body. I had this laying around from work so I it would be good enough to hold the studs.
    Used the paint stick method to hold in place while I lay on the filler.
    Had to trim the stock hole up quit a bit to get the shape to match the louvers. Its still rough, I will let the painter finish it.
  38. #75
    Looking really good. One hint: The bulb seal isn't supposed to be on the rear cockpit wall between the trunk sides. The aluminum back wall by itself, with carpet, is already a tight fit. Could ultimately affect the fit of your body.
  39. #76
    Nov 2012
    Tacoma, WA
    Got alot done over the last three weeks. I am titled and licensed with over 250 miles on her. What a blast it is to drive and a challenge to keep it under the speed limit. The Coyote revs so high the pipes are screaming at 5000 rpms. Worked out some of the bugs and got the alignment pretty close. Did get a P0116 code for coolant range issue, talked to Ford techs and said it was know issue with the crate motor computers. Just not ready to send it back to get flashed yet, I think I will wait till the rain starts here in the Northwest. The plan for paint is to trailer it down to California for Jeff Miller to lay down the paint. Going with a Ford color Deep Impact Blue with Ingot Silver strips. I didn't put on any door and hood latches or mount the hood per Jeff's instructions, don't want to add more work for him that I would end up paying for.
    Need to still finish the nose aluminum in powder coat, fix the running lights and hook up the oil cooler lines.
    The dash, center cover and glove box turned out awesome. Had the sifter boot and brake boot sewn with the same leather I covered the dash with. Turned out great but a bit pricey.
    Plan to have the Coyote and valve covers painted to match the body in some way just not sure yet what parts will get what color. I know I will get the valve cover plastic painted Deep Impact Blue the main cover just not sure yet. I have time so we will see.
  40. Likes FlyingCobra liked this post
  41. #77
    Congratulations From Way Down South In New Orleans!
    Major milestones are always worth celebrating & this is one of them!
    Laissez Les Bons Temps Rouler!
    http://gatewayno.com/culture/culture.html
  42. #78
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    Congrats! She looks great. What colours you planning?
    Kyle
  43. #79
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    Very nice !!
  44. #80
    Tybee Island, GA
    She Looks Fantastic!
    Videos are at: YouTube Videos
