Results 1 to 19 of 19
Thread: Oil cooler scoop
    Oil cooler scoop
    I was going to put a set of the Tangent driving lights in my oil cooler scoop. Website says Not Available. I contacted them and they said the lights are no longer sold anywhere in the world. He offered the kit at a higher price with better lights, but IMHO they dont fit or look as well. I did ask if they would sell me a kit with no lights, thinking I'd find my own lights to install and didnt get an answer.
    I dont need an oil cooler as temps on the Mid-Atlantic are average. I've heard most F5 Roadsters dont need a cooler unless they are racing, and I only plan on the occasional autox.
    Ideas on what to do with the scoop? Dont really want to leave it open as its obvious that there's nothing there and looks incomplete. Fake the oil cooler and lines? Build my own bracket and install my own lights?
    Other ideas?
    Heart of Dixie, Alabama
    If your car has the authentic look, I would go for the cooler lines in the rad opening and a cooler in the bottom. If you have power steering you can always plumb it into the cooler.
    I have no problems with the lower opening being empty and hope I can direct the cooler air to the intake box.
    That's too bad. I've used the Tangent lights and they look good there. Most don't need an actual cooler. A fake one is an option, as mentioned. Some people put a grille in that opening, similar to the brake ducts. Doesn't look bad. Better than an empty opening.
    Senior Member DavidW's Avatar
    Stevensville, MD
    I'm going to put the Breeze duct in there, I'll post a pic once its done.
    Nowhere near the authentic look. Dual roll bars, hiback Kirkeys, no Halibrand style wheels, way off the original paint. But I do have the kick-back shifter and backwards speedo.
    I may put a cooler in there just to fill the hole or as you said, plumb it into the PS. Oil lines in the rad opening wont work cuz I'm going with the Replicaparts shroud in there.
    Nice idea on using it for intake box air.
    Yeah, I'm a bit disappointed too. Already have the wiring, relay and switch installed for the lights. Think once I get the body back and hung, I'll look into mounting my own lights in there.
    I looked at the grills, its a possibility. Be nice to keep the low flying sparrows out.
    Quote Originally Posted by DavidW View Post
    Are you talking about an actual duct? Or the grills? I havent seen an oil cooler scoop duct...
    The owner of one that I finished recently made tubular grilles for all of the front openings:
    Too bad about the Tangent setup; I've always liked it. I installed what must have been one of the last sets on another car I did just a couple of months ago.
    Senior Member tonywy's Avatar
    Nanticoke, Pa
    On my car I bought the mesh screen from Breeze , it looks much better.
    My thought is give it what should have been there in the first place. A proper divergent duct true ram air system.
    Raleigh NC, OIB NC
    CAI for the COYOTE.
    Kevin
    MKIV #8234
    Thats pretty cool, Jeff. Goes right with the skinny paint stripes and the grills in the gills. Def custom.
    Quote Originally Posted by mikeinatlanta View Post
    Mike, that's awesome work.
    CAI for the COYOTE.
    If I had a ducted intake engine, thats most likely what I would do.
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    Mine has the "oil fooler" - an old-school look, but the lines are just stubbed in through the panels on the sides of the radiator. No need for a functioning oil cooler on the street, but my old-school look car needed this in the opening.
    Later,
    Mk3.1 #7074
    Senior Member karlos's Avatar
    Littleton, CO
    Same here, but with the Replica Parts radiator aluminum.
    MKIV Roadster #8641
    Complete Kit with IRS, Eaton Detroit Truetrac, 3.55 gears, Wilwood Brakes
    Ford Racing Z427 w/ Pro-M Sequential Port EFI System
    TKO 600 + McLeod Midshifter; Fast Freddie's Electro-Hydraulic power steering
    Miller Customs Bodywork & Paint
    Quote Originally Posted by karlos View Post
    So you were able to make it work with the Replicaparts shroud. I like this...
    That looks good, Gumball. Always respected your car and all the work you did, as well as all the helpful posts you put up...
    Dang, Mike, you are an artist! That is amazing work. So nicely done!!
