Thanks Thanks:  44
Likes Likes:  161
Results 1 to 40 of 654
Thread: GTBradley's build - Still Kick'n!
Threaded View
    Nov 2018
    Centennial, CO
    078 Panels - Total Square Footage - Page 2
    082 Front Suspension - Page 3
    097 IRS Center Section
    100 Rear Brakes
    101 Coyote Arrived
    123 Routing of Rear Brake Lines - Page 4
    131 Video Tip for Pulling Studs into Hub
    132 Shocks
    133 Panel Treatment - Natural Aluminum with Clear Coat
    146 Power Steering Rack and Steering Shaft
    153 Tires and Wheel Weights
    159 Clutch Throw Out Arm
    169 Panels and Drop Trunk - Page 5
    170 Cheap Bench Top Bandsaw Mod
    172 Fuel System
    174 Brake Lines 2
    182 Cockpit Sound and Heat Insulation
    186 Electrical
    197 Coyote - Installation
    218 Transmission Spacers - Page 6
    223 Radiator Mounting - Breeze
    226 KRC Power Steering Reservoir
    232 Instruments
    250 Glove Box - Full Size - Page 7
    251 Headers and Side Pipes
    252 Heater with Firewall Forward and Full-Size Glove Box
    255 Intake
    256 Couplers for the Rear Over Riders
    257 Cubby and Roll Bar
    259 Dash Mount Using Hidden Fastener
    260 Buttoning up the Driver's Foot Box
    261 Tunnel Top - Leather
    264 Body Installed
    265 First Engine Start
    268 First Drive
    270 Trunk Struts and Hinges
    272 Carpeting
    279 Seat Heaters
    283 Off to Paint - Page 8
    291 Body Buck Mod
    292 Gas-N Side Pipes
    303 Painter Updates - Molded Hood Scoop
    307 Body Painted
    339 Wipers - Page 9
    341 Spinner O-rings
    343 Seat Brackets - Breeze
    344 Wheel Well Panels
    347 Broken Windscreen - Replaced with Lexan
    363 Colorado Registration Process - Arapahoe County - Page 10
    367 Badges
    370 Radiator Protection - Nomex Honeycomb
    377 Fan Controller to Reduce Fan Run-Time and Noise
    385 License Plate Mod
    390 Factory Five Floor Mats Mod
    398 Driveshaft Safety Loop
    401 Clutch Cable Repair and Upgrade - Page 11
    424 Whitby Motorcars Soft Top and Tonneau Installed and Time-Lapse Installation video
    428 Dyno Tune
    431 Seat Repair
    434 Self Cancelling Turn Signal
    439 KRC Power Steering Pump Flow Valve Change
    453 Phone Mount using Dash Support Tube - Page 12
    470 Foot Box Vents with Blowers
    483 3500 Mile Report - Likes and Dislikes with time breakdown - Page 13
    489 Inflatable Lumbar Support
    554 Painting Coyote Engine Covers - Page 14
    564 Luggage Rack - Page 15
    585 Intermittent Wipe and Wash Function Added to the Lucas Wipers
    599 Powder coating large items - DIY
    609 Forte's Front Anti-sway Bar - Page 16
    612 Autocross Spare Wheels and Tires
    614 Autocross Improvements
    615 Side Pipe Sound Suppressing Inserts
    623 Gas-N side pipe sound mod that is removable
    639 Radiant heat deflectors for the vent tubes
    641 Cruise control for drive-by-wire Coyote gas pedal - Page 17
    *6/26/2020 EDIT: Graduation thread posted:
    https://thefactoryfiveforum.com/show...in-Drive-Video
    July 2020 POM
    3500 mile report video:
  2. Likes Mylo, Aircontroller liked this post
