Thanks Thanks:  44
Likes Likes:  161
Page 4 of 17 FirstFirst ... 2345614 ... LastLast
Results 121 to 160 of 654
Thread: GTBradley's build - Still Kick'n!
  1. #121
    Nov 2018
    Centennial, CO
    That's right you have one of those fancy Eastwood tools. I thought about buying one of those and then spent gobs of money on other unexpected things and let that thought fade. I'm going to give this a shot first, thanks. I hadn't even considered flaring after the bends though, thanks for that too.
    Bradley
  2. #122
    Nov 2018
    Centennial, CO
    Bradley,
    If you want, get everything bent up and bring your lines over and we can use my Eastwood flair tool to finish them up.
    Thanks Dave, but I think I've got it, it might even be fun and maybe even faster soon. Glad I took Monday off...
    Does that look Right?
    Bradley
  3. #123
    Nov 2018
    Centennial, CO
    Routing of rear brake lines
    Bradley
  4. #124
    The double flair has the right shape, but I'd be a bit nervous about the condition of the tube leading up to the flair and the roughness of the flair itself. It doesn't take much to create a leak and brake fluid is one of the most effective paint removers I've ever seen. Here is my very first flair with the Eastwood flair tool:
  5. #125
    Nov 2018
    Centennial, CO
    Yeah, that tool has ridges that grip the pipe and leave those marks. I can see that Eastwood is pretty good. I'll see if I can clean up on the outside of the flair.
    Bradley
  6. #126
    Nov 2018
    Centennial, CO
    So who’s done the FFMetal firewall forward kit? I’m wondering how the the under dash panel works with it.
    Bradley
  7. #127
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    That's about the only downside... just dress them off with a few light swipes of a small file. They're hidden inside the fittings anyway.
    John D. - Minneapolis 'Burbs
  8. #128
    Nov 2018
    Centennial, CO
    My KC Chiefs lost , though they put up a very good fight. However, it looks as though my POL delivery is here and I took the holiday off.
    Bradley
  9. #129
    Nov 2018
    Centennial, CO
    It does appear to me that the important part for a good seal is the inside face where it meets the opposite fitting.
    Bradley
  10. #130
    Nov 2018
    Centennial, CO
    Well, I'm mounting body of the Koni shocks down also, but just as soon as you think you've seen everything on the subject out pops instructions from just one of the shocks:
    Bradley
  11. #131
    Nov 2018
    Centennial, CO
    Pulling studs into hub
    I had trouble with pulling the new studs into the hub, so when I figured it out I made a quick and dirty video to show that my solution woks well.
    Add two hardened washers and a drop of oil between. Use breaker bar to turn lug nut until stud is flush against hub.
    https://youtu.be/ERK-_ehKumk
    Bradley
  12. Likes ydousurf liked this post
  13. #132
    Nov 2018
    Centennial, CO
    I received the spring hats and a bunch of other POL items Monday, so I was able to get the shocks and springs installed.
    The instructions don't call out the same spacers I had but it was easy enough to figure them out.
    Bradley
  14. #133
    Nov 2018
    Centennial, CO
    Panel treatment - natural
    After giving it a lot of thought and getting quotes that ranged from $550 to $3000 to powder coat all the panels I've decided to go the JKleiner route. My panels will be natural with the visible ones cleaned, scored and treated with clear enamel.
    Bradley
  15. #134
    The front coilovers are to be installed with the body up rather than down as you have them.
    Nov 2018
    Centennial, CO
    I would tend to agree, but there are so many discussions on the forums saying otherwise. Most notably that the double-adjustable Koni shocks require body down but not the single like mine. All official sources I’ve seen agree with you.
    Last edited by GTBradley; 01-23-2019 at 08:10 PM. Reason: delete word "up", add word "down"
    Bradley
  17. #136
    ...the double-adjustable Koni shocks require body up...
    Actually, just the opposite. The double-adjustable Koni shocks must be mounted body end down. Per Koni, the valving mechanism only works properly with the body down and no more than 45 degrees from vertical. The standard red Konis work with the body end either up or down.
  18. #137
    Senior Member q4stix's Avatar
    Seattle, WA
    ... I've decided to go the JKleiner route. My panels will be natural with the visible ones cleaned, scored and treated with clear enamel.
    What enamel did you use? I really like that look!
    Gen 3 Type 65 Coupe builder
  19. #138
    Nov 2018
    Centennial, CO
    Yeah sorry, got that backwards/upside-down. Where does this come from though?
  20. #139
    For the double adjustable shocks, both Factory Five and Koni instructions cite mounting them body down. The Koni instructions say why, as I mentioned in my post. They don't work body up. Don't remember if the Factory Five instructions state the reason.
  21. #140
    Nov 2018
    Centennial, CO
    Ah, now I know what has me confused, the assembly manual has the shocks mounted body down and the #14675 - KONI Front Coil Over Shocks (Download) PDF has the shocks mounted up. Then there is the instruction sheet I received in just one of the shock boxes showing this:
    Anyway, sorry for bringing it up again. I was just curious to know if anyone had gotten official word from Koni on the single adjust shocks (part number 30-1720) saying they could be mounted both ways.
    Bradley
  22. #141
    Bradley,
    This same subject came up early in my build, too. There is a post from Jim at FFR that may settle it in your mind.
    https://thefactoryfiveforum.com/show...l=1#post278032
  23. #142
    Nov 2018
    Centennial, CO
    Bradley,
    Thanks, that does help. The fact that they had a Koni engineer involved helps immensely.
    Bradley
  24. #143
    Nov 2018
    Centennial, CO
    Those damn steering arms! Just when you think you know what you’re doing...
    Bradley
  25. #144
    Nov 2018
    Centennial, CO
    Quote Originally Posted by q4stix View Post
    Thanks, I can only take credit for the elbow grease, it’s Jkleiner’s technique. I used Duplicolor Engine Enamel Gloss Clear with Ceramic. It seems like pretty good stuff and protects reasonably well against finger prints and minor wear - does nothing to protect against stupidity when skidding across it with the revit gun.
    Bradley
  26. #145
    Nov 2018
    Centennial, CO
    I gotta say, one of the most convenient items I have for working on the car is my adjustable rolling desk. It has the perfect height for standing and the perfect height for sitting, even at the lowest stool level. And it keeps the the manual right where I need it.
    Bradley
  27. #146
    Nov 2018
    Centennial, CO
    Power steering rack and steering shaft
    I installed the power steering rack and steering shaft. Not a big deal after fixing the steering arms mistake I previously thought I had avoided.
    I don't understand why the steering shaft is so close to the chassis:
    It's not touching anymore but by slim margin and only after loosening and raising the lower bearing what little distance it would travel upward.
    Bradley
  28. #147
    Aug 2017
    Minneapolis 'Burbs
    Steering shaft clearance seems to be a common problem with the "newer" frames. Mine was the same way.
    Solution:
    1) Either a flat piece of 1/8" plate (shim) or some washers under the pillow block
    2) Purchase Russ Thompson's turn signal setup
    Either one will fix the clearance issue.
  29. #148
    Nov 2018
    Centennial, CO
    Solution:
    Thanks, at least I know it’s not a problem with just mine. If they just raised the point at which the steering shaft came through the foot box front wall a ¼” it would help.
    I was thinking of the shim, I was concerned about the geometry of the steering wheel if I did that though. I’m guessing the RT turn signals essentially act as a shim too. It does clear currently, but if that lower bearing drifts down over time...
    I suppose I could grind a low spot in the 4” cross member as a third option?
    Bradley
  30. #149
    Aug 2017
    Minneapolis 'Burbs
    Raising the lower bearing point isn't really an option for them, it's really tight already with a Coyote powerplant
    (**Future Build Tip Ahead** You'll have to disconnect the shaft at the steering box and swing it outboard just to get the engine in there, so don't LockTite anything down there yet!)...
    Be it a shim, washers, or RT's signal setup, that little bit of angle change won't affect anything. The steering wheel (by design) isn't actually parallel to the dash now.
    I'd avoid grinding a radius in the crosstube. It's not worth the effort when a $.05 washer will fix the problem.
  31. #150
    Put a couple of flat washers under the pillow block---DONE!
    Nov 2018
    Centennial, CO
    I had planned on moving it for engine install. I moved ahead on steps as I still have POL items holding up earlier steps. Good to know about it not affecting the steering wheel position much. Thank you.
    Bradley
  33. #152
    Nov 2018
    Centennial, CO
    Done!
    Bradley
  34. #153
    Nov 2018
    Centennial, CO
    Tires
    I'm going to pull the trigger on the tires. Putting this car on it's wheels can't be more than a couple weeks away. From what I've read on the forums Nitto is a favorite and I think I like the NT555 G2 for its balance of performance and tread life.
    size:
    255/40 17 $128 each. Weight: (tire and wheel) = 48 lbs
    315/35 17 $203 each. Weight: (tire and wheel) = 55 lbs
    Bradley
  35. Likes copythat liked this post
  36. #154
    BadAsp427's Avatar
    Greeneville, TN
    Steering Rack Setup
    Now would be a very good time for you to review this post concerning front steering rack setup... If you find your correct center now, and mark it for later use, you will save yourself a lot of trouble in the future. This photo shows how I marked the steering rod and rack so that I can always take my rack back to dead center. NOTE: this is not the same as turning your wheel lock to lock and back to midway...
  37. #155
    Nov 2018
    Centennial, CO
    ...and perfect timing, I was just starting my investigation of this.
    One question, I have not done initial alignment of the rear wheels yet as I am still waiting on the e-brake cable and the manual says not to tighten bolts down until the e-brake step is done. Will this affect the steering rack setup? ...I see there is a step in there where a string is run from the rear wheels to the front.
    Bradley
  38. #156
    BadAsp427's Avatar
    Greeneville, TN
    The main part of this is to find your center on the rack. The actual alignment will come later and with your IRS, you only have toe and camber adjustments to worry about, you can get those pretty close by eye for now. You will have plenty of time to get the alignment later. It is just very easy to do the centering with everything out of the way at this time. Actual front end alignment will also be done later in your build.
  39. Thanks GTBradley thanked for this post
  40. #157
    Nov 2018
    Centennial, CO
    I went ahead and set the toe and camber on the rears too:
    One thing I'm a little concerned about is the distance from shock to rear tire near the tops - it is different from one side to the other. Actually, with the shock body up the spring hat was touching the tire so I flipped both shocks. I haven't read into rear wheel alignment yet as I still need to install the e-brake and torque the rear wheel nuts.
    Initial alignment done, steering wheel straight
    Bradley
  41. #158
    Nov 2018
    Centennial, CO
    Clutch throw out arm issues
    Okay, some good progress since last post and I'll get that all posted soon, but right now I've got some real consternation going on here. I don't get this throw out arm. I have the Coyote/TKO600 kit from Forte's. The clutch is a RAM. The first problem is there is minimal direction from RAM on how to install the clutch. But I should be able to figure this out, right? Anyway, if someone has put together the same setup as I have here please chime in.
    In one box was was the shorter, black pivot and the silver, longer pivot in with the clutch parts. I don't know which to use...
    ***edit - Mike Forte says use the shorter black one.***
    Then I have this, while the arm sits on the pivot the throw out bearing is not aligned with the center:
    I have the throw out bearing installed on the arm like this:
    So what's going on here, is it me or do I have parts issues? And where are the detailed instructions? Did I misplace them or what?
    Bradley
  42. #159
    Aug 2017
    Minneapolis 'Burbs
    You're so close...
    The bearing just needs to be pushed further onto the throwout arm. When in the correct position it'll kinda just flop/rock on those pivot humps in the arm, but not fall out of place.
    Unfortunately I don't remember which pivot stud I used. Here's a pic of mine installed
    When all is good and you'll not be taking anything apart again, slather a light smear of chassis grease on the snout of the gearbox (where the TOB slides on), and on the pivot stud & fork detent.
  43. Thanks GTBradley thanked for this post
    Likes GTBradley liked this post
  44. #160
    I had the same questions. Call Mike Forte. He will walk you through it. Best thing about buying from Forte is that he will happily guide you through any problems you have.
