Ok, so I maybe getting an early start, but parts are rolling in so what the heck here goes.
I have been wanting to do a Factory Five Roadster since I first saw the add in Mustang and Fords in the Mid-90's. I have long admired the look of the car, so when my wife suggested a Father and Son project build it didn't take much to convince me. I started off looking at unfinished kits and almost had one lined up, but that fell through so I decided to take advantage of the 50% off sale and get a little crazy. My build will go as follows:
Factory Five- Completion Date 8-20-16 and Delivered by Stewart's on 9-2-16
# 8947 MKIV Base Kit for Coyote
-Powder Coated Chassis
-Body Cut-outs
-FFR Front Lower Arms
-IRS Rear
-FFR Coated Coyote Headers
-Complete Coyote Power Steering Kit
-FFR GPS Gauge Set
- Lowback Kirkey
-Halibrand 17x9/10.5
-Polished Overriders
-Stainless Side Exhaust
-MKIV Hood Hinge
-Brake Duct Mesh
-Battery Cut off Swich
-Wiper Kit
-Chrome LH Roll Bar and Grommet Set
-Assembled Side Louvers
-Center Dash Support
-Front and Rear swaybar
-RF Chassis Harness
-Coyote Install Kit
-2015 IRS Rear Brake Kit
-Vinyl Dash
-Wilwood Pedal Box
-Defroster/ Heater Kit
-Windwings
-FFR Radiator Kit
-FFR Front Spindle Kit
Thanks Courtnie!
Like I said I was half off crazy!
FF Metal
Battery Box
Heavy Gauge Firewall
Jegs
2016 Coyote Motor with control pack ( I was lucky to get in on the kit pricing and got the M50AK instead of the M50A)
3.55 Traclok IRS
Rear IRS Hubs
Liberty Gears
UPGRADED-SYNCHRONIZED TREMEC TKO600
Various Online Sources
Spectra F12B Fuel Tank
Spectra Fuel Level Sender
Spectra Tanks Straps
Walbro 255 In-Tank Pump
'95 Mustang Pump Bracket ( larger lines than earlier Fox Body Mustangs)
All Tank Seals
M-6392-M46 - Bellhousing (May upgrade to Quicktime, but found this for $125, so...)
CNC 1483 Remote Reservoir (Thanks Edwardb for the idea)
So still lots to procure and plan. Color is up in the air as I really want Deep Impact Blue, but Wife is railing for some type of Red. I may have to cave since this was her idea, but IDK. Definitely going with a Forte Hydraulic Clutch setup and maybe a Hydroboost. Looking at Breeze or FF Metal fan shroud, not sure which at this point. Really like the look of the oil cooler, but doesn't seem that popular with the coyote. Lots of little things I like at Breeze, Forte and **********, Replicar and Whitby. I really want air, but have not found one yet.
So that is it so far. Anything I should be considering let me know. Anything you see in my build that needs a second look I appreciate the feedback. I have worked on a few Classic Mustang, but nothing this extensive so I look forward to the challenge.
Also I am signed up for the September 2016 Mott MKIV Build School.
