GTBradley's build - Still Kick'n!
078 Panels - Total Square Footage - Page 2
082 Front Suspension - Page 3
097 IRS Center Section
100 Rear Brakes
101 Coyote Arrived
123 Routing of Rear Brake Lines - Page 4
131 Video Tip for Pulling Studs into Hub
132 Shocks
133 Panel Treatment - Natural Aluminum with Clear Coat
146 Power Steering Rack and Steering Shaft
153 Tires and Wheel Weights
159 Clutch Throw Out Arm
169 Panels and Drop Trunk - Page 5
170 Cheap Bench Top Bandsaw Mod
172 Fuel System
174 Brake Lines 2
182 Cockpit Sound and Heat Insulation
186 Electrical
197 Coyote - Installation
218 Transmission Spacers - Page 6
223 Radiator Mounting - Breeze
226 KRC Power Steering Reservoir
232 Instruments
250 Glove Box - Full Size - Page 7
251 Headers and Side Pipes
252 Heater with Firewall Forward and Full-Size Glove Box
255 Intake
256 Couplers for the Rear Over Riders
257 Cubby and Roll Bar
259 Dash Mount Using Hidden Fastener
260 Buttoning up the Driver's Foot Box
261 Tunnel Top - Leather
264 Body Installed
265 First Engine Start
268 First Drive
270 Trunk Struts and Hinges
272 Carpeting
279 Seat Heaters
283 Off to Paint - Page 8
291 Body Buck Mod
292 Gas-N Side Pipes
303 Painter Updates - Molded Hood Scoop
307 Body Painted
339 Wipers - Page 9
341 Spinner O-rings
343 Seat Brackets - Breeze
344 Wheel Well Panels
347 Broken Windscreen - Replaced with Lexan
363 Colorado Registration Process - Arapahoe County - Page 10
367 Badges
370 Radiator Protection - Nomex Honeycomb
377 Fan Controller to Reduce Fan Run-Time and Noise
385 License Plate Mod
390 Factory Five Floor Mats Mod
398 Driveshaft Safety Loop
401 Clutch Cable Repair and Upgrade - Page 11
424 Whitby Motorcars Soft Top and Tonneau Installed and Time-Lapse Installation video
428 Dyno Tune
431 Seat Repair
434 Self Cancelling Turn Signal
439 KRC Power Steering Pump Flow Valve Change
453 Phone Mount using Dash Support Tube - Page 12
470 Foot Box Vents with Blowers
483 3500 Mile Report - Likes and Dislikes with time breakdown - Page 13
489 Inflatable Lumbar Support
554 Painting Coyote Engine Covers - Page 14
564 Luggage Rack - Page 15
585 Intermittent Wipe and Wash Function Added to the Lucas Wipers
599 Powder coating large items - DIY
609 Forte's Front Anti-sway Bar - Page 16
612 Autocross Spare Wheels and Tires
614 Autocross Improvements
615 Side Pipe Sound Suppressing Inserts
623 Gas-N side pipe sound mod that is removable
639 Radiant heat deflectors for the vent tubes
641 Cruise control for drive-by-wire Coyote gas pedal - Page 17
*6/26/2020 EDIT: Graduation thread posted:
https://thefactoryfiveforum.com/show...in-Drive-Video
July 2020 POM
3500 mile report video:
